Old 05-26-2013, 04:31 PM   #43
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Doesn't hurt to at least have a ziptie.
vubaru is offline   Reply With Quote
Old 05-26-2013, 04:34 PM   #44
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by whitefrs View Post
i just notice that one side of my MBC is loose no zip tie or clamp.
could this be the problem?
it says that it can be a vacuum leak
The side that goes to the WG Actuator is often times left with nothing so that you can manipulate it. (I am running mine with nothing on it). Te Perrin MBC has a lip to hold the hose in place. You can always zip tie it and cut the tie everytime you want to manipulate it.
Old 05-26-2013, 04:36 PM   #45
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
so that a no lol
thats not the problem
The Following User Says Thank You to whitefrs For This Useful Post:
Sportsguy83 (05-26-2013)
Old 05-26-2013, 07:15 PM   #46
charged86
charged86's Avatar
so that a no lol
Let me know how this gets repaired. Does the car idle and drive normally
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 05-26-2013, 07:36 PM   #47
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Ni
Rough idle when I start the car or stopped but while driving off boost I feel it normal
Sent from my HTC One using Tapatalk 2
charged86 (05-26-2013)
Old 05-26-2013, 07:40 PM   #48
charged86
charged86's Avatar
Ni
Get this thang fixed
Old 05-27-2013, 11:18 AM   #49
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
does anyone have an idea of how much a shop will charge to replace the injector seals? and also i think that my obd2 ports is not working. its hard to get a connection when trying to onntect to ecutek or any obd scanner
Old 05-27-2013, 11:44 AM   #50
dabocx
dabocx's Avatar
Drives: Scion FRS
Its intersting that this started coming up with a few people at this time, I dont remember reading about this issue last year and quite a few people started boosting in august-november.
dabocx is offline   Reply With Quote
Old 05-27-2013, 12:10 PM   #51
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I know sucks
Old 05-27-2013, 12:34 PM   #52
xjohnx
Grip>Slip
xjohnx's Avatar
What happens when you try this?
Old 05-27-2013, 12:47 PM   #53
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
It just doesn't connect
Old 05-28-2013, 12:42 PM   #54
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
My mechanics (JMR Garage) said $500-$600 in labor to replace the direct injection o-rings.
No Limit Motorsport is offline   Reply With Quote
Old 05-28-2013, 12:48 PM   #55
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
@King Tut and @Pure Automotive
we all have the same kit. had u guys had this problem
I had the fuel pump O ring issue, but I have NEVER had a CEL or misfire/lean condition that you are mentioning. I have nearly 8,000 miles on my kit.
Old 05-28-2013, 12:54 PM   #56
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am assuming @Visconti has an EcuTek log that is showing that the direct injectors are the problem and not the port injectors on bank 1. The OBD2 port mount is pretty flimsy, so it might just be bending when you are trying to connect it. Look under the dash and make sure it looks okay visually, and I like to hold the bracket when I plug in my EcuTek cable to keep from bending the bracket.
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 07:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 01:35 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Brake fluid leaking from pistons/seals normal? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-06-2012 03:54 PM
Bad window seals? Dzeremijs Issues | Warranty | Recalls / TSB 18 10-26-2012 04:24 PM
