#1779 |
Thanks
Someone just smashed my right rear quarter, wheel, and bumper as I went to get gas in town next to the track. Anyone know how long it will take to have a quarter panel replace? My next event is 5 weeks out so I'm hopeful but not gonna hold my breath What should I look for in the rear suspension as far as damage. Car seems to drive fine maybe a slight pull to the right. How does insurance deal with aftermarket wheels? My brand new PF01 is fucked up. Not bend but rashed bad.
#1780 |
Drives: 2013 Scion FR-S Firestorm
That sucks, sorry to hear that.
Insurance could go either way and it really depends on your local agent.
#1781 | |
Drives: 2013 Scion FRS
If the aftermarket wheel is similar or cheaper in price than a new OE wheel then you should be fine as you have a good argument. If it's more expensive then they might ask you to pay. In that case it depends on how good your negotiation skills are
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#1782 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
#1783 |
Thanks
watkins glen, im still here drinking in my hotel room :\
#1784 | |
Now if it was your fault things are much more complex. You insured your car for some value and, save for some common wording to cover limited aftermarket parts like car stereos, the insurance company is not going to cover costs that are not part of that coverage. That all said, they will probably try and weasel out of as much as they can, it is the insurance company's interest to do so.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#1785 | |
Do you have an oil cooler? Also based *purely* on the GPS traces, this looks suspiciously like what happens when I compare my data to @ImperiousRex's data in the same car: he brakes earlier, enters the turns slower, but more composed, and gets on the gas earlier. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | DarkSunrise (08-19-2014) |
#1786 |
Drives: 2004 Toyota RAV-4 5M
Yeah, its Marc. He's a good guy and I don't really think he's cheating. He got a dyno re-class recently, which freed up the 7 points that the E36 M3 starts with, letting him run Hoosiers. He's going to nationals in September, so I'm sure he'll be compliance checked several times. I was like 3 seconds off his pace at NJMP Thunderbolt, but I think my gap there was more down to lack of track experience since it was my first time there.
#1787 |
This is what I was thinking too.
2022 BRZ Build 2013 FR-S Build |
#1788 | |
I really wish the other guy had a Solo DL that would work with his car. It would be really interesting to see how his throttle work compares to mine in the turns. I may play around with my suspension settings a bit to see if I can let myself get on the throttle earlier as I don't seem to have much understeer yet. Running 4 clicks from full stiff up front and 5 in the back. |
#1789 | |
Watch your turn-ins on the lower speed corners, and you'll see yourself sawing at the steering, and "ratcheting" your input. You need to slow down your rate of input, turn in earlier, and use one larger constant input. Use the pedal dance and trail brake into the turn, so that you can get a bit more rotation out of the car, so that you can get on the throttle earlier. A rear sway or stiffer rear springs will probably help here (although the Ohlins are not designed for a rear spring change). Alternatively, using a 1.5 or 2 way LSD to force rotation on corner entry will work as well. This understeer on turn-in results in a car that is REALLY easy to power out of corners with; this effect is caused by a few things. The car has a static bias toward understeer, so even under power, the front gives out first unless something really upsets the balance of the car. The car also is more stable under powering out because the entry and mid corner speeds are slower, because you need to scrub off more momentum to make the entry to begin with. Your throttle inputs mid-corner are not committed. Slowly squeeze the throttle, and don't commit unless you know you're not going to lift. Skidpad exercises with a loose rear will help your confidence here. As for line, I don't know the track, as I've never driven it, and the elevation/camber/bumps aren't too apparent in the video, but I'd be driving a different line based on what I can tell (but again, this could be wrong). - Turn 1 - I'd brake ~60 feet earlier, trail brake into the corner, and be WOT post-apex before the track out. - Turn 2 - you stab at the brakes pretty hard. My data traces never show brake psi getting that high - Turn 3 - you should be flat here; you can sacrifice the entry into the next corner - Turn 4 - I'd only track out enough to be able to en turn 5 all the way from the left - Turn 5 - I'd single apex it; your car has the grip to do it. Turns 6-8 - Looks solid. Maybe smoother on the brakes through 8, and more throttle commitment, with less sawing. |
#1790 | |
Robispec and I speculated that on a NA car with hoosiers, 205 on 7.5" rims is probably fastest. |
#1791 | |
![]() Turn 2 (3 in track map) - Yeah, I was really trying to brake as late and hard as possible there, which probably wasn't the best way to go about the turn Turn 3 (4 in track map) - That will take some serious cajones to stay flat through there, but I'll build up to it and give it a try. I went a bit faster through there earlier (101-103 the whole way through the turn) but the car was a bit unsettled when I went to go on the brakes and I couldn't quite get it slowed down in time and ended up going a bit off track. See Turn 5 (6-7 on track map?) - Did you mean 6-7 on the track map? If so, by single apexing do you mean staying tight to the inside the whole way though the turn or do you mean ignore the exit apex? |
#1792 | |
![]() Also, that is a very interesting theory about the hoosier sizes. Do you guys think that the lower rolling resistance makes up for the lack of grip from the extra width? Maybe next year I should compromise and run a 215, which would also give me enough points back to go full exhaust, which in turn should put me pretty close to the power/weight ratio for TTD. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 10:54 AM |
