86WORX
Old 06-17-2013, 07:50 PM   #519
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I know the Celica GTS does not let vvtl-i engage till oil temp is up.
clayrush is offline   Reply With Quote
Old 06-17-2013, 09:17 PM   #520
strat61caster
strat61caster's Avatar
Originally Posted by ft_sjo View Post
Mazda 3.
Ford Focus ST.
Volvo something.
It's usually to protect the transmission.
Thanks for providing examples.
FYI for anyone who doesn't want to google here's what I found:
[ame="http://en.wikipedia.org/wiki/Mazdaspeed3"]Mazdaspeed3 - Wikipedia, the free encyclopedia[/ame] (no citation though)
https://www.accessecu.com/support/do...scriptions.pdf (p. 48, references a table that limits the amount of torque the crankshaft puts out)
(couldn't find anything solid on the Volvo)
It seems like both those vehicles limit the boost available depending on the gear being used for various reasons, be it torque steer, fuel economy or to "protect the transmission".
Thanks, :happy0180:
ineedyourdiddly
Old 06-17-2013, 10:55 PM   #521
sierra
Drives: Skoda Yeti DSG diesel 4x4
I've NEVER heard of that (ECU "reducing power" for lower gears) outside of vehicles with very specialized motors/purposes (trucks or racing maybe?), would love to see evidence of that in commercial passenger vehicles, would be interesting.
I remember reading it from one of the Ecutek tuners, that they remove the power limits placed on 1st and 2nd gears.
sierra is offline   Reply With Quote
Old 06-18-2013, 12:51 AM   #522
dsgerbc
Drives: BRZ(sold), STI
Source?
I'm not saying it doesn't happen, I'd just love to see some evidence aside from "trust me".
Subaru does it with WRX/STI/LGT. Go to romraider and search 'per-gear timing'. This one killed a lot of motors on the track until tuning community realized that per-gear adjustment was there.
dsgerbc is offline   Reply With Quote
The Following User Says Thank You to dsgerbc For This Useful Post:
strat61caster (06-18-2013)
Old 06-27-2013, 10:17 AM   #523
Mikem53
Drives: FR-S 6MT
Really.. It's very common.. It's called torque management. My V6 accord had it as well as my vettes. Especially with automatics.. It's very obvious to detect in an auto V6 accord. Between the torque steer and all the tranny failures.. They have to do it. My vette was a manual, but they still had some tq management in the lower gears. The auto vettes got a much more noticeable dose of tq management. Many had it tuned out.. But not all of it.. They also pull timing during shifts on the autos to reduce shock.
Mikem53 is offline   Reply With Quote
Old 06-27-2013, 10:22 AM   #524
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Originally Posted by Sithspawn View Post
A quick heads up for everybody. This car has issues with detonation with the factory tune. I'm not talking about crappy Cali gas, but the ECU calibration guys at Subaru screwed up here.
This failed engine is a direct result of cascading failures due to a bad tune. Detonation is not normal and anyone who says so, ought to be doing something else for a living.
Detonation over time will damage engine internals. This is a given. The first component to fail on this engine with the detonating tune is the nylon collar on the direct injector tip. When that insulator cracks and breaks off due to detonation, there is nothing left to protect the injector seal from combustion gasses and the seal fails as a result. Then, the failed seal leaks, causing more detonation and misfires until the engine throws in the towel (or a rod).
This car detonates on the 2-3, 3-4, 4-5, 5-6 shifts when driving the car hard. By hard, I mean WOT and shifting with speed and authority. I have attached a log that shows detonation happening at exactly the shift points (you can see the engine speed rising to redline and the shifts). On the 2-3 and 3-4 shifts I logged, there was detonation resulting from too much timing advance which can also be seen in the log. Keep in mind that this is the factory tune and all I did was log what it does.
I have also attached a view of the factory Transient Ignition Retard Table that shows that it is not pulling jack for timing in the high rpm range. It does pull timing at low rpm and low load, but keeps the timing too far advanced up top. This is due to the fact that the base timing map is advanced a lot in the low load range at high rpm (which the engine sees when you close the throttle for your shift).
Apparently, there is a new flash from Toyota that fixes the tune...sadly, the tune is what ultimately caused the engine failures here people. Subaru needs to step up and fix their mistake.
In closing, while not everyone drives their FRS/BRZ like a madman, driving this car hard will eventually kill the engine with the stock tune. Tracking the car only accelerates the inevitable death of the engine since you are shifting like this much more often.
Not being a tuner myself should knock correction always read 0? when reading the ecutek logs does - 1 or more indicate knock/detionation? or what knock correction lean value means?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-27-2013, 10:44 AM   #525
#87
I usually post drunk
#87's Avatar
Any updates from @CSG Mike
#87 is offline   Reply With Quote
Old 06-27-2013, 12:20 PM   #526
Not yet... other than a lot of downtime.
Old 07-01-2013, 06:26 AM   #527
regal
Does this sound like a rattle above pulling above 4k rpm ? My idle and low rpm are fine. But a hard pull past 4krpm and I get a rattle coming from the cowling on the mid passenger side. It sounds like something loose rattling. The only thing remotely loose on the engine is the sound tube, but it looks designed to not be held tight.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-02-2013, 03:08 PM   #528
Dezoris
Dezoris's Avatar
There is a 45 day lead time to get any parts related to the DI system. I complained about this 7 months ago and just blamed it on the new model. But after a year of production, we still don't have anything in our local depots in the States is piss poor.
Literally if you have any issues with this car, its going to be out of service for at least a month.
I expected this shit when I owned a Lotus, but not from a major OEM.
The Following User Says Thank You to Dezoris For This Useful Post:
bestwheelbase (07-07-2013)
Old 07-02-2013, 03:44 PM   #529
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Ditto. I owned an Exige and the lead time for parts was less. Sad.
spitz is offline   Reply With Quote
Old 07-02-2013, 03:50 PM   #530
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Wow that sucks! I feel you man. I had to lemon law a E46 M3 for 2 engine failures and the tranny blowing up, a M Roadster with motor issues and a Z4 Roadster for engine work three times in 8 months. They replaced the entire head before month 3 of ownership and then had to do it again at month 5. Then the entire motor at month 8. One thing though, BMW was pretty good about it all and never really tried to put one over on me. I got more than fair value for all my cars and got to drive most of their fleet for months, including a 750i, 640i, M5, M3 and various BMW's for months.
Good luck and hope you get this fixed ASAP!
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 07-02-2013, 03:51 PM   #531
Dezoris
Dezoris's Avatar
You could pay to expedite parts so they could be at the dealer from the UK in 4 days if you needed them. Otherwise it was 2-3 weeks normally. And at least you knew how long the wait was.
With this car its, zero answers, just wait. S2000 and RX8 were bad too but not this bad.
Old 07-02-2013, 05:43 PM   #532
clayrush
I had synchro problems fixed under warranty for my 2000 Celica gts in 03 it took them more than 45 days to get the parts. Part of the delay is that they sent the parts by boat and they said they had no way of expediting the shipment. I am just glad they gave me a rental car.
Search this Thread:
Advanced Search
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 09:55 PM
Denied service... Chen Northwest 37 09-13-2013 09:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 12:17 PM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 09:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-08-2012 12:57 AM
