| View Poll Results: Have you had an issue with your Direct Injection System? | |||
| I have had a DI issue and was fixed under warranty (Subaru) |
10 | 12.35% |
| I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) |
2 | 2.47% |
| I have had a DI issue and was fixed under warranty (Toyota) |
31 | 38.27% |
| I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) |
3 | 3.70% |
| I have had a DI issue and denied warranty by (Subaru) |
7 | 8.64% |
| I have had a DI issue and denied warranty by (Toyota) |
14 | 17.28% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) |
8 | 9.88% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) |
6 | 7.41% |
| Voters: 81. You may not vote on this poll | |||
#323 |
Well I'm not giving up on these car's.
There is a reason that the calibration changed in the fall of 2012 to ZA1JA01C and no dealer in the USA is allowed to flash this update to cars built before then.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#324 |
Grip>Slip
Perhaps the reason is that admitting they changed the ECU mapping would essentially be admitting that there was a defect in the factory map.
#325 |
Or it could be as simple as dealers cannot link the calibration file to a TSB/bulletin and have no way to perform the update. If it is not in the system, they are not going to update you.
#326 |
And it is definitely time to stop listening to all the conspiracy theorists around here who have been telling people their engines will meltdown at 30K miles or less..
Egg, meet face..
| The Following User Says Thank You to thill For This Useful Post: | Mikem53 (08-28-2013) |
#327 | |
Drives: GT86
In North America.. there are three ECU's.. (for a given trim level) One from Mar-12 to Dec 12 Another from Jan-13 to Jun-13 And the current is from July-13 to date.. So take what you want from that, my bet would be that's for the 700, A00 and A01 cals accordingly... Some part numbers to CJ to.. SU003-00440 SU003-04593 SU003-04675 Have a nice day now @regal Thanks CheapToyotaParts for the info... |
| The Following User Says Thank You to ft_sjo For This Useful Post: | Sportsguy83 (08-28-2013) |
#328 |
Drives: FR-S 6MT
They can do a system check on the engine with techstream and it shows the engine calibration level. I did it using my VCI cable and techstream
#329 | |
Drives: FR-S 6MT
I have a feb 13 build with A01 calibration.. According to techstream results. |
#330 | ||
Our ECU, even after the emmissions update/recall/whatever is not "ZA1JA01C". It is ZA1JA00C (I know the last 4 digits are A00C).
Are you interested in doing an ECU swap with us if you have a newer ECU?
#331 | |
Drives: FR-S Whiteout
#332 |
Drives: FR-S 6MT
#333 |
#334 |
#335 |
Drives: FR-S 6MT
I bought a mini VCI cable and downloaded techstream from a link posted on this site. Techstream has a health check option for the engine.. And it displays the ECM calibration level ..
| The Following User Says Thank You to Mikem53 For This Useful Post: | ShoShin (08-28-2013) |
#336 | ||
@ft_sjo, why is there a month gap between computers? Any Idea? My car falls right in the middle of the December 12 and the January 13 (Mine was built January 4th) |
| Tags |
| direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 01:35 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 07:54 AM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 09:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) -- General Topics | 9 | 01-30-2012 01:25 PM |
