#463 | |
Also, try to refrain from using political stuff in your posts, even if only reference. |
| The Following 5 Users Say Thank You to 2forme For This Useful Post: | ATL BRZ (06-07-2013), Marchy (06-07-2013), Sportsguy83 (06-07-2013), strat61caster (06-07-2013), xjohnx (06-07-2013) |
#464 |
Drives: FR-S 6MT
On "a" car is hardly evidence or proof that an epidemic exists. I was making a small joke with the dem comment.. Sorry to offend.
#465 | |
Considering we've seen 2-3 tracked cars with the issue and I've seen 1 non tracked car with the issue, that would infer a 25-33% part of the effected populace, in our extremely tiny sample. |
#466 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | GTM_Challenge (06-07-2013) |
#467 | |
Drives: 2013 SWP BRZ
Mike, maybe it's that crap Motul 300V you're putting in there?
#468 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#469 | ||
Those engines don't have a DI injector in the combustion chamber, just a spark plug and no polymer "seal" required for the DI. The thing is detonation is more likely as ECT & OCT climb. The issue we are having with detonation and thrown rods happened in the late sixties with high compression V8's when spark plugs were not as well made as now and not as heat resistant, they would crack breaking the seal and the engine would blow. Its a fairly analogous failure mode. The concern is D4-S was supposedly "mature" having been used by Lexus for a few years. This is why I am so surprised that the experts here are overlooking the huge difference in a Subaru boxer head vs. the previous application of D4-S. A simple mistake in leaving too much timing after throttle lift at high rpm's just seems infallible to me with the D4-S maturity. I mean Toyota did have Mike's first engine for several months without releasing an updated flash, actually there is no evidence that they have as of today domestically. Below 6000 rpm this engine has very little HP. The only way to get the power out of this little beast is to rev it and keep it revving between shifts, without that its literally a 125 HP car. So extensive validation work should have been done driving in this matter. How could this have been missed? It couldn't have. Along with Mike's complete denial of warranty after Toyota claiming his first engine this is a very serious issue. I hope those plots posted showing elimination of knock with proper timing management is the root cause but think its fair to ask what the ECT & OCT readings were with these given the strong correlation between knock, OCT, and ECT.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#470 |
Drives: GT86
Jesus, shut up.
The det occurs when you go back on the throttle after a shift. It's because the ecu is temporarily using the wrong spark angle due to latency in the system. This is what the transient tables are supposed to handle. The transient retard during shift tables were disabled above 5200 rpm. The new cal fixes this. Was it a fuck up by Subaru? Possibly. Likely, no. But a fix exists so the effect of the old cal is obviously worse than whatever they were trying to achieve by restricting the function of the transient spark table. Calibration engineers at OEM's know exactly what they're doing. Every value in every cal is there for a reason. |
| The Following 4 Users Say Thank You to ft_sjo For This Useful Post: |
#471 |
Drives: 2013 FR-S Hot Lava
Do they?
Live to drive another day
#472 |
Driving Coach
| The Following User Says Thank You to ATL BRZ For This Useful Post: | SkullWorks (06-07-2013) |
#473 | |
#474 | |
Drives: SSM LT MT BRZ
Firstly, you seem to miss over and over that there are 2 companies involved each of which is apparently handling the issuance of TSB's at their own rate and with their own process, so atleast try to keep the manufacturer right so we can have some faith that you are paying attention since you have been asked nicely several times to pay attention and keep the nonsense down. Second, I'm not sure how many cars have had D4s and manual transmissions...that makes a huge difference, the OEM's knw exactly how fast the Auto trans will shift EVERYTIME, so it is much easier to plan spark timing strategies as they relate to gear changes. Third, Do you understand how many tables relating to spark retard are in a modern ECU's programming? The ECU looks at Oil Temp Ambient Temp IAT's Coolant temp, and short and long term Ign trim (at the very least) beore issuing a spark timing command....it's not like there isn't a knock sensor aswell to pull timing if all of the maps still don't provide enough timing retard with elevated temps, you aren't the first person to realize that increased temps lead to preignition |
| The Following User Says Thank You to SkullWorks For This Useful Post: | ATL BRZ (06-07-2013) |
#475 | |
That's the funny part about the real world, people think oh hey look i drew it now it's my idea, I want some free ones.... Provide a fully tolleranced drawing, specify all GD&T, tell me what material you need it made out of and in what temper and what plating process, how much build up and to what spec, the design the tooling to make it, plate it, grind it after plate (yes the tollerances will need to be that tight), then cut me a check for ~8k to make you a prototype, then and only then if your design works...you can sell it. Ideas are like pollen, they are everywhere but it takes an incredible amount of other input to even verify if the idea was worth having. besides, having the rings nest, and split causes more problems that it would solve, additionally the materials and plating you mentioned are not desirable for the application, and they would peel all the plating off upon installation, and gouge the head on install... |
| The Following 2 Users Say Thank You to SkullWorks For This Useful Post: | P@ul (06-11-2013), strat61caster (06-07-2013) |
#476 | |
Drives: Scion FRS
| The Following 4 Users Say Thank You to markitect For This Useful Post: |
| We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 94 | 09-15-2013 09:55 PM |
| Denied service... | Chen | Northwest | 37 | 09-13-2013 09:37 PM |
| HELP with diminished value claim! | zohare | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 04-03-2013 12:17 PM |
| Hit and Run Insurance Claim | CharlieChaos | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 12-26-2012 09:54 PM |
| Japan loses its claim to "Creepiest Asian Country" | reni | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 05-08-2012 12:57 AM |
