#281 |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Fastest Track Times Thread
Watkins Glen. NASA TTD
2908lbs with driver/164whp 2:15.62
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 Last edited by lutfy; 09-26-2017 at 01:50 PM. |
| The Following 4 Users Say Thank You to lutfy For This Useful Post: |
#282 |
Subaru Ambassador
Drives: 13 BRZ 18 Silverado
[ame="http://m.youtube.com/watch?v=ojfGPYi1REE"]http://m.youtube.com/watch?v=ojfGPYi1REE[/ame]
Watkins Glen. NASA-NE. I think I had a 2:14.xxx going but my friend in the grey EVO was holding me up in a few corners. Car felt fantastic thanks to corner balancing the night before. Thanks Edgar (endless_pain). 2:15.78 Last edited by subielife; 09-26-2017 at 02:08 PM. |
| The Following 4 Users Say Thank You to subielife For This Useful Post: |
#283 |
Drives: 2013 Scion FR-S Firestorm
Geeze! You guys are quick. But I guess H7s vs Proxes RRs, I'm probably giving up about a second.
[ame="https://www.youtube.com/watch?v=Tu0WH0Ce7NE&t=6s"]https://www.youtube.com/watch?v=Tu0WH0Ce7NE&t=6s[/ame] Finding a clear lap in traffic is a gift. This, and almost every other were mildly to moderately compromised. If it can be believed, stringing my fastest sectors together from the session would have made for a mid 2:15. So I think I'm at least close. ![]()
#284 | |
Have you tried the flat foot shift feature? I have it tested back to back and its worth .25 secs on the track. Thanks to Emmanuel Baako for showing me the data initially. Cheers, Lutfy
2022 LR Defender 2023 BMW M2 |
#285 |
JHerbert Racing
Drives: 2013 Scion FRS
Man I am slow......My Watkins Glen fast lap is 2:19.36 using Maxxis RC1s
What no lift shift are you using? OFT?
| The Following User Says Thank You to Takumi788 For This Useful Post: | jjaisli (10-04-2017) |
#286 | |
- 2013 Scion FRS - Enkei RPF1 - Toyo Proxes RRs with about 12-13 heat cycles (during this run) 235/40/17 - Bilstein B16 coilovers (not ideal for the track but workable--on the stiffest setting they're probably a bit over damped and under sprung--I think that's why I'm getting so much understeer at T7-T9 but I like the stability under braking) - Raceseng Camber plates & lower control arms -3.5/-2.5 (have to check the toe settings) - Stoptech BBK - TRD Exhuast, Highflow cat, OF UEL header (coated) - Moto East Custom tune - Autopower rear cage (welded) with 'proper' seats and a 6 point. The last time it was corner balanced, with me + a half tank of fuel it was 2,899-lbs (I'm about 200-lbs with clothes and shoes) I don't know the track temperature but the ambient during this run was about 58* and it was bright sunshine. It HAD been 37* the night before and it was raining the previous day. So I'd say conditions were ideal for power delivery but maybe not for grip. But it felt good. I haven't tried flat foot shifting although Moto East did add it to the tune. (side note--it's normally controlled through the cruise control but I'm running a removable wheel and have no cruise control stalks so it's now this funky combination of hitting the defrost button x amount of times with the key in position I with your foot on the brake. LOL Or some such thing. But I have a beatronix box which makes the pedal dance a bit easier. But getting back to flat-foot-shifting, not sure I really want to try it as it seems like it would be kind of hard on the trans and synchros. I'd prefer to keep the car going for a while. I'm not after tenths that badly. On almost every lap, of this session I was slightly compromised in some way. So yeah, I think I probably could have been in the 2:16s. Or that's what I'm telling myself. The first two sessions, it was only 40*/44* and the track/curbs were still a bit damp. And the final two sessions were combined with other groups and it was REALLY impossible to string a good lap. And I think at that point, the 'magic' had long gone out of the RRs. Saturday it was raining the whole day and Friday I had my RA1s mounted and could only get into the 2:19s. They still have plenty of tread so they were howling in protest and I was trying not to abuse them too badly. Despite this I had a GREAT time out there and people were generally well behaved. It was my first event with GVC. Lots of fun. I just wish they would continue the point-by generosity by ALSO backing off. Here's the full session if you're interested. [ame="https://www.youtube.com/watch?v=-SSNAcJ889Y"]WGI w/BMW GVC: Solo Session 2:17.07 on DOT Rubber - YouTube[/ame] Last edited by jjaisli; 10-04-2017 at 01:30 PM. |
| The Following User Says Thank You to jjaisli For This Useful Post: | subielife (10-04-2017) |
#287 |
#288 | |
Lutfy
#289 | |
My alignment is spot on with yours. Yesterday I installed stiffer rear rates to combat the understeer. 550 front and now 650 rear. Felt great in parking lot testing, may want to consider rates and or playing with heights. I am tinkering as this car is newly built....Will know this weekend at VIR. The flat foot does not hurt the synchro, it takes the revs down so essentially you are holding off gas when clutch is depressed but on data, it adds up to a few MPH end of straight. Not big but a few shifts here and there it adds up. I am competing for time (Nasa TT) and in DE setting run normal shifts. Lutfy
| The Following User Says Thank You to lutfy For This Useful Post: | jjaisli (10-05-2017) |
#290 | |
And I guess I kind of misunderstood the concept of flat foot shifting. Got it now. EDIT: Although I have to say, the softer springs DO allow me to attack curbs with confidence. |
#291 |
Drives: 2014 FR-S SSC
Blackhawk Farms / 1:26.925 / Eric Koehler / 10-8-2017 / Ferodo DS2500 pads, 215 Zestino Gredge 07R tires, otherwise all stock even the wheels
No video, timed with Harry's Lap Timer Also did a 1:29.072 standing start (high speed autox format for those familar with this track) |
#292 |
In the slipstream
Here’s my fastest lap of the year, a 2:07.8, in my 2013 BRZ.
Mods are: 17x9 RPF1's 245/40/17 RS4 MCS Coilovers [ame="https://www.youtube.com/watch?v=bXSNkjUV9ts"]High Plains Raceway Emich Track Day 10/15/17 BRZ - YouTube[/ame] |
#293 |
@lutfy Greatest avatar!
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | lutfy (10-24-2017) |
#294 |
Drives: unlimited cheap build N/A track car
ROAD ATLANTA
ROAD ATLANTA
MARK TURNER 1:40:4 SEC. MODIFIED N/A RPF1,235-40-17 NT01, OFT E-85 TUNE, WILWOOD, CUSTOM SUSPENSION COMPONENTS, FLEX-Z, TRACK CAR. I am waiting for a cooler day to go for sub 1:40:00 |
| Can too much grip hurt track times? | ayau | Tracking / Autocross / HPDE / Drifting | 53 | 04-22-2013 11:28 AM |
| Top Gear (UK) track times | GeeTee86 | AFRICA | 29 | 02-15-2013 08:04 AM |
| Before/After Track Times (Sonoma Raceway) | CorteXracing | Tracking / Autocross / HPDE / Drifting | 5 | 11-26-2012 11:28 PM |
| POST YOUR FASTEST GT5 NURBURGRING TIMES.... | FT-86GOD | Other Vehicles & General Automotive Discussions | 96 | 07-15-2012 01:45 PM |
| GT5 - fastest Suzuka (full track) times | NESW20 | Other Vehicles & General Automotive Discussions | 11 | 04-03-2011 01:20 AM |
