| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: 2013 red FR-S, OFT. 2000 Miata SE
100Low Lead has 10 times the amount of old leaded car gas. It fouls out the plugs in aircraft engines that run at 65% power or more. Auto engines would foul out even faster. On top of ruining the cats and fouling out the O2 sensors, it gets in the oil. we change piston aircraft oil every 35 to 50 hours of flying and it is nasty when it comes out. We used to run airport cars on 100LL and they didn't last long after we started using it in them. Rotax makes a H4 that will run on auto gas or 100LL. We have found when ran on auto gas, the internals of the engine are cleaner.
John |
| The Following User Says Thank You to jdcorbitt3 For This Useful Post: | strat61caster (05-16-2013) |
#16 |
Drives: WR Blue BRZ, 240Z
I'm a pilot. We call 100LL "100 Lots of Lead". It's call LL because it has less lead then the Green 130L that it replaced in the early 1960's.
Moreover, besides having way too much lead for the O2 sensor and cat, 100LL isn't formulated for throttle response - it's formulated for long storage life. |
#17 |
Red wine
Drives: Subaru BRZ(R.I.P)
Interesting.... So if you run 87 then your car is gonna run like crap, if you run 100 octane then your car is gonna run like crap(eventually), but if you fill it up with 93 your car is race car clean. Bad joke
#18 | |
Of course, our cars don't have the compression ratio and ECU tuning to take advantage of the 100 octane (stock) so it's kind of like throwing money down the drain if you have 93 readily available. |
#19 |
Drives: 2013 Subaru BRZ Limited in DGM
I have used 107 Octane "unleaded" fuel for racing and autocrossing in serveral Subaru's going back to the 90's. It will not hurt your car, but it might not give the benefits you hope for. I found it gave me slightly better performance and would just take 5 gallons (in a racing canister that was molded plastic) run the car down as empty as I could before the event and then put in the 107 octane. That is the only times I ever used it. One quarter of a second in a timed competition event was worth it. But I would never use it for street driving as the difference was not worth the cost or trouble.
I would never put leaded gas into a 2013 car with a standard manufacturer engine. It will cause you much more trouble in the long run than you will experience any performance increase in the short run. |
#20 |
Drives: 2005 Toyota Camry
If you're running leaded-anything, even if it's 1000 octane, you'll do more harm than good if your internals are stock and you're running factory timing.
If you have an engine built up to run this type of gas in the first place, you wouldn't be asking the question. The only benefit of running fancy high octane gasoline, is the feeling that you're a much faster driver with it. It's like putting on stickers on the car... you look and feel fast, but it doesn't add any power to the car. And costs money. Sidenote: yes, high octane gas may help at the track under extreme temperatures, but frankly if the temps are so high where a stock engine warrants such high octane gas, I'd be more worried about cooking the brakes/tires/coolant before engine knock becomes a major issue. -alex |
#21 | |
But then again, it all depends on what gas the engine was originally tuned for. -alex |
#22 |
(=^・ェ・^=)
Drives: 2013 FRS, '08 GSXR 600
Why did this remind me of the Family Guy episode where Peter thought about putting airplaine fuel in his car? But you never know until you try so . . . . . . . .
| The Following 2 Users Say Thank You to Ryuu0u For This Useful Post: | VesperLynn (05-17-2013), WRXGuy1 (05-20-2013) |
#23 | |
I had a 2.5RS with Cobb tuning upgraded camshafts, Prodrive cold air intake and cat back exhaust,. As well as a mix of Cobb, Prodrive and STI perfromance parts in the suspension, transmission and shifter. I tried to say that I thought it was not worth the trouble, effort or money to use on a daily driver to try and get more perfromance. Guess I did not do it well. |
#24 |
AutoX-10/10ths every run
I've run 100 octane unleaded in my tank a couple of times. Not sure if the car was any faster, but it sure seemed to run smoother. 8-9 dollars a gallon hurts though.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
#25 |
Dismember
Drives: 2013 Red Scion FR-S
Running leaded fuel causes brain damage and criminality. No kidding. Leaded fuel goes away. Crime rates drop as the last brain-damaged cohort goes away. Leaded fuel is poison. Stay away.
#26 |
Drives: FR-S 6MT
lead will kill the cats and possibly other sensors.
tha additional octane won't help you unless you modify the ECU to take advantage of it. |
#27 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
[ame="http://www.youtube.com/watch?v=A6ZklI4D5Ko"]family guy jet fuel truck - YouTube[/ame]
| The Following 2 Users Say Thank You to whitefrs For This Useful Post: | Allch Chcar (05-19-2013), VesperLynn (05-19-2013) |
| FR-S at Williams Airport | texas2888 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 02-22-2013 12:34 AM |
| 100 octane race gas: 91 octane ratio? | GhostofAkina | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 02-08-2013 02:23 AM |
| Buckingham Airport AutoX - Ft. Myers, FL - 11/11 | raul | Southeast | 0 | 10-29-2012 08:26 PM |
| Baltimore airport. Any frs/brz guys here? | Hardrock4445 | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 10-27-2012 08:50 AM |
