Old 01-13-2016, 10:35 PM   #29
swarb
Originally Posted by HaloFRS View Post
Did you figure it out? Im planning to get these but not sure what lug pattern to choose. 5x100 or 114
Thanks!
Our cars are 5x100. Why would you even consider 114?
The Following User Says Thank You to swarb For This Useful Post:
HaloFRS (01-14-2016)
Old 01-14-2016, 12:42 PM   #30
HaloFRS
Drives: 2020 Subaru BRZ Limited
I wasn't sure what the bolt pattern is lol. Thanks!
HaloFRS is offline   Reply With Quote
Old 01-14-2016, 01:09 PM   #31
EzyBrzy
Drives: 2015 WRB BRZ
These look good but too much poke.
EzyBrzy is offline   Reply With Quote
Old 01-19-2016, 10:18 PM   #32
kdmxdgt
Drives: 2014 WR Blue BRZ Lmtd
Thanks!
i only had a problem with the lugs/key. the bore is pretty small for the lug holes so make sure you can return your lugs if you get locking ones and the key doesnt fit.
kdmxdgt is offline   Reply With Quote
Old 12-05-2016, 10:57 AM   #33
The86Minister
Drives: 2019 Camry Hybrid
Had these for a short while on my GT86 (Hot lava, stock suspension), might as well post some iPhone pics here. Sold them due to massive poke in the front (risk of rubbing/police issues), very good looking wheels tho. Next wheel setup will definitely be another 5-spoke with deep lip, just a little more flush setup. Sold these to a guy with a WRX.
Tires are Goodyear EfficientGrip Performance 225/40-18.
The86Minister is offline   Reply With Quote
Old 06-21-2017, 09:56 AM   #34
Squanto
I've had these wheels on for almost two years. If you are not lowered it will look funny as they are a aggressive offset. But once your car is lowered and you find that perfect tire size, the fitment is perfect with only a small amount of poke.
Squanto is offline   Reply With Quote
Old 10-05-2017, 04:42 AM   #35
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
If I were to have coil-overs installed, could I run wider tires with these wheels? 245/40/18
rookietopro_frs is offline   Reply With Quote
Old 11-17-2017, 06:54 AM   #36
rookietopro_frs
Brilliant! Front needs some negative camber like me but it looks pretty mean!
I just glad it looks good with stock suspension, thinking about getting the same wheels.
Old 04-26-2018, 11:43 AM   #37
Pinoy_FRS
Drives: Ultramarine
Anyone know how these will fit with a 245 tire all around on stock suspension?
Pinoy_FRS is offline   Reply With Quote
Old 07-20-2018, 10:14 PM   #38
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Hello friends, I have a contribution.
MCTeeJ is offline   Reply With Quote
Wheel Directory: XXR 527 18x9.75 +20 4Running Daily Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 02-06-2017 12:55 AM
Wheel Directory: STR 603 18x9.0 +40 malubawla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-06-2015 02:05 PM
Wheel Directory: Cosmis Racing Wheels 18x8.5 +22 BugeyedWagon Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 03-06-2015 08:15 PM
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 05:09 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 04:15 AM
