| View Poll Results: Have you had an issue with your Direct Injection System? | |||
| I have had a DI issue and was fixed under warranty (Subaru) |
10 | 12.35% |
| I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) |
2 | 2.47% |
| I have had a DI issue and was fixed under warranty (Toyota) |
31 | 38.27% |
| I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) |
3 | 3.70% |
| I have had a DI issue and denied warranty by (Subaru) |
7 | 8.64% |
| I have had a DI issue and denied warranty by (Toyota) |
14 | 17.28% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) |
8 | 9.88% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) |
6 | 7.41% |
| Voters: 81. You may not vote on this poll | |||
#351 |
That makes sense now. I was reading as the tech put that in the notes, but looking at it again, it does read more like that was the last update applied.
Muaddib, did you have you car in for any updates/repairs since you bought it? |
#352 |
Mentat
Drives: 2013 Scion FRS 6MT
I went there a few times because i had some other unrelated problems. They never gave me any ecu update.
#353 | |
Drives: FR-S Whiteout
#354 |
Drives: FR-S 6MT
Do a search on this site.. There are threads and links to the software download and for the cable itself. Also info on how to install and use.
#355 |
USA Customers, take the following steps to receive the updated calibration that should address the DI seal issue:
Step 1: Remove your ECU Step 2: Place in your oven full Broil for 60 minutes, let cool Step 3: Reinstall ECU Step 4: Call your dealer to tow your car and install a new ECU. Thank you for this slight inconvenience.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
| The Following 3 Users Say Thank You to regal For This Useful Post: |
#356 | |
Drives: FR-S 6MT
Until they fix the system... That's probably what you would get. |
#357 | |
I Love custom Turbo kits
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | ATL BRZ (08-29-2013) |
#358 | |
Drives: Something fun.
#359 | |
Drives: FR-S 6MT
http://www.ft86club.com/forums/showthread.php?t=35530 |
| The Following User Says Thank You to Mikem53 For This Useful Post: | solidONE (08-29-2013) |
#360 | |
If they haven't built a car with the old ECU in 9 months odds are the old ones are out of their system. I may wait a little longer or I may just say F- it and toast the ECU
#361 |
Drives: GT86
You need help. And to think I got an infraction for doubting your abilities.
| The Following 2 Users Say Thank You to ft_sjo For This Useful Post: | CSG Mike (08-29-2013), Sportsguy83 (08-29-2013) |
#362 | |
Drives: FR-S 6MT
They might have a warehouse or two full of preprogrammed ECU's laying around with old programming ready to be matched up to a certain VIN number range.. It wouldn't surprise me... Good luck with your espionage.. I don't blame you for wanting it corrected.. It's ridiculous how screwed up something fairly simple can be when it comes to large corporations.. |
| The Following User Says Thank You to Mikem53 For This Useful Post: | AyJay (08-29-2013) |
#363 |
Reap the BReeZe
Drives: 04 LandShark STi
Was driving last night (14,943 miles), and stopped for gas. Left for the highway, and hit a CEL in 3rd. I hadn't reached the highway speed limit of 75mph yet. Took the next exit, and pulled a P0351.
Tonight, I was driving on a 2 lane 75mph road, stuck behind a car behind a pickup/trailer doing 55mph. Downshifted, and passed both only to get another CEL. Pulled the code, and grabbed the freeze frame data. Only mod to the car is painting the plastic cover on the intake manifold. Ran puregas since getting the car home to keep the crickets away. Local stations switched to E10 this summer, but been going to the station that squeaks least. Been reading through multiple threads tonight. Is this a sign my DI seals are gone? Fault log report generated by Torque for Android ================================================= Vehicle VIN: * Vehicle Manufacturer: Subaru Vehicle Calibration ID: ZA1J700C Current Fault Log ------------------ P0351: Ignition Coil "A" Primary/Secondary Circuit Pending Fault Log ------------------ ECU reports no pending faults Historic Fault Log ------------------ ECU reports no historic faults Other discovered fault codes (possibly pending, current or manufacturer specific) ---------------------------------------------------- ECU reports no other fault codes logged End of report. Freeze frame report generated by Torque for Android ================================================== ======= Vehicle VIN: * Vehicle Manufacturer: Subaru Vehicle Calibration ID: ZA1J700C Freeze frame information: ------------------ Fuel Status = 0 byte Engine Load = 0 % Engine Coolant Temperature = 88 °C Fuel Trim Bank 1 Short Term = 0 % Fuel Trim Bank 1 Long Term = 7.031 % Intake Manifold Pressure = 2.466 psi Engine RPM = 6,465.75 rpm Speed (OBD) = 150 km/h Timing Advance = 34 ° Intake Air Temperature = 32 °C Mass Air Flow Rate = 8.38 g/s Throttle Position(Manifold) = 17.255 % Fuel trim bank 1 sensor 2 = 0 % Run time since engine start = 725 s Fuel Rail Pressure = 2,043.582 psi Fuel Level (From Engine ECU) = 88.235 % Barometric pressure (from vehicle) = 13.924 psi Voltage (Control Module) = 14.126 V Engine Load(Absolute) = 6.667 % Commanded Equivalence Ratio(lambda) = 0.948 Relative Throttle Position = 5.49 % Ambient air temp = 31 °C Absolute Throttle Position B = 33.333 % Accelerator PedalPosition D = 13.333 % Accelerator PedalPosition E = 12.941 % End of report. |
#364 |
Drives: GT86
150 km/h is 93mph!
| Tags |
| direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 01:35 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 07:54 AM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 09:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) -- General Topics | 9 | 01-30-2012 01:25 PM |
