Old 08-15-2013, 03:36 PM   #43
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Wylie1 View Post
Yes, the temperature gauge is a POS. Whether or not anyone complains to the dealer will determine whether or not the worthless thing is ever fixed. If you should complain be sure to mention the RIDICULOUS cig lighter/12 volt port locations as well. And don't get me started on the window gaskets!) Thank the Lord I can plug in a USB cable conveniently...which I may never do...and which despite what they told me at the dealership does not seem to charge phones, etc. like they said it would. How some of this convenience feature engineering ever got out of the design department I will NEVER know. Too busy making a fun as S car to drive I guess.
CSB. My Galaxy S4 gets charged just fine from the USB plug, and the temp sensor is accurate enough.
Old 08-15-2013, 03:45 PM   #44
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
I always find that mine is off by the following formula:
(((Indicated Temp*2)*0.90)+32)
What should I do?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
wparsons (06-17-2014)
Old 08-24-2013, 05:26 AM   #45
The_Societan
The_Societan's Avatar
Drives: Firestorm FR-S
Mine isn't terribly accurate either, so I don't pay attention to it. I can see the concern with winter driving/freezing point, etc. I tend to drive cautiously if there's any reason to believe I might encounter an ice patch, so I doubt the reading on the dash will affect my driving habits.
The_Societan is offline   Reply With Quote
Old 08-24-2013, 08:14 AM   #46
Porsche
Drives: 2013 BRZ Ltd. MT
What should I do?
Switch your speedometer over to kilometers per hour, of course.
And learn a foreign language, perhaps?
Porsche is offline   Reply With Quote
The Following User Says Thank You to Porsche For This Useful Post:
Old 08-24-2013, 07:45 PM   #47
tennisfreak
Drives: 2018 BMW M240i
my temp gauge is always 5+ degrees off. There has to be some way of calibrating it.
Old 08-24-2013, 09:22 PM   #48
MY13FRS
***** Super Senior Member
MY13FRS's Avatar
Drives: 13 FRS
Originally Posted by WolfpackS2k View Post
I'm comparing it to my experiences with my last car, S2000.
hmm....you shouldn't compare a high end car to a budget economy car like the twins.
You are right, my S2000 is more accurate than my FRS. It should only take several minutes for the feature to accurately display the outside temp.
MY13FRS is offline   Reply With Quote
Old 08-28-2013, 06:45 PM   #49
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
This is as unexplainable as the thermometer on my Suunto watch telling me it's always 89 degrees
The only thing that bothers me is the inability to adjust the temperature and MPG calculation. I can do it on my '11 Outback easily, and it gets perfect temp/MPG readings (at least once it's been driving for 10-15 minutes). I could adjust it on my '03 330Ci as well. I hope there's an easter egg adjustment menu someone hasn't found yet.
Aside from that I leave the temp gauge off and have it on MPG or ODO. I have my S4 to tell me the weather.
DoomsdayJesus is offline   Reply With Quote
Old 06-17-2014, 05:52 PM   #50
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
The outside temperature display in the gauge cluster stopped working entirely. It displays the *F units, but no numbers. Connecting Torque to my car, it shows the outside temperature and is accurate within reason. Anyone else have this issue? I'm at 34k miles, and am going to be bringing it in to the dealership soon for warranty.
JDKane527 is offline   Reply With Quote
Old 06-17-2014, 06:12 PM   #51
wheelhaus
wheelhaus's Avatar
Thread resurrection... Almost one year old!
Maybe check the sensor itself if you can find it. It's possible the ECU gets it's temp reading from the intake air temp sensor or somewhere else, which may be what the Torque software may be displaying... The dash gauge likely only uses the simple ambient sensor.
wheelhaus is offline   Reply With Quote
Old 06-17-2014, 06:42 PM   #52
DJCarbine
Thupercharged
DJCarbine's Avatar
What difference does it make? It's a feature on the car that doesn't work properly.
Thus I don't see the harm in posting on here to see if it's a common occurrence or not. You'll have to excuse me for wanting everything on my brand new car to function properly.
What other temperature reading are you comparing the vehicle sensor to?
Temperatures outside can vary due to gusts of wind, sun exposure, etc.... its hard to get super accurate readings using a single temperature probe.
If you find its always off by a certain amount, looking up the sensor information and find out of if its a simple thermistor and what the voltage/temperature scale is, then clever application of a resistor may bring the results more in line with what you deem accurate.
I find that mine is accurate within reason, as in a rough estimate of the outside condition.
You could probably pull the sensor off, take it to a climate controlled room, check resistance and compare it to what it should be reading at a certain temperature. This information might even be in the shop manual, I've had good shop manuals that let you bench test most sensors on a car if they are able to be bench tested
2013 FRS
Vortech V3 11psi
Old 06-17-2014, 06:51 PM   #53
wparsons
wparsons's Avatar
I can't believe for all the complaining in here, not one person checked tech stream to see that it is an option that can be EASILY set.
It's just a compensation, so if it's always reading 5* too hot, put in -5 for the compensation.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
evan (06-17-2014)
Old 06-17-2014, 06:57 PM   #54
DJCarbine
Thupercharged
DJCarbine's Avatar
Forgot all about techstream, my previous BMW let you add compensations for the MPG gauge, outside temp, etc.
Sometimes the most simple solution is overlooked
2013 FRS
Vortech V3 11psi
Old 06-17-2014, 07:05 PM   #55
JDKane527
JDKane527's Avatar
Anyone have any idea then where the sensor is located? I'm hoping its not on the dash...in which replacing the sensor would mean ripping out the dash. The only issue I'm having is the ambient air temp sensor. The ambient air temp reading on Torque is within a few degrees of the local weather I check online. The gauge cluster just doesn't seem to be getting any of that info from the ECU though.
Old 06-17-2014, 07:37 PM   #56
andrew20195
Drives: 2013 Subaru BRZ
Sounds like you have a LAN/CAN problem. If the sensor is reporting to the ECM correctly, it's not a faulty sensor.
andrew20195 is offline   Reply With Quote
Search this Thread:
Advanced Search
Fuel Gauge is Inaccurate Surakusa Issues | Warranty | Recalls / TSB 13 09-02-2017 11:26 PM
Southeast Toyota FR-S recall for inaccurate load carrying capacity labeling Dadhawk Issues | Warranty | Recalls / TSB 6 04-24-2013 12:19 PM
FS: AEM 30-4402 Oil/Transmission/Water Temperature Digital Display Gauge. Sportsguy83 Engine, Exhaust, Bolt-Ons 4 03-25-2013 11:37 AM
BRZ temperature display malfunction percyng CANADA 7 10-24-2012 10:31 PM
Optional Rear View with Homelink....does it display indoor temperature? Fugazi BRZ First-Gen (2012+) -- General Topics 1 06-30-2012 09:15 PM
