#43 | |
Platinum Member
Drives: Toyota 86 Vortech SC
I've never adjusted anything at the coast. My car goes great there, so I'm not looking for anything more. But there could be more to be had?? I rarely go to the coast, so that doesn't matter to me. Ignore what I said about launches - as I said, I know little about drag racing. Just seemed to be so much wheelspin and so little hookup. I'm probably spoilt because I've only run R-Compound tyres for the past 18 months, and I've never run street tyres with SC.
#44 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Yep, some very good systems out there but pointless if there is no, or crappy local support. I wonder if RGM will stick with Vortech or start looking at different ones?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#45 |
Drives: Toyota MR2 Spyder Turbo
Rommies, the difference in 1/4mile time between yours and Rob's car can be put down to the fact that they were running semi-slicks on the day they ran that time. It was at a TTCC event.
Also, when pulling up to the line, dont drive over the water coz you have street tyres. With my MR2, I was running 14.6 or so all night. Then i started bypassing the water and ran 14.4 (this is before my build and at 0.5bar boost). Still need to put a new time down.
#46 |
Drives: Toyota
Ryan! are you serious man? damn! didn't even know you went s/c!?
#47 | |
Drives: Toyota
yep...I think its time to put on some 265/35/18 semi slicks on the back as well
#48 | |
Drives: Toyota
yes we did try to go around the water. its been edited out of the video.
#49 | |
Platinum Member
I use 235/40-17 or 225/45-17 R-Comps. I find my 225s a little bit lacking on track when it comes to putting down full power in 2nd coming out of a corner, but the 235s hook up well. I suggest that before going to a wider tyre, try a stickier compound.
#50 |
Drives: Toyota 86 STD
Rommies, I've done a lot of drag racing in front wheel drive cars, launch and keeping that power down is key when it comes to ¼ mile runs, tyre pressure, track temp outside temp all play a huge roll.
Front wheel drive and real wheel drive are very different on the strip. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to MacJunkie For This Useful Post: | Rommies (09-10-2014) |
#51 | |
Drives: Toyota
#52 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
86 with no spare wheel should out launch most FWD. I find using launch control @5000 rpm, with SC absolutely potent. |
#53 | |
Drives: Toyota
we will have to change rubber first like mentioned above....and then try the 5k rpm launch. Have you been to tarlton s2s bud?
#54 |
Drives: Toyota 86 Supercharged
Rommies, while you're here, what's the offset on your Rota's
#55 |
Drives: Toyota
ROTA Grid 18" 8.5J 5x100 ET44 Gun metal
#56 |
| HKS Supercharged 86 on dyno.. | Brian S | Forced Induction | 14 | 01-22-2013 01:13 PM |
| My 07 tC, Supercharged | HunterGreene | Member's Car Journals | 21 | 12-12-2012 01:52 PM |
| Supercharged HKS car on nitrous? | Lawnik | Forced Induction | 3 | 09-04-2012 12:47 AM |
| Supercharged GT86 | Billy2224 | AUSTRALIA | 14 | 06-06-2012 09:39 AM |
| Supercharged GT 86/FR-S/86 vs. Turbocharged BRZ | switchlanez | Scion FR-S / Toyota 86 GT86 General Forum | 61 | 12-20-2011 12:16 PM |
