| View Poll Results: Have you had an issue with your Direct Injection System? | |||
| I have had a DI issue and was fixed under warranty (Subaru) |
10 | 12.35% |
| I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) |
2 | 2.47% |
| I have had a DI issue and was fixed under warranty (Toyota) |
31 | 38.27% |
| I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) |
3 | 3.70% |
| I have had a DI issue and denied warranty by (Subaru) |
7 | 8.64% |
| I have had a DI issue and denied warranty by (Toyota) |
14 | 17.28% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) |
8 | 9.88% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) |
6 | 7.41% |
| Voters: 81. You may not vote on this poll | |||
#295 | |
Drives: 22 GR86, 13 FR-S, AP2 S2000
Quoting myself from a different thread:
#296 | |
Drives: 2013 BRZ Ltd. MT
Yes, I know; thank you. Questions, actually … plural.
I was hoping for good answers. Comprehensive answers. I'm still waiting. But I'm not going to badger you if you choose to focus on evasion rather than explanation. Quote:
Shall we conclude that you are now asserting that any operation above 5200 rpm will produce damaging, uncontrolled detonation? Is there another rational interpretation, an alternative conclusion to be drawn from your statement? If not, then please account for EXACTLY why this is so. I do not accept this at face value, this 5200 rpm limitation to avoid catastrophe. I respect your experience, knowledge, skills, and abilities. I respect your intellect, Regal, but I cannot accept the above assertion at face value; it seems somewhat preposterous. I require supporting, DETAILED EXPLANATIONS, and a compelling argument if I am to be convinced. I am not saying you are wrong. I am saying that your so-called "arguments" have failed to convince. You are capable of much better … assuming that you have indeed thought this out carefully and are standing on solid ground. Convince me, please. I'm hoping to redirect your persistent complaints to an equally insistent determination to find SOLUTIONS. I know you are dissatisfied. You are not alone. Rather than continue to curse the darkness, let us light a candle, shall we?
#297 |
Drives: 86
what are the signs for this ?
#298 |
Drives: Subaru BRZ
I just got back from the dealer. I live in Dubai and have 35000 km on my car. It runs extremely bad after the engine is driven on for about 40 miles or so. They won't cover the warranty because I had the oil changed some where other than the dealer. What a crock of SH*T!!!! I will never buy another Subaru or Toyota again!!!!!! They want to charge me $3000.00 for 4 injectors and a fuel pump.!!!!
#299 | |
Grip>Slip
#301 |
#303 | |
Drives: tezla
maybe they should make an anonymous poll? doesnt seem like people are being too honest with what they did to the car before things like this happened... has anyone with a fully stock car, not tuned, non tracked, not "abused" having DI failure? |
#304 | |
| The Following User Says Thank You to suaveflooder For This Useful Post: | forwallblakmail (08-26-2013) |
#305 | |
#306 | |
Drives: tezla
#307 |
#308 |
| Tags |
| direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 01:35 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 07:54 AM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 09:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) -- General Topics | 9 | 01-30-2012 01:25 PM |
