Old 03-31-2014, 09:21 PM   #15
sirwiggles
sirwiggles's Avatar
Drives: 2014 FR-S
Cosmis XT-005R, Hankook 225/40 18
sirwiggles is offline   Reply With Quote
The Following 2 Users Say Thank You to sirwiggles For This Useful Post:
DarrenDriven (04-01-2014), Thekaylakrunkk (09-05-2014)
Old 04-21-2014, 07:42 PM   #16
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
soon ill have coils and my white cosmis wheels on
Kosmos is offline   Reply With Quote
Old 05-01-2014, 10:47 PM   #17
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Size:  103.2 KBName:  uploadfromtaptalk1398995253778.jpg
Sent from my SM-N900P using Tapatalk
The Following 2 Users Say Thank You to Kosmos For This Useful Post:
sirwiggles (03-25-2015), Thekaylakrunkk (09-05-2014)
Old 06-29-2014, 01:43 AM   #18
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
I've been thinking about these wheels. Can anyone give some thoughts/review on them?
Fitment issues, how they're holding up, etc.
Thanks guys
Edit: and any more pictures if possible
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 06-29-2014, 11:27 AM   #19
Thekaylakrunkk
XE Autosport
Thekaylakrunkk's Avatar
Drives: 2013 Scion FRS Whiteout
Thanks guys
Mine are amazing! Holding up perfectly. I'm on coilovers and have like 2-3 degrees camber for perfect fit. Theyll fit w no camber but you'll poke. I'm thrilled w my choice on wheels.
Thekaylakrunkk is offline   Reply With Quote
The Following 2 Users Say Thank You to Thekaylakrunkk For This Useful Post:
BRZ21 (06-30-2014), sirwiggles (09-05-2014)
Old 06-30-2014, 02:48 PM   #20
BRZ21
i kill cones.
BRZ21's Avatar
Thanks
I saw a little while ago you wanted to sell them right? You changed your mind?
Old 06-30-2014, 02:49 PM   #21
Thekaylakrunkk
XE Autosport
Thanks
Yeah I was going to. But after my coilovers and alignment I've decided to keep them. They fit the way I want them to now lol
The Following User Says Thank You to Thekaylakrunkk For This Useful Post:
BRZ21 (06-30-2014)
Old 06-30-2014, 04:12 PM   #22
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Thanks guys
- They have a ton of poke (not lowered). They are heavy as well.
+ They look amazing fit perfectly when you are on coils and go low.
I have 18x9 +25
And lowered it 3 inches and an alignment
Spc ez cam camber bolts
Maxed out negative camber for the fronts
Size:  52.4 KBName:  uploadfromtaptalk1404155542574.jpg
BRZ21 (07-01-2014), SlammedSilly (12-04-2015)
Old 06-30-2014, 04:13 PM   #23
Thekaylakrunkk
XE Autosport
Mine isn't cambered nearly that much.
Old 07-01-2014, 12:05 AM   #24
BRZ21
i kill cones.
BRZ21's Avatar
I have 18x9 +25
Attachment 83693Attachment 83694
Thanks
I'm not planning on having nearly as much camber cause I have to use oem crash bolts to stay in my autocross class.
Hopefully ~2°
Old 07-01-2014, 01:18 AM   #25
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
I have -2 in the fronts. And -3 in the rears
Old 01-16-2015, 05:18 PM   #26
kdmxdgt
Drives: 2014 WR Blue BRZ Lmtd
Just got these installed today. Bronze on WRB wrapped in bfg sport comp 2 225/40/18
Showing how deep the lip is. It's actually flat for only about an inch then angles in.
How it looks on the shaded side
kdmxdgt is offline   Reply With Quote
The Following User Says Thank You to kdmxdgt For This Useful Post:
rookietopro_frs (10-05-2017)
Old 02-10-2015, 12:44 AM   #27
kdmxdgt
what type of lugs/locks did everyone else use? i tried to install varrstoen v48 lugs and locks but the socket would not fit inside the bore for the lugs. i had to have generic lugs installed in the style of a standard muteki lug.
thanks
Old 01-13-2016, 10:30 PM   #28
HaloFRS
Drives: 2020 Subaru BRZ Limited
thanks
Did you figure it out? Im planning to get these but not sure what lug pattern to choose. 5x100 or 114
Thanks!
HaloFRS is offline   Reply With Quote
Wheel Directory: XXR 527 18x9.75 +20 4Running Daily Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 02-06-2017 12:55 AM
Wheel Directory: STR 603 18x9.0 +40 malubawla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-06-2015 02:05 PM
Wheel Directory: Cosmis Racing Wheels 18x8.5 +22 BugeyedWagon Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 03-06-2015 08:15 PM
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 05:09 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 04:15 AM
