| View Poll Results: Have you had an issue with your Direct Injection System? | |||
| I have had a DI issue and was fixed under warranty (Subaru) |
10 | 12.35% |
| I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) |
2 | 2.47% |
| I have had a DI issue and was fixed under warranty (Toyota) |
31 | 38.27% |
| I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) |
3 | 3.70% |
| I have had a DI issue and denied warranty by (Subaru) |
7 | 8.64% |
| I have had a DI issue and denied warranty by (Toyota) |
14 | 17.28% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) |
8 | 9.88% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) |
6 | 7.41% |
| Voters: 81. You may not vote on this poll | |||
#155 |
Jamesm, you should be able to guess that number, since you know the number of members on this forum.
Let's say 10% of all members have seen this thread, then less than 1% of all cars are affected by it (assuming all members who are affect by it have participated in this poll). |
#156 |
Drives: 2013 FRS Asphalt
I want to know if a single automatic has been affected. The shift points are different the stock tunes ran more rich up top compared to the stock mt tunes.
2013 Scion FR-S AT Picked up 5/30/2012
| The Following User Says Thank You to feldy For This Useful Post: | neutron256 (08-28-2013) |
#157 |
Track Junkie
Drives: Faster than the Stig!
Just got back from my euro trip, and got a full day at the nurburgring and a chance to talk to the Bjorn from http://www.rentracecar.de. Rentaracecar uses the toyobaru platform for some of their rentals. I asked Bjorn if they had had any trouble with the cars and he said two of the cars were at the shop for direct injection issues. He mentioned that all of the GT-86 rent cars had suffered this issue as well as spark plug related problems, he said they are anxious to get rid of them. Being this the case they only had two GT86's available and they were both rented, cant complain though i got to drive the Sirocco cup car and even though its FWD it was quite fast and fun. This confirmed my fear that even cars in cold weather are going to start to see this issue.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
| The Following User Says Thank You to track_warrior For This Useful Post: | Bristecom (07-07-2013) |
#158 | |
Drives: Moped
#159 | |
This post should be at the front page of this forum. It is a direct indicator of what all of us will be facing as we pass warranty.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#160 |
Super news, what were the issues with spark plugs, obviously just melting down?
#161 |
Drives: Whiteout FRS
I wonder when Toyota and Subaru are going to address this problem. Can someone take note of this and get this issue published on a major website such as Autoblog and Jalopnik?
#162 |
sub'd....interesting to see how this turns out. Judging by the poll, it doesn't sound very common and there are A LOT of people tracking these cars.
#163 |
Drives: 2017 Fiesta ST
Well, Rent a Racecar cars suffer from a lot of abuse in the first place:
[ame]http://youtu.be/BMzTpsKua-I[/ame] |
#164 | |||
Every car failed. Its an ideal accelerated wear test. All this means is if you drive spirited it will affect you eventually, how many miles is the only question. With engines seizing from this I don't blame that rental company from dropping the twins, that is a serious safety hazard not only on the track but on the street.
#165 |
blowhard
Drives: frs, project forester
so, in summary
should i add mechanical break down coverage from insurance company for <$10 a month, stop worrying and beat the car silly? |
#166 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
#167 |
86 Member
I would think if your car is stock and under warranty you shouldn't worry but after the warranty time expires you should jump on that coverage. I need to check if my insurance has the same thing.
#168 | |
Isn't that sort of coverage only good if your engine completely breaks down? If you are astute to your engine making odd noises and bring it in they will probably just call this normal wear and tear? One scenario is enough people complain and they fix this issue by the 2015 MY and those of us who drive "aggressively" will throw a rod and get a good engine before the 5 years is up. Definitely document oil changes and pay for the 30k mile service racket Better would be to find a tuner to develop a conservative 99.999% detonation free tune, not just modify the transient retard table but really dive deep into preventing detonation to the point that the knock correction index is not a factor. I think Toyotas hands are tied with emission promises, I'm looking at investing in BRZ-edit and fix the transient ignition, make closed loop as minimal as possible, find the right spots to pull timing and add fuel. But need fresh O-rings first. Shouldn't be that difficult. If someone figures it out hopefully it will be shared with the community.
| Tags |
| direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 01:35 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 07:54 AM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 09:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) -- General Topics | 9 | 01-30-2012 01:25 PM |
