#295 |
Drives: FRS
Why the hell don't we have this re flash in the USA? Seriously.
I am thinking we should all call our manufacturers tomorrow and let them know we are aware of the issue and want to know why we are not being given the most recent ecu update. Who is with me? |
#296 |
Drives: whiteout
can someone else pull the same data as sithspawn who has already had the ECU TSB performed? that would put a lot our minds at rest that our cars are not detonating whenever we accelerate hard > <
#297 |
Drives: 2013 scion frs whiteout
What does "detonating" sound like?i can hear my engine breaking up nearhigh revs. Is that it? Im at 3500 on the dash but i drive it hard.
#298 | |
Drives: GT86
It's worth noting though, transient det is usually in low load condition and is not typically considered problematic (a lot of older MAP sensor based cars use to suffer from it), but on this direct injection engine it's obviously an issue. |
#299 |
Dang im trying to figure out what this noise is.
#300 |
Drives: Slow
Assuming this is the source of the problem indeed, I would not be happy with just a new tune to correct the problem. I would want new injectors as well because they could be damaged from all the driving done with the bad tune.
| The Following User Says Thank You to civdaddy For This Useful Post: | ATL BRZ (06-03-2013) |
#301 |
#302 |
Drives: FRS
Sent an email to Toyota and Scion regarding this issue. Linked all the threads on this topic in the body of the email. We'll see what comes back.
To to OP: I would bring them the TSB regarding the issue if you have not already. The issue is known by the manufacturer as other markets have been given the fix for it. I would consider using the TSB to your advantage here. At least to get more of a break down so they can see it was an injector issue. |
#303 |
Drives: '14 Hot Lava FR-S w/Flappy Paddles
FYI, I just edited my Transient table, flashed the ECU and did a log. Bye bye detonation.
#304 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
wouldn't be cool if you could take you subie to a Toyota dealer. They fix your car then they bill Subaru.
#305 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
Why would the detonation occur when you lift off the throttle to shift? Normally detonation occurs at WOT when the mixture leans out due to more air flow than fuel. I would think at lift you would get a surge of residual fuel as the air flow is being shut off.
Yes, I am aware that other factors such as heat can also cause detonation. I am just looking for a confirmation as to why it is happening like you say it is.
So many modders have more cents than sense!
#306 | |
Drives: GT-86
.i have noticed i am not getting close to the fuel mileage u guys are getting i'm wondering if its because of the fuel? |
| The Following User Says Thank You to acro For This Useful Post: | civdaddy (06-03-2013) |
#307 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
You can see the ignition advance spike up and back down, that's where his foot is off the throttle. The detonation spike appears to be just slightly after that. This is why I say it's happening on the throttle opening right after the shift. |
#308 | |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | Clipdat (06-03-2013) |
| We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 94 | 09-15-2013 09:55 PM |
| Denied service... | Chen | Northwest | 37 | 09-13-2013 09:37 PM |
| HELP with diminished value claim! | zohare | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 04-03-2013 12:17 PM |
| Hit and Run Insurance Claim | CharlieChaos | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 12-26-2012 09:54 PM |
| Japan loses its claim to "Creepiest Asian Country" | reni | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 05-08-2012 12:57 AM |
