#15 |
this has got me kind of worried. my car is in the shop getting a turbo kit right now, and i haven't had any of the TSB updates people are talking about. I just got my car a month or two ago, should I be safe from this? how long ago did they figure this out and start correcting them at the factory?
#16 |
I Love custom Turbo kits
Drives: Limited BRZ
How are you 1000% sure it is your DI seal that is shot?
#17 | |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
as per @Visconti
#18 | |
Drives: Limited BRZ
#19 | |
Love Boost!!!!!!!!
#20 |
Drives: FRS
^^^ so the 305? Isn't the real power u will most likely make more ?
#21 |
#22 | |
Love Boost!!!!!!!!
Sent from my HTC One using Tapatalk 2
#23 | |
Drives: Limited BRZ
My advice to you, whenever someone tells you something and you really don't know or understand, ASK. That is how you will learn!!
| The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post: | lexusb3 (05-26-2013), skatery1989 (05-26-2013) |
#24 |
Drives: FRS
whats your power goal?
#26 |
Love Boost!!!!!!!!
Will talk to john more about it
#27 |
Love Boost!!!!!!!!
350 whp
#28 |
Drives: Scion FR-S
I was wondering if these are the stock injectors or aftermarket. I have seen a few issues with the design of aftermarket ones (I'm a hydraulics mechanic for aircraft). The seals on the aftermarket pumps and a injectors don't seem to be up to par. I would use high temp back up teflon rings on the back side of a high grade seal. This will make you good for temps over 300 degrees and pressures up to 6000psi. It's over kill but better to have to much than to little.
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 01:35 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 05:26 PM |
| Brake fluid leaking from pistons/seals normal? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 12-06-2012 03:54 PM |
| Bad window seals? | Dzeremijs | Issues | Warranty | Recalls / TSB | 18 | 10-26-2012 04:24 PM |
