#141 |
Drives: 2013 White Out FR-S
PID locations on some parameters will differ but stuff like rpm speed etc the basics will most likely still work.
| The Following User Says Thank You to FA20Club.com For This Useful Post: | lbroskee (06-01-2013) |
#142 |
Drives: 2013 Scion FR-S-Asphalt
Fan! How long is the group by price available?
#143 |
until the official release i think should work for everyone
| The Following User Says Thank You to FA20Club.com For This Useful Post: | lbroskee (06-02-2013) |
#144 |
Signed up thanks for adding oil pressure option, this is huge as its the only thing I can't get with Torque and worth the cost of the gauge.
| The Following User Says Thank You to Dezoris For This Useful Post: | Sportsguy83 (06-02-2013) |
#145 |
Drives: seat ibiza
For us Europeans
Can the oil-temperature reading be changed to read in °C instead of Fahrenheit ?
With the external oil pressure sensor, is it just psi or is it possible to show the pressure in bar? thanks. edit: Just saw in the p3cars.com FAQ that metric and English units can be changed on the fly. correct me if I'm wrong
#146 | |
Drives: Great White
![]() "The interface is shipped by default using English units, but is configurable for both English and Metric on the fly via the config menu. You can also set it so that only boost is in PSI, but the rest is in Metric. Metric settings also changes the 0-60mph timer to a 0-100kph timer, and the temperatures to Celsius. Please see the operating instructions for details." |
#147 |
Drives: seat ibiza
thanks for the quote
#148 |
Drives: White GTS, Vortech, Aero kit
Definitely want RHD gauge please
![]() Also, could be a silly question but just double checking, does this get boost reading from a factory sensor (don't have to add any aftermarket sensors)?
Build thread here: http://www.ft86club.com/forums/showthread.php?t=30502
#149 |
yes the factory sensor is used for vacuum/pressure readings
| The Following 3 Users Say Thank You to FA20Club.com For This Useful Post: |
#150 |
Drives: BRZ D4S 6MT L Vortech
What else is needed parts wise to hook up the oil pressure sensor?
#151 |
Drives: 2013 BRZ DMG manual Limited
Filled out the form!
#153 |
1337
Drives: 2013 BRZ WRB S/C
I don't really need any gauges just yet but this thing is just too damn slick. Will check the finances :P
#154 |
| Tags |
| gauge, p3cars |
| LHD 3-meter gauge-pod? | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 02-11-2015 07:19 PM |
| Dash Cam + HU + Reverse Integration | JDMSushi | Electronics | Audio | NAV | Infotainment | 0 | 12-04-2012 07:47 PM |
| iPodŽ/USB Integration in the glove box? | 8987846 | Electronics | Audio | NAV | Infotainment | 26 | 12-04-2012 01:45 AM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) -- General Topics | 40 | 08-19-2012 05:29 PM |
| Gauge Sweep? | himbo | BRZ First-Gen (2012+) -- General Topics | 17 | 12-12-2011 12:39 PM |
