#2521 |
Drives: Nuisance BRZ
Are all tires above that treadwear really that bad? Trying to base my car off GTA enthusiast class specs...
#2522 |
Drives: 86
Achilles 123 are UTQG 220 I think. Pilot Super Sports are UTQG 300, and cheaper than Primacys.
| The Following User Says Thank You to juliog For This Useful Post: | CSG Mike (02-19-2015) |
#2523 | |
I would avoid the Michelin PSS if you are looking to use them on track; the center wet compound greases out pretty quickly so you need to be careful about how use use them. That said, they are a fantastic tire if you aren't looking to heat them up too much.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#2524 | |
#2525 |
The stock tires are terrible on track IMO.
The PSS are a great combo tire between street and track but like David said, you need to maintain control and not overheat them by scrubbing speed with the tires. I ran PSS on my 2011 STi for a season of track and 2 years on the street. IMO they were more than adequate and I run in the Instructor/Advanced groups at HPDE. They also have great longevity as I put about 20K miles including a season of HPDE on them and no real signs of wear other than the usual evidence of tracking them. If you are overheating your tires on track you should consider running smoother as that will make you faster and wear your tires less ![]() -mike |
| The Following User Says Thank You to AZP Installs For This Useful Post: | Racecomp Engineering (02-19-2015) |
#2526 | |
As I said, I have no actual experience with the Primacies so I totally believe you about them.
#2527 | |
Drives: 2023 BRZ
| The Following 3 Users Say Thank You to Pat For This Useful Post: |
#2528 | |
![]() edit: hmmm just double checked the regulations and i guess they "unbanned" them...
| The Following User Says Thank You to car_roll For This Useful Post: | juliog (02-19-2015) |
#2529 |
#2530 | |
Also any of these summer tires here we are talking about would be for a relative novice looking for a tire that can be used for both street/daily driving as well as the occasional track day. Any of us who are up in the higher classes would likely be looking at dedicated or near dedicated track tires in the R888 class of tire IMO. -mike |
#2531 |
#2532 |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Asking since you're the resident RE11A fan (and I'm pretty set on those tires):
RE11A, 17x8 ET48 OZ wheel, stock dampers with RCA yellows and camber whiteline bolts (-1.8 on front alignment). Mostly DD with some parking lot autocross 3-5 times/year. 245/40 vs 225/45 - both will fit the wheel. Subjectively I like the fat look of the 245 but am worried I'd need a 5-10mm spacer to clear the stock strut and the steering feel will be meh/flexy since I'm at the smaller rim size limit. I do have the FT electric SC which breaks the stock tires loose just by gunning it, but not a full turbo/SC setup. I've been stuck on this for awhile - it's only 2cm. :P |
#2533 | |
I believe the RE71R supercedes the RE11A, but I have not yet tried them. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Khyron686 (02-26-2015) |
#2534 |
Drives: 2013 FRS / 2013 427 Vert
Someone help me understand how PSS's work so well on GTR's. I have two friends that use them on their highly modified street legal cars for dual duty. They came in first and second at the NARRA time trials at Sebring in the TTU class with 2:16 laps. Two months later one of them is running 1:14's at Roebling on the same set!
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
