Old 06-05-2013, 10:55 PM   #29
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I think I'm going to end up getting these.
http://www.tirerack.com/tires/tires....omCompare1=yes
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 06-06-2013, 02:55 AM   #30
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Honda challange guys have been running on 7inch rims. They run anything from a235/40-245/40. We currently run a 235/40/17 R1R on the stock rim. It's a touch smaller then stock and we have no problems.
DAMotorsports is offline   Reply With Quote
Old 06-11-2013, 03:02 AM   #31
l8apxes
Drives: 2013 BRZ Premium
Tirerack is showing a 215/45 F 255/40R stagger option for stock wheels. Anybody have any experience in that combo?
l8apxes is offline   Reply With Quote
Old 04-29-2014, 08:52 PM   #32
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
Bumping this?
Brahsbrah is offline   Reply With Quote
Old 04-29-2014, 10:47 PM   #33
FRSWiLLY
Drives: 2013 Asphalt
Just got Michelin Pilot SS 225/45/17.....in love, super smooth, extra grippy!
FRSWiLLY is offline   Reply With Quote
Old 05-17-2015, 08:11 PM   #34
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
Do you happen to have a picture of them on the stocks?
jimmillion is offline   Reply With Quote
Old 05-18-2015, 01:55 PM   #35
WNDSRFR
Drives: FR-S,GTI
I've always run 235/45/17 on the FR-S and my VW (has the same size rims). Been using them on the VW for over 10 years. I don't like the "look" of the stock size. It just doesn't look right to me.
Actually as soon as I got the FR-S I swapped tires with the VW. It has the stock Scion tires on it now. And it looks really wrong. They'll probably be the last tires it ever sees because I pretty much don't drive it anymore. The FR-S is much more fun to drive.
Old 05-18-2015, 09:32 PM   #36
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I'm running 225/50 on 16x7 with zero issues, including autocross. Car has better feedback than the OEM setup, and I don't need to run crazy pressures get good feel. 7" is perfectly fine for a 225, unless you just like the extra weight.
venturaII is offline   Reply With Quote
Old 05-18-2015, 10:22 PM   #37
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Every manufacturer specs out acceptable wheel sizes for each of their tires and sizes. Some 225 width tires will fit. Others will not. It's dangerous to run tires out of their specs, unless you're just hard parking.
Old 10-16-2015, 05:00 PM   #38
Lorico
Drives: 2015 FRS
I installed 225 55 17. And they were rubbing. The. I went down to 225 50 17. No rub at all turning all the way and it's much more comfy as well
Lorico is offline   Reply With Quote
The Following 2 Users Say Thank You to Lorico For This Useful Post:
N234 (11-18-2019), Spankopotomous (04-14-2021)
Old 10-22-2015, 01:25 AM   #39
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
This thread let me know that I can order my PSS tires in 225/45/17. Thanks a bunch, heading to Costco's website.
jeepmor is offline   Reply With Quote
Old 12-17-2015, 07:08 PM   #40
Teseo
Drives: frs
Bump
I will buy tires soon, will stock rims can hold 225? Or can go more width without rubbing issues?
Old 12-17-2015, 10:14 PM   #41
Asidrive
I autocrossed last year on 245 RS3's on the stock wheels at the oem ride height. Never felt unsafe but had some sidewall flex. Had the first tire shop refuse to install them and basically had to beg the second shop to do the install.
Asidrive is offline   Reply With Quote
Old 12-17-2015, 11:01 PM   #42
SHWNBRZ
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
Originally Posted by Teseo View Post
Bump
stock wheels and stock everything else...225/45/17 will work fine.
If you're going for the most amount of contact patch...look into Yokohama AD08's. PSS's are pretty good...but if you live where there's light snow/cold-near freezing temps...look into the AS3's.
SHWNBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to SHWNBRZ For This Useful Post:
soulreapersteve (12-18-2015), Teseo (12-17-2015)
Best Tire Size for Stock Rims djliquidsteele Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 58 09-03-2017 03:10 AM
optimal tire size for stock wheels brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 12-05-2015 01:01 PM
Maintaining stock tire size what to upgrade to... tuckdaddy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-03-2013 12:28 PM
largest tire for 19x8.5 et45 garfull Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-25-2013 12:44 AM
Optimal Tire Size For Stock Rims Raven604 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-05-2013 09:41 PM
