go_a_way1
Old 04-04-2015, 10:48 PM   #2591
StRacngtC06
StRacngtC06's Avatar
Drives: 2013 Whiteout FR-S
what is the lifespan on harnesses, and what is a good track official style?
StRacngtC06 is offline   Reply With Quote
Old 04-06-2015, 04:31 PM   #2592
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
Harnesses get a manufacturing/certification date, usually by FIA or SFI. It's up to the organization you're driving with to determine lifespan, but I think 3-5 years is common.
Unless you've got a fully caged, fixed-seat, track-only car, you shouldn't even be worrying about harnesses. They're generally part of an all-or-nothing safety system including cage, helmet, HANS, seat, etc.
If you're having trouble staying secure in your seat, try getting a CG-lock or the simple trick of pulling your seatbelt out all the way so it locks, then pulling it tight across your lap.
JozhGoober is offline   Reply With Quote
The Following User Says Thank You to JozhGoober For This Useful Post:
EAGLE5 (04-10-2015)
Old 04-09-2015, 09:09 PM   #2593
enivid
enivid's Avatar
Drives: WRB JR BRZED
Are these still good? Name:  uploadfromtaptalk1428624581272.jpg
enivid is offline   Reply With Quote
Old 04-10-2015, 09:47 AM   #2594
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Originally Posted by enivid View Post
Are these still good? Attachment 106710
Yes. That's normal heat checking. If they don't catch a fingernail then they aren't an issue. They are probably getting close to finished, but it's hard to say when. That's why I always have spares with me at the track.
celica73 is offline   Reply With Quote
Old 04-11-2015, 12:20 PM   #2595
ka-t_240
I'm going to agree with his suggestions!
ka-t_240 is offline   Reply With Quote
Old 04-11-2015, 11:04 PM   #2596
Yes, but keep an eye on them with spares at the track.
That's normal heat checking as mentioned above, and it's also a sign that you're getting quicker!
As soon as a crack touches an edge, you need to replace the rotor immediately, and you'll also feel it in your brake pedal.
solidONE (04-17-2015), Ultramaroon (04-14-2015)
Old 04-13-2015, 12:56 PM   #2597
Lateral G
Drives: 2017 Series.Yellow + Perf Package
Alignment
I would like a daily driver alignment, but aggressive as I live in East TN and every road is curvy. I also AX, and am going to Track Night in America at AMP in GA.
In short, a performance oriented alignment that wont wear out my tires in 10k miles.
Suggestions?
Lateral G is offline   Reply With Quote
Old 04-14-2015, 12:21 AM   #2598
juliog
juliog's Avatar
Drives: 86
Suggestions?
Stock suspension?
juliog is offline   Reply With Quote
Old 04-14-2015, 03:48 PM   #2599
Suggestions?
Well, an "aggressive daily alignment" is a track alignment.... so is tire life or maximum grip more important to you?
Old 04-15-2015, 09:48 AM   #2600
Lateral G
Originally Posted by juliog View Post
Stock suspension?
Yes, stock suspension. Stock Primacy HPs. Soon to be stock Bridgestones.
Old 04-15-2015, 09:50 AM   #2601
Lateral G
I'd really like a balance of the two, leaning towards performance as primary concern.
Old 04-15-2015, 10:46 AM   #2602
cjd
cjd's Avatar
Drives: 2017 BRZ
My opinion... Tires are cheap compared to an incident of any kind. Get the track alignment and tires you can flip.
The Following User Says Thank You to cjd For This Useful Post:
CSG Mike (04-15-2015)
Old 04-15-2015, 12:22 PM   #2603
dp1
driving smoother faster
Drives: Sold
I had even wear with -3f/-2.5r camber on Michelin PSS driven primarily on the street with a couple of AX events (.5 mile track with curves, about 1.5 hrs run time each) and one wet track day. Just replaced them with new at 4/32 tread. No burnouts, zero toe front and rear, fun but safe speed in corners on street.
dp1 is offline   Reply With Quote
Old 04-15-2015, 01:03 PM   #2604
redlined600
redlined600's Avatar
Drives: Fr-s
You can run a fair amount of camber with zero toe and be ok unless you're only driving on the highway.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) -- General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) -- General Topics 20 01-10-2012 10:54 AM
