#113 |
Drives: Scion FRS (Asphalt)
S Buttonwillow 13CW (Buttonwillow CA): 2:23.08 / Erik Mc, April/19/2014, bone stock, removed spare tire but had passenger, full trunk, stock pads, stock tires.
#114 |
Drives: 2004 Toyota RAV-4 5M
NA Summit Point Main / 1:27:508 / Josh Adams / April 27, 2014 / Ohlins Road and Track, ACT Prolite Clutch/Flywheel, DSS CF Drive Shaft, Whiteline Pos. Shift Kit & Diff Cradle, Perrin Motor Mounts, Driveway Labs Diffuser, Essex AP Racing Sprint BBK, Ferodo DS-Uno/DS-2500, K&N Drop In Filter, Crawford Performance AOS, Dunlop Z2 235R40
[ame]http://youtu.be/HtCDpjiZj3o[/ame] I know this time is about 0.05 off the pace of Hahm's time, but I thought I'd see if I could get an honourable mention seeing as I'm still street tires, stock exhaust, and stock tune. According to my laptimer, I actually had a 1:26 going in a different session. I knew I had it coming up to the last corner so I tried to really push it and ended up blowing it - |
| The Following User Says Thank You to ja1217 For This Useful Post: | EAGLE5 (04-29-2014) |
#115 | |
Drives: Hydra EMS Powered FRS Raven Black
Typically without the chicane at T3 is 5-7 seconds a lap faster depending on the HP. Last edited by Element Tuning; 04-29-2014 at 04:44 AM. |
| The Following User Says Thank You to Element Tuning For This Useful Post: | EAGLE5 (04-29-2014) |
#116 | |
Dismember
Drives: 2013 Red Scion FR-S
I consider you quite honorable.
Now get the proper tires, exhaust, and tune so you can crush his time.Quote:
#117 |
Dismember
Club circuit? Some other circuit? I don't know the park, but I see two optional turns for a total of four possible tracks.
#118 |
Getting the tires (Hoosier R6's) this weekend @ VIR, although they will only be used for initial break-in procedures. Exhaust probably won't happen for a while, as that would bump me up a class for time trials (it was either exhaust or the tires, I went with tires). An E85 tune might be in the near future, as that won't affect my class, but I'm kind of wary about using E85 and I don't think I'll need it, but we'll see.
#119 |
Drives: 2013 SWP BRZ
Sebring / 2:38.95 / Scott Bartlett / 03/23/2014 / RCE T2 coilovers, 215 Nitto NT01s, Cobalt Friction pads, TF brake cooling kit, Motul fluid, StopTech SS lines, muffler delete, cat delete front pipe and drop in HKS air filter w/ snorkel mod
[ame="https://www.youtube.com/watch?v=Gt5Cmhg39wE"]Sebring - 2:38 Lap in the BRZ - YouTube[/ame]
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
#120 | |
People are seeing 3+ seconds quicker! Lower power cars may not be as much. Most of the time is made up at T3-T4 and heading into Oak Tree.I think next weekend will be even faster if anyone is going out for NASA. |
#121 | |
#122 |
Virginia International Raceway (Full Course) / 2:18:138 / Josh Adams / Nov 12, 2013 / Ohlins Road and Track, ACT Prolite Clutch/Flywheel, DSS CF Drive Shaft, Whiteline Pos. Shift Kit & Diff Cradle, Perrin Motor Mounts, Driveway Labs Rear Diffuser, Essex AP Racing Sprint BBK, Ferodo DS-Uno/DS-2500, K&N Drop In Filter, Crawford Performance AOS, Dunlop Z2 235R40, 70lbs. of ballast
[ame]http://youtu.be/IPp4XnKWkYg[/ame] Unfortunately I only had a one day weekend at VIR yesterday as one of my brake rotors cracked and I did not have a replacement. I managed to limp my car home and replacements and spares have already been ordered. This was my first time driving with the 70lbs. of ballast that I'll need to stay in TTD in the car, so I was getting used to that. Fairly confident that I could have easily gotten into the 2:17s on street tires since I think I was going in too hot for turn 4. I did one short session for the initial break-in procedure for the Hoosier R6s and had a 2:15 going before heading off into the pits. Looking forward to my next event where I'll get to really push the Hoosier's and see what they got. Forgot to mention, my overlay program seems to mess with the best lap time for some reason, which is why it only shows a 2:18.304 in the video. Also, my camera was aimed a little too low and the video outside the car got a bit washed out. Last edited by ja1217; 05-04-2014 at 03:31 PM. |
#123 | |
Crazy what fresh pavement and a few slightly wider corners will do. |
#124 |
Dismember
I'd like to see @ja1217 and @Element Tuning swap for a run at VIR. See how the mods affect times on the same day.
#125 |
NA New Jersey Motorsports Park (Thunderbolt Bypass) / 1:34:267 / Josh Adams / May 18, 2014 / Ohlins Road and Track, ACT Prolite Clutch/Flywheel, DSS CF Drive Shaft, Whiteline Pos. Shift Kit & Diff Cradle, Perrin Motor Mounts, Driveway Labs Rear Diffuser, Essex AP Racing Sprint BBK, Ferodo DS-Uno/DS-2500, K&N Drop In Filter, Crawford Performance AOS, Hoosier R6 225R45, 70lbs. of ballast
[ame]http://youtu.be/At1gpuiOqdc[/ame] This was my first time on Thunderbolt and my first time competing in NASA's Time Trial program in class TTD. I ended up coming in 3rd place (2nd place was a stripped out RX8 that ran a 1:34.080, and 1st place was a well prepped E36 M3 who broke the track record, which he already had, with a 1:30.5 something) and I know I left some time on the table. The octopus section (the tight right then left loop towards the end of the lap, before the bridge) was giving me trouble all weekend and I ran out of my DS-Uno brake pads and was running my street pads DS-2500's so I was all over the place (sometimes not even on the track) in turn 1. |
| The Following User Says Thank You to ja1217 For This Useful Post: | EAGLE5 (05-20-2014) |
#126 | |
| Can too much grip hurt track times? | ayau | Tracking / Autocross / HPDE / Drifting | 53 | 04-22-2013 11:28 AM |
| Top Gear (UK) track times | GeeTee86 | AFRICA | 29 | 02-15-2013 08:04 AM |
| Before/After Track Times (Sonoma Raceway) | CorteXracing | Tracking / Autocross / HPDE / Drifting | 5 | 11-26-2012 11:28 PM |
| POST YOUR FASTEST GT5 NURBURGRING TIMES.... | FT-86GOD | Other Vehicles & General Automotive Discussions | 96 | 07-15-2012 01:45 PM |
| GT5 - fastest Suzuka (full track) times | NESW20 | Other Vehicles & General Automotive Discussions | 11 | 04-03-2011 01:20 AM |
