Old 05-24-2013, 03:14 AM   #15
OrbitalEllipses
Drives: Attitude
Originally Posted by raul View Post
Went around for some figure 8s tonight at a local deserted parking lot. Ended up 1.25 turns from soft in the front and 1 full turn in the back. It corners neutral for the most part, but if you add throttle mid-corner you can get the car to rotate in a very controlled, progressive manner. It's still slightly bouncy and I might play with it more later, but so far it feels amazing.
Can you isolate where the bounciness is coming from, front or rear? This setup has minimized most of the bounciness from the stock setup, but there's still room for improvement. At 2 turns from soft front and 1.5 turns from soft rear, I'm not quite happy with harshness during street driving though I understand you don't raise spring rate (and compression/rebound damping) without losing some ride comfort.
Old 05-24-2013, 09:33 AM   #16
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I only notice the slight bounciness on hard cornering. It feels like it's from the rear. I was 1 full turn from soft in both front and rear and was getting a bit of understeer so I stiffened up the front another .25 turn. I think if I stiffen both ends proportionally I could get rid of it.
raul is offline   Reply With Quote
Search this Thread:
Advanced Search
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 07:06 AM
FS: rce yellows & whiteline camber bolt $300 chappys4life Mid-Atlantic 19 05-13-2013 03:31 PM
