View Poll Results: Have you had an issue with your Direct Injection System?
I have had a DI issue and was fixed under warranty (Subaru) 10 12.35%
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) 2 2.47%
I have had a DI issue and was fixed under warranty (Toyota) 31 38.27%
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) 3 3.70%
I have had a DI issue and denied warranty by (Subaru) 7 8.64%
I have had a DI issue and denied warranty by (Toyota) 14 17.28%
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) 8 9.88%
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) 6 7.41%
Voters: 81. You may not vote on this poll
Old 01-21-2015, 11:36 PM   #533
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Is the DI issue covered via powertrain warranty (60K miles) or the basic one (36K)?...I am thinking the powertrain but correct me if I'm wrong..
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 07-29-2015, 01:19 PM   #534
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
My car started exhibiting this problem after an autocross this past Sunday. Cliff notes:
-Bought the car used with 2500 miles on it, at 39k now
-It's seen 7 track days, and lots of autocrosses
-Was stock powertrain until about 3 weeks ago when I built up fr STX, now it has an intake, header, exhaust, and tune.
Symptoms are limited to when the car is fully warmed up, heavy load acceleration from 2500-3500 RPM or so. Found another thread with someone who described this exact scenario and his Cyl 1 seal was completely gone.
Took my car to the dealership, they denied warranty work as expected because of the tune and aftermarket parts. They also refused to diagnose the problem because there is no CEL present.
The other member with my noise posted a video:
That is exactly what my car sounds like, and it's seen plenty of track time, so I'm confident enough to tell Toyota to replace the DI seals without diagnosing it. It's an $850 gamble on my part.
Here's the interesting part: They said they're going to use TRD high pressure seals. Anyone else heard of this? I can try and get the part number, haven't found it online yet.
Should get my car back tomorrow. I'll keep everyone posted.
trippinbillies40 is offline   Reply With Quote
The Following 3 Users Say Thank You to trippinbillies40 For This Useful Post:
Ramster (07-29-2015), strat61caster (07-29-2015), Tcoat (08-04-2015)
Old 08-04-2015, 03:26 PM   #535
trippinbillies40
Drives: '22 WRB
Quick update. After a week of "it'll be done tomorrow", finally got the car back today. Total cost of $830. Cylinder 1 injector seal was completely gone.
The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post:
Tcoat (08-04-2015), thambu19 (11-06-2015)
Old 08-04-2015, 04:05 PM   #536
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Anything to add on this?
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 08-04-2015, 09:30 PM   #537
trippinbillies40
Drives: '22 WRB
Unfortunately not really. I looked up the part numbers and nothing says "TRD" from what I can find. Let the invoice at work. I'll post part numbers tomorrow. The whole ordeal with the dealership was a nightmare and I just wanted to get my car back and get out of there. Sorry
Old 07-06-2016, 06:07 PM   #538
LLYNCES
LLYNCES's Avatar
Drives: 13 Firestorm/UltramarineRIP/15 Halo
My car was experiencing the hard shifting issue found in the AT (There is a TSB for it) which basically made the car not rev match correctly and idle properly (ecu related) I ended up getting a CEL on this car prior to my appointment date to get the ECU fixed and barely made it to the dealer with the car (limp mode)
Turns out two direct injector seals failed on my car and they said it was a seperate issue - to me it seems a more likely that the AT hardshifting problem caused this as it seems this DI failure is caused by a bad factory tune and shifting at high rpms.
Toyota is fixing this under warranty, going take around a week. Not happy about this as you think the 2015 models would not have this problem.
LLYNCES is offline   Reply With Quote
Old 09-15-2016, 11:33 AM   #539
pepe
Drives: gt86
you think a header uel catted can damage the injectors?
pepe is offline   Reply With Quote
Old 01-03-2017, 05:30 PM   #540
MagicMexican
Drives: 2013 BRZ Premium
Hey guys, I just picked up a 2013 BRZ with 41,000 miles on it. I've had the car for 2 weeks and not noticed anything strange, but I've just babied it so far. It drives great, but now that I joined this site and did some reading, I am starting to get paranoid. I don't know the exact build date, but the carfax I was given shows the first owner bought it in 7/12 so that makes me at risk for having this issue, correct?
The carfax shows plenty of regular maintenance, but nothing about an ECU reflash or seal replacement. This is the first car I've ever financed and had warranty on, so I'm not 100% sure how everything works. Should I go to the dealership and just say 'Hey, I'd like you guys to check the ECU and tell me what version of software it has?' or should I just get a tactrix cable and flash it myself? Will that affect the warranty? I'm supposed to have a 7 yr, 100k mile warranty.
Basically, I'd like to be sure that my car is not at risk but I'd also not like to get jerked around by the dealer and I'd like to know exactly what to say/do to make sure my car's protected.
MagicMexican is offline   Reply With Quote
Old 01-03-2017, 07:07 PM   #541
radroach
Drives: car
@MagicMexican you'd want to check the TSB to see if your car's vin falls in that range.
Old 01-03-2017, 07:28 PM   #542
steve99
Their is TSB out for dealers to flash cars prior to B01C/D calibration to that ECU calibration generally cars built prior to late 2013
http://www.ft86club.com/forums/attac...1&d=1386706237
and
http://www.ft86club.com/forums/attac...1&d=1395947828
just complain of rough idle and idle dips when a/c cut in/out
Old 01-03-2017, 07:34 PM   #543
steve99
no its the poor factory tune on low quality petrol causing excessive knock on high rpm shifts.
http://www.datazap.me/u/steve99/sout...=1477440000000
notice IAM=0.2 and still getting over -3 degrees knock correction at high rpm shifts and high load, the knock kills the DI seals
turbocat (01-03-2017)
Old 01-04-2017, 12:20 PM   #544
MagicMexican
and
Thanks! I'll print those out and take them with me. I'll mention rough idle but idk how believable a/c would be since it's January and I'm in Colorado... but we'll see. I'm going back there this weekend. The dealer is unfortunately an hour and a half drive away.
Old 01-04-2017, 02:10 PM   #545
strat61caster
strat61caster's Avatar
Manufacturing date is on the sticker in the door jam, but I believe all 2012 build dates are at risk, it may have already been re-flashed though. I believe the change came out approximately in the Spring of 2013, May onwards to be safe.
Defrost uses air conditioning to dehumidify the interior, I bet you're using the A/C a lot actually given that it's winter and you're in a snowy climate.
ineedyourdiddly
Old 01-04-2017, 02:34 PM   #546
This^ My AC kicks in about three times as often when in defrost /heat mode than it does in actually cooling the car. It only runs for short bursts to dry the air opposed to longer periods required to actually cool it. This results in a much more frequent impact on the idle. First car I have had where you can't turn the function off when heating so it took some getting used to. Don't even notice it anymore.
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage
Search this Thread:
Advanced Search
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 07:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 01:35 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 07:54 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 09:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) -- General Topics 9 01-30-2012 01:25 PM
