Old 01-09-2014, 12:01 AM   #29
stacker
Drives: 2013 rfs
Originally Posted by MarcL View Post
Sorry if this is old news, but I was so happy to learn that Subaru, in a brilliant stroke of genius, placed a power socket behind the glove box. This allows for a super easy wired install of the Valentine (or any other detector I suppose). Here's a video explanation. A whole lot easier than the same install using an add-a-fuse in my BMW daily driver.
TKS took all of 5min to complete>>> Great DIY Video.
stacker is offline   Reply With Quote
Old 01-26-2014, 02:00 AM   #30
eurominican
Bringing Hachiroku Back
eurominican's Avatar
Drives: 2013 Firestorm FR-S
Duuuude! Thanks! I wanted to make sure of where to tuck the wire once its run behind the A-pillar didnt know about the hole/gap in the end of the dash. This is exactly what I needed to see to confirm before I popped the A-pillar cover and ventured to plug my new dashcam in the lighter socket. Thanks again! This also saved me the $$ for the add-a-fuse since was planing on plugging it into the fuse box...
eurominican is offline   Reply With Quote
Old 02-05-2014, 09:17 PM   #31
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
Where the heck are you all finding this rj11 phone jack adapter to cigarette lighter plug? Trying to hardwire my escort and I couldn't find thus a adapter at any local store or online.
mmmcambelsoup is offline   Reply With Quote
Old 06-28-2014, 01:07 PM   #32
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Originally Posted by Jeffsu350 View Post
Very cool!
Make sure you route the cable BEHIND, or on the front windshield side, of the airbag. Wouldn't want the airbag deployment messed up by the power cord.
Can you clarify what this means?
Chad86 is offline   Reply With Quote
Old 07-02-2014, 02:35 AM   #33
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool
Just finished my install. This made perfect sense when I opened the pillar and exposed the side curtain airbag.
To clarify for anyone doing this in future, just make sure the wire runs behind the curtain airbag on the side of the glass, as to not interfere with the airbag, should it ever have to deploy.
My finished install looks factory. I am so happy with the results. It is as if Toyota intended for this.
Old 01-10-2015, 09:40 PM   #34
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
How well does the suction cups stay on the dot matrix? Mine keeps falling off after driving. Right above the rear view mirror is perfect, but those dots don't work well for the suction cups. Any solutions anyone?
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 01-10-2015, 09:55 PM   #35
Chad86
Chad86's Avatar
Drives: Toyota GT86
I have this problem occasionally too. I am thinking double sided sticky tape will solve this.
Old 01-11-2015, 04:20 PM   #36
FRS Johnny
FRS Johnny's Avatar
I was thinking small Velcro bits on the suction cup and windshield. I tried last night but it was cold and moist so it didn't stick. Think I'll put a piece of masking tape then the Velcro to make it stick more. Hopefully it works
Old 03-03-2015, 02:20 PM   #37
FRS Johnny
FRS Johnny's Avatar
So I used some gorilla tape to stick the velcro on, but the tape is sliding off from heat. Velcro doesnt hold on the suction cups either.
Anyone have a way to get the suction cups mounted on the dot matrix better? I'm going to try some 3m double sided tape today or tomorrow and hopefully that works.. but any pointers are helpful!
Old 03-03-2015, 05:48 PM   #38
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
Get a Blendmount and mirror tap. Then tap into the connector for the mirror which is hidden in the headliner. Problem solved.
Caspeed is offline   Reply With Quote
Old 03-04-2015, 06:01 AM   #39
FRS Johnny
FRS Johnny's Avatar
I sort of wanted it above the mirror so no one can see it. I found a forum online that did a diy of one without suction cups. I'll try it tomorrow. Hopefully it works! Discovered 3M dual fasteners. or scotch outdoor fasteners. It holds 5 lbs!! It's basically velcro on steroids.
Old 03-20-2015, 12:06 AM   #40
balla_08
Drives: Satin Pearl BRZ
This was my plan..do you know of a guide out there to help with the mirror tap?
balla_08 is offline   Reply With Quote
Old 03-20-2015, 01:00 AM   #41
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Read this? http://www.ft86club.com/forums/showthread.php?t=21171
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following 2 Users Say Thank You to Bramick For This Useful Post:
Busybee (06-20-2019), Caspeed (03-20-2015)
Old 03-20-2015, 07:03 PM   #42
Caspeed
Caspeed's Avatar
Looks like Bramick handled it.
The instructions come with the mirror tap. Just pull out your dome light and gently feel around inside the headliner on the pass. side. Mine was 6"-8" away from the opening. I would recomend fishing the wires from the front of the headiner. If you try to feed them forward you'll have a hard time getting the detector connector thru. Also I would wrap the connection on the mirror plug with electrical tape to prevent the tap from backing out or shorting.
Good luck.
Radar L3P47 Electronics | Audio | NAV | Infotainment 31 05-15-2013 01:53 PM
radar detectors Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 9 02-24-2013 03:27 PM
Radar Detectors swag BRZ First-Gen (2012+) -- General Topics 28 01-31-2013 05:58 PM
Next mod: Radar dector jwbrocloud Scion FR-S / Toyota 86 GT86 General Forum 39 01-27-2013 02:04 PM
Has anyone done a good concealed Valentine One install? sikest Electronics | Audio | NAV | Infotainment 3 01-22-2013 07:37 PM
