#15 |
Drives: '13 Ultramarine
'13 6MT here, Build date 04/12, took delivery 6/12. almost 17,000 miles. I've had the left side front 1/4 window replaced due to a bad seal, and the car goes in for a new right side tail light tomorrow. Nothing major.
#16 |
Check the Issues/Warranty/Recall subforum:
http://www.ft86club.com/forums/forumdisplay.php?f=72 There have been two confirmed issues that could affect an FRS/BRZ/86 that would require major rework. 1. Check Engine Light/Slip Light error which never got a real solid answer seems to be eliminated. This resulted in a couple blown motors, a couple replacements and a couple of services requiring replacement of camshaft/timing equipment/ecu replacement. Again this seems to have been "solved". 2. Injector seals blowing out, current root cause is said to be shifting at or near redline and when you step back on the gas the engine will knock, over time this will degrade the seals until they no longer seal the combustion chamber causing a lean condition, more knock and eventually things break. The fix should be an ECU update to fix the transient timing tables to prevent the knock under hard acceleration, but there is concern that it may be caused just by heat buildup, in which case a new seal design will have to be released or they will have to find a way to keep the engine cool (lol). If you avoid hard shifting at redline (or at least are easy getting back on the gas after a shift) there shouldn't be any major issues. Everything else is small or a one in a couple thousand fluke. But like everyone else here I'll post anecdotal evidence: 10k miles, zero issues. |
#17 |
New owner here, 2013, FR-S 6MT. No problrms after 1200 miles ...
![]() humfrz |
#18 |
Can't Re Member
Drives: 2013 Argento AT, 2013 Firestorm MT
#19 |
Drives: 2013 MT Asphalt FRS
#20 | |
Drives: 2013 FR-S (Raven Black)
Just over 11 000 Km's here and ZERO issues! No regrets about pulling the trigger on the 13.
FT86Club Central Ontario
http://www.facebook.com/groups/146889685467558 http://www.ft86club.com/forums/group.php?groupid=44 |
#21 |
Drives: 450 awhp twin turbo vr4
Are you smoking pipes ? Knowing it a TOYOTA and you are doubting it RELIABILITY ? What do you smoke ?
#22 | |
Just drive it
Drives: 13' FR-S
I put about 5600 miles and it's been great so far. |
#23 |
Even if it is not 100% Toyota. I wouldnt think Toyota would allow even one platform to ruine his reputation.
#24 |
The only major widespread engine issue that I know about is the idle/CEL issue, which was fixed by a simple dealer ECU reflash.
The DI seal issue is not nearly as widespread, and so far has mainly affected guys who track their cars hard. I'm keeping my eye on it, but it looks like another dealer ECU reflash might be the easy solution. Fingers crossed.
2022 BRZ Build 2013 FR-S Build |
#25 |
Drives: Whiteout FR-S
#26 |
Drives: 2013 FR-S, Asphalt
14K plus miles on mine.Took delivery on October 11. No issues whatsoever. Great fun little car. One of the main reasons to buy my FR-S was that it was being built by Subaru. I've owned 4 Subarus in a span of 10 years and those things are bulletproof.
#27 |
Drives: Raven FRS MT
23K miles and only had the tail-light moisture issue. And crickets of course if that is still seen as an issue. I kinda think of the crickets as the car's trademark sound now haha. if it doesn't have crickets, then it hasn't been properly broken in yet.
#28 |
Drives: 2013 Scion FR-S Raven 6MT
Oh, just stop stewing over it and go get one. You can find the build date on a sticker inside the driver's door, if you want a more recent one. I wouldn't count on any major changes for 2014. Mine was built in March of this year, and I haven't had any problems yet, not even crickets.
Stay squatchy, my friends
