#743 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
#744 |
Drives: 2013 Subaru BRZ Limited SWP
Not to drag the quality of this thread down with a fart joke... but dude really looks like he's just pulled his own finger.
Derek
2013 BRZ Limited SWP Professional driver in search of closed course.. |
#745 | ||
Drives: 2013 Asphalt FR-S
![]() Quote:
![]() My concern is more to do with getting the car to the dyno on an ecutek basemap... ecutek and brzedit are not "compatible" so I would have to use whatever canned tune is available, which rules out the possibility of a larger maf housing until i am able to do a BRZedit base map that runs the car. I could always use the canned ecutek tune to get to the dyno, get some base numbers, get some logs, then head home with the data and create my own base map in brzedit True, but with a good honeycomb and proper maf housing you can clean up most of that. I have one sitting in my tool chest right now :happy0180:
~Namaste~ |
#746 | |
Corner Junkie
#747 |
Drives: 2JZ FRS
what are the oiling requirements for these units? self contained im assuming?
| The Following User Says Thank You to spitfire481 For This Useful Post: | robispec (06-05-2013) |
#748 |
Drives: Black frs project
Yes.
#749 |
Add lightness!
Drives: 17' WRX
Man that sprintex kit is one nice looking piece of hardware.
#750 |
Yeah, sorry, i was asking if the ecutek base maps provided with the kits will be speed density or maf based load.
~Namaste~ |
#751 |
Drives: SSM LT MT BRZ
the ECUtek maps are simply corrected, they do not completely change the firmware so that you can run MAF-less.
HOWEVER, the ECU actually relies on the map sensor for low load low rpm fueling as well as the MAF,...that's why we have a MAP sensor in a MAF car...that is NA... longstoryshort...you are gonna be fine rescaling the maf with a larger sample area, the MAP sensor should make up for the difference. not to mention since there is a positive displacement SC on top of the manifold now you should be moving more air per RPM anyway, so it's a self remedying problem of sorts. you will not likely be able to use both ecutek and brzedit on the same ECU, I doubt BRZedit can pull a rom previously edited ECUtek. |
| The Following User Says Thank You to SkullWorks For This Useful Post: | mad_sb (06-05-2013) |
#752 |
Drives: 86
#753 |
Drives: Thunder Silver 86 GTS
#754 |
| The Following User Says Thank You to robispec For This Useful Post: | whataboutbob (06-05-2013) |
#755 |
Drives: American Made Shift!
| The Following User Says Thank You to tom@kartboy For This Useful Post: | whataboutbob (06-05-2013) |
#756 | |
I'm familiar with hybrid map maf cars, 4b11t's are like that but the roms have been decoded enough that you can log each load calc and match up the tables so your maf load matches your map load. There is a map based load table in the rom but it looks more like a load compensation table rather than a straight load table... Values at low rpm low manifold pressure (high vacuum) are higher than the values at higher rpm and higher manifold pressure. And it only goes up to 4800 rpm. I'm sure there are more tables that have not be defined yet though. The stock ecu has a map based port fueling compensation table, so as long as you update to a 2+bar map sensor and update the MAP calibration table you can comp the port fueling. I don't expect ecutek and brzedit to be compatible. What i'm thinking is i can run around on the ecutek base map to log the tune, make a few pulls on the dyno etc.. Take the log data (ignition timing, engine load, port injection time, di injection time, etc) and build a good enough base map in brzedit to get the car running safely. At that point I would flash back the stock rom with Ecutek and flash my rom with brzedit and start fine tuning.
~Namaste~ |
| Bullet/Sprintex/Innovate on the bullet website | JoeBoxer | Forced Induction | 333 | 04-18-2013 11:07 AM |
| Still searching for an FR-S? 2 available in Little Rock | Moshpit37 | Southwest | 9 | 01-02-2013 11:32 AM |
| Bullet SC 86 | Loki556 | AUSTRALIA | 9 | 08-08-2012 02:39 AM |
| Searching Inventory in the SE | Erroneous | Southeast | 40 | 07-23-2012 05:40 PM |
