86WORX
Old 05-18-2013, 10:20 AM   #43
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by lbroskee View Post
3. i know this is OBDII to read, but how do reg gauges read then? like do they go straight to what they read so as to eliminate a middle man.
Regular gauges bring their own sensor that you plug into the motor and they read directly, not through OBDII
Sportsguy83 is offline
Old 05-18-2013, 11:36 AM   #44
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Watching.
Cessblood is offline
Old 05-18-2013, 12:18 PM   #45
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Originally Posted by FA20Club.com View Post
well the torque app is bluetooth transmission which is very slow transmission rate compared to the actual CAN Bus speeds so i know the transfer rate on this will be faster when comparing it to the Torque app.
Looks pretty sick...
chadstyle is offline
Old 05-18-2013, 01:23 PM   #46
FA20Club.com
Drives: 2013 White Out FR-S
thanks Chad
FA20Club.com is offline
The Following User Says Thank You to FA20Club.com For This Useful Post:
ScottDRFT (05-18-2013)
Old 05-18-2013, 01:49 PM   #47
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Does that mean this is a bit less accurate?
lbroskee is offline
Old 05-18-2013, 01:54 PM   #48
FA20Club.com
No, just than aftermarkets gauges are cheaper in cost because the manufacturers dont invest in as much time to implement CAN communication. But at the same time not every car has certain sensors preinstalled thats why they come with their own sensors or tap into other sources to get their readings.
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post:
lbroskee (05-18-2013), Sportsguy83 (07-09-2013)
Old 05-18-2013, 02:02 PM   #49
lbroskee
lbroskee's Avatar
ah ok, so this takes advantage of the OEM features while other gauges just essentially add 2nd redundant sensors. very interesting.
looking at this how can i tell what gauge im on at quick glance? like 1 sensor temp from another
lbroskee is offline
Old 05-18-2013, 02:18 PM   #50
FA20Club.com
each item is labelled not just the display data shown
Old 05-18-2013, 03:19 PM   #51
DJCarbine
Thupercharged
DJCarbine's Avatar
Not only will I buy it, but I will have your babies as well
Can this also display lambda/AFR from the factory sensor?
DJCarbine is offline
Old 05-18-2013, 03:45 PM   #52
cf6mech
Drives: FRS Silver LS1 swapped.
would like to see a photo with this installed.
cf6mech is offline
Old 05-18-2013, 04:21 PM   #53
FA20Club.com
yes it will display the factory afr readings
Old 05-18-2013, 04:22 PM   #54
FA20Club.com
the new beta model with vent will be ready for install into our car in about 2 weeks
lbroskee (05-18-2013), lexusb3 (05-18-2013)
Old 05-18-2013, 04:27 PM   #55
Frs300
Frs300's Avatar
Drives: Pile of junk
maybe tony will mix the shop car up with mine
Frs300 is offline
The Following User Says Thank You to Frs300 For This Useful Post:
Old 05-18-2013, 04:37 PM   #56
lexusb3
Drives: FRS
or mine
lexusb3 is offline
gauge, p3cars
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 07:19 PM
Dash Cam + HU + Reverse Integration JDMSushi Electronics | Audio | NAV | Infotainment 0 12-04-2012 07:47 PM
iPodŽ/USB Integration in the glove box? 8987846 Electronics | Audio | NAV | Infotainment 26 12-04-2012 01:45 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) -- General Topics 40 08-19-2012 05:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) -- General Topics 17 12-12-2011 12:39 PM
