#1989 |
Good advice. May want to add front camber bolts before the alignment.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | GotBRZ1691 (10-07-2014) |
#1990 | |
#1991 | |
An LSD will universally increase grip, whereas a wing will increase rear grip as speed increases. It depends on what you 're doing with it. |
#1992 |
Drives: Raven 6MT
Mike,
I remember a post/discussion from a long time ago that a muffler delete/single exit exhaust made the rear end jittery since the muffler is integrated with the airflow moving under the car and out the back. Just wanted to see if that was true or if im misremembering things? If so, whats the best way to offset it? I know diffuser would probably be the answer but allocating points in TTD probably wont let me....
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
#1993 |
Drives: 86
Many aftermarket cat-back designs create a gap in the underbody —previously filled by the stock muffler— that traps the air flowing from the front, creating drag. This can be offset by installing a diffuser.
See this thread. |
#1994 | |
Drives: Raven 6MT
#1995 | |
#1996 |
Drives: 2023 BRZ
#1997 | |
When the price of Brooks and APR/Voltex are similar, most people will go with the proven name. Brooks will point out that their wings are "PhD designed". APR and Voltex provide results with the top cars at WTAC sporting their aero. Oh, and they also do wind tunnel and CFD analysis, and occasionally release data when it's not deemed a trade secret. |
#1998 |
Drives: Raven 6MT
Totally random note and not doing this anytime soon....if you removed the A/C could you just buy a shorter belt or would that throw off the balance/timing of the engine? I know the usual option is to buy a bracket and a pulley to fill in for the missing A/C.
#1999 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
http://www.ft86club.com/forums/showthread.php?t=43060 http://www.ft86club.com/forums/showthread.php?t=59950 |
| The Following User Says Thank You to dradernh For This Useful Post: | THEmailman (10-11-2014) |
#2000 |
Drives: 2013 FRS / 2013 427 Vert
Copying this post that I left in the P0351 ignition coil thread as it seems this issue is much more prevelant with tracked cars.
Failing coil replaced, car runs up to redline with no issues anymore! Wanted to share some additional perspective on this: Cel started coming on more frequently during daily driving, 6000 rpm would activate it. Gas mileage had dropped to below 23 mpg average Car would hesitate and sputter (stalled once) as you pulled to a stop and seemed sluggish in general. Strange fuel smell in the cabin especially with the fan on high. Possibly unburned fuel?? During the couple sessions that I ran with the cel there was a profound change in the traction / stability control. I had turned it off with the 5 second switch but it was really nuts whenever I had high rpm high g load corners. Motor cut and rear brakes grabbed to the extent that I nearly lost it. With the new coil, all of these street issues are gone and it feels like I am running the E85 tune compared to how the car was running up till now. The power difference is enough to tell the difference. Even the exhaust note standing outside the car at idle sounds different. It would appear that when a coil gets this bad, there are multiple symptoms present even if the cel is intermittent.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#2001 | |
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#2002 |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
