Old 01-21-2014, 01:33 AM   #43
KonTheory
Drives: '14 FRS
Is the sound difference huge from resonated to non resonated?
Also other than noise is there a reason to pick one over the other?
KonTheory is offline
Old 01-21-2014, 08:41 AM   #44
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Resonators reduce rasp in a system, but they also add cost to the MFG side of things. I'd personally always go resonated.
FT-86 SpeedFactory is offline
Old 01-27-2014, 05:34 PM   #45
N_A
Drives: 2013 Raven
Sound clips?
So does anyone have a sound clip of this with stock header and front pipe? Resonated vs. Non resonated?
I really want to get this exhaust but I just want to hear more of it. In car, drive bys, etc.
I want to buy this thing like right now. Lol.
N_A is offline
Old 01-27-2014, 05:57 PM   #46
ScionFamily
ScionFamily's Avatar
Drives: Magnetic Gray tC, Silver FR-S
I was going to do one, but jumped the gun and put everything on. I'm will to bet that you can't go wrong with this exhaust with the stock header and front pipe though.
ScionFamily is offline
The Following User Says Thank You to ScionFamily For This Useful Post:
N_A (01-28-2014)
Old 01-28-2014, 02:09 PM   #47
N_A
Drives: 2013 Raven
Thanks. Any drone before you put on the header? How loud was it compared to other exhaust that you know of?
N_A is offline
Old 01-30-2014, 02:53 PM   #48
ScionFamily
Can't say it would be too loud but it would most certainly give you a deep and louder than stock setup. You won't be disappointed and I would say go resonated in cause you want more.
Old 01-30-2014, 03:48 PM   #49
FT-86 SpeedFactory
Originally Posted by touge-n00b View Post
Any chance we can get a video without any other exhaust add-ons (I.e. stock front and over pipe, and stock headers)? Also if it was mentioned elsewhere I apologize, but is there an official weight?
26lbs. We'll try and do that for sound but it will take us some time. A lot in the pipe right now to do.
Old 04-01-2014, 02:40 PM   #50
Pseud0logik
Pseud0logik's Avatar
Drives: '13 Firestorm FRS MT
I'm looking high and low for a video of this exhaust on an otherwise stock car. I almost pulled the trigger on a Tomei 60s but decided it's just too loud. I really want a single exit for the weight savings, but I'm concerned about volume too.
Pseud0logik is offline
Old 08-01-2015, 01:23 AM   #51
Scuba86
Drives: 2014 FR-S Monogram Raven
Originally Posted by FT-86 SpeedFactory View Post
We are proud to finally release our V2 Single Exit Exhaust system for the Scion FR-S, Suabru BRZ, and Toyota GT86.
This is the review of this system and general information.
After a very long delay that seemed like forever we have finished our V2 exhaust. We had one goal in mind here really and that was to reduce the weight of the exhaust system. That was achieved here.
We used a V-Band clamp again to attach the axle back portion for ease of install, and backwards compatibility with our V1 system. So for those of you who own our V1, you can grab the V2 axle back and simply swap out for track days to loose some weight if you want, or just want to rock the single look for awhile. We use the exact same mid-pipe making this change possible.
If you are looking for something made in the USA, that's extremely high quality, super lightweight, and provides a great sound, then this is it.
Super lightweight. Muffler section weights in at 10 lbs exactly. Add in our mid pipe at 16lbs, entire systems is 26lbs.
V2 SPECS:
2.5" T304 Stainless Catback to Muffler
Minimal bends, Single Piece Mid-Pipe No pie cuts and welds here.
4" Stainless Angle Cut or Rolled tips
Made in the U.S.A (Iowa to be exact.)
V-Band Clamp for rear section
Un resonated or resonated options are available on this system
Extremely light weight
Fits both manual and automatic FRS / BRZ cars
Backwards compatible with the V1 system.
This system is on our Silver FR-S and will be at the 86Expo in Las Vegas. Come by and check it out.
Picture time.
Resonated:
Non Resonated:
Standard Pics:
On Car:
Videos contain the following exhaust mods:
Borla UEL
Motiv Over Pipe
Invidia Resonated Front Pipe
FT-86 SpeedFactory V2 Exhaust ( Single Exit )
Rev Video - Resonated Version:
Drive By - Resonated Version:
More videos and dyno's after we get back from 86Expo in Las Vegas.
Drive By on the Salt Flats - Resonated Version:
The pictures wont load for me in the first post but does anyone have pictures of the ground clearance under the car? Or any sound clips of the resonated one with just the exhaust and stock header/fp etc..
Scuba86 is offline
Old 08-26-2015, 12:23 PM   #52
FT-86 SpeedFactory
Pics should be working again.
SINGLE EXIT EXHAUST karma003 Engine, Exhaust, Transmission 163 06-28-2018 03:48 PM
FT-86 SpeedFactory - V1 Cat Back Exhaust - RELEASED FT-86 SpeedFactory Engine, Exhaust, Transmission 203 03-13-2017 12:29 PM
For Those of Us with a Single-Exit Exhaust naikaidriver Engine, Exhaust, Transmission 12 09-05-2013 02:20 PM
Single exit exhaust? Sonydigital Engine, Exhaust, Transmission 24 07-21-2013 12:26 AM
Stock Exhaust to Single Exit DriftEightSix Engine, Exhaust, Transmission 3 02-16-2013 11:48 PM
