Old 06-16-2015, 01:03 PM   #127
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Originally Posted by philooo View Post
quick question, so you have no more cooling duct with your ap racing spring setup ?
and you still want pads that works at lower temperature XR3 instead of XR5...
do I get this right the kit is so good not only you don't need the ducts, you are even going to a lower temperature pad
Sorry for the late response.
Correct, TF Cooling Kit is great, but doesn't work with the AP kit. And The XR2 Cobalt pad is overkill now, as I'm not getting the most out of them, and am moving to the XR3 pad. Just goes to show the efficiency of the AP kit.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 08-06-2015, 05:15 PM   #128
IPGJames
Drives: ...Cars...
I pm'ed you but that was before I found this thread...you can disregard that....great information here and answers all the questions I had for you....thanks for the detailed information. Making my decision over buying a BRZ or not as a track car easier.
IPGJames is offline   Reply With Quote
Old 08-18-2015, 02:54 PM   #129
smbstyle
smbstyle's Avatar
So a few more updates:
June 14th - OEM clutch is toast. The surface material is fine, but the center shaft of the clutch is separating from the body of the clutch, and flopping around. You can see where it's chewed up a bit and offset.
August 14th - Finally bit the bullet and put an oil cooler in. Summer at Sebring we were seeing 290*+ sustained, and the next day we tested at Sebring with the oil cooler (Mishimoto kit) and ended up seeing high 230's* sustained, max 245*. Water temp dropped about 8-10* as well.
Also this past weekend at Sebring I got a P0302 and P0300 code, Cyl #2, which has had the coil pack replaced twice already. I believe it's an issue with the spark plug, as that is the farthest away from the heat from the header, so I doubt it's a heat issue with the coil pack. Will change the plug and report back.
2013 SWP BRZ
Old 08-18-2015, 05:25 PM   #130
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You gonna be at Sebring with HoD this month?
Old 08-19-2015, 05:08 PM   #131
Chazzzy
Drives: VW GTI
I love reading these track car threads. Lots of good info in here.
Keep it going!
Chazzzy is offline   Reply With Quote
Old 08-21-2015, 08:38 AM   #132
smbstyle
smbstyle's Avatar
Nope, I only run with Chin Motorsports (one of the reasons is that I'm one of the managers.) Come to Sebring with us in October!
We're also going to be doing a night DE in December (and possibly November).
2013 SWP BRZ
Old 08-27-2015, 02:45 PM   #133
King Tut
NASA SpecE30 Racer
King Tut's Avatar
NASA has a Sebring event in October I am doing. A couple of my S2000 buddies already bailed on Sebring this weekend, but I am still planning on going.
The Following User Says Thank You to King Tut For This Useful Post:
smbstyle (09-01-2015)
Old 09-10-2015, 10:22 AM   #134
smbstyle
smbstyle's Avatar
So after 6 months of running the BBK, I want to provide some insight on my consumables of the AP Sprint Kit (what you can use to justify to your wife/significant other why you "need" this kit!)
Before the AP Sprint Kit, I was running OEM calipers and rotors with SS lines, Cobalt Friction XR2 pads, Torque RT700 brake fluid with the Touge Factory brake cooling kit.
Tracking the car for about 2 years in that configuration, I was going through pads every 3 days on track (sometimes 4 if I was easy on it), and rotors every 7 days on track.
I installed the AP Sprint Kit back in March, along with fresh Torque RT700 fluid, and now have 23 track days on the AP Sprint Kit in the past 6 months (6 days at Road Atlanta, 10 days at Sebring, 2 days at Homestead-Miami, 1 day at MSR Houston, 2 days at VIR and 2 days at Barber).
So far I have gone through 1.5 set of pads (first set Cobalt XR2s, second set that is currently installed - Hawk DTC-60s) and am still on the original rotors.
So, to compare and break down the numbers....
The OEM setup was costing me approximately $85.76/track day, while the AP kit costs me $28.46/track day (estimating the rotor replacement at 25 days, which is very conservative, as they just have normal heat checking on them now).
Including the initial cost of the AP Sprint Kit at $2,099, the AP Sprint Kit LITERALLY pays for itself after 38 track days in my case (wear/costs of consumable may vary depending on track, experience level, etc). For me, that's less than a year of track days. These numbers do not include caliper rebuilds, band-aids for busted knuckles constantly working on the OEM brakes, etc...
Here are some numbers and a chart to give to your wife to justify your purchases .
Thanks again to Jeff @JRittand the Essex Parts team for their support throughout the purchase and installation process, as well as checking in with me routinely post-sale. Great group of folks, and I highly recommend them.
2013 SWP BRZ
The Following 4 Users Say Thank You to smbstyle For This Useful Post:
Chazzzy (09-05-2016), killboy (02-23-2016), philooo (09-10-2015), weepel (02-23-2016)
Old 09-10-2015, 10:34 AM   #135
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Nice way to break down the data.
smbstyle (09-10-2015)
Old 09-10-2015, 10:59 AM   #136
philooo
Drives: 13' Scion FRS Track car
suddenly I feel better about me spending the money on the essex...
philooo is offline   Reply With Quote
The Following User Says Thank You to philooo For This Useful Post:
Old 09-05-2016, 10:51 AM   #137
86ft.lb
86ft.lb's Avatar
Drives: orange fr-s MT
smbstyle, do you still find bbk without duct is adequate for your application? Is there any uneven wear, pad knockback, soft pedal issue when pad is worn more than 30-50%?
I am running oem caliper with TF duct and raybestos racing pad. The pad easily lasts for 20+ track days and upkeep cost is minimal. But uneven wear and pad knockback kills me. I am considering bbk kit mainly for reducing uneven wear and knockback. I would like to know how your bbk performs in this department. Thanks.
86ft.lb is offline   Reply With Quote
Old 08-29-2017, 10:59 PM   #138
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Sooo... This is one of the best build threads I've read on here. What happened to the guy? I see that he last logged on back in May.
ApexEight is offline   Reply With Quote
Old 09-23-2017, 02:42 PM   #139
Opie
Opie's Avatar
Drives: '13 BRZ TLM Spec
smbstyle is now working for Porsche North America as the Manager of Motorsports and Driving Events. His BRZ is now part of the Chin Track Days fleet.
Living the gear head dream!
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
ApexEight (09-23-2017), Pat (09-23-2017)
Old 11-28-2017, 01:12 PM   #140
Opie
Opie's Avatar
For those interested, smbstyle's BRZ is now for sale:
http://thechinforum.com/forum/member...013-subaru-brz
