#645 | |
That Guy
Drives: 2013 asphalt FRS MT
Can we get a full list of parts on your car that will aid in acceleration? I'm pretty sure you said you have a 4.7 final drive & E85, and now there's a header and half an exhaust system. Is there anything else? Am I understanding this correctly, basically this "vq35" feeling motor is going to feel more like a K20 with mild bolt ons, to those of us that haven't done those mods and don't have E85 available? Or more to the point, all of the reviews of how this kit makes the car feel are completely invalid? |
| The Following User Says Thank You to Calum For This Useful Post: | Sonolin (05-31-2013) |
#646 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#647 |
Old...
Drives: Subaru
A lot of people don't get that boost pressure is a residual measurement. CFM and temperature are more important leading indicators. Less boost and more power just seems counter-intuitive at first. When you add exhaust on a blower setup, boost typically drops but power goes up. You increased CFM of the motor. If you open up the inlet more before the blower, the boost rises because it can inhale easier. Colder temperatures will also look like less boost, but make more power. You'll only ever flow as much air as your tightest restriction. That could be the valve, tb, compressor inlet, or cam.
I'd like to know what kind of exhaust pressures are normal. I've never looked into it too deeply.
| The Following User Says Thank You to Subzero For This Useful Post: | Calum (05-31-2013) |
#648 | |
Drives: Black frs project
Check the build log lol
The 75 mm pulley on our car makes approximately seven psi at peak We make about 10 % more than the gasoline car with the 80 mm pulley To my knowledge the car will come with a base map for the stock intake stock exhaust California 91 octane Kart boy is running the 75 mm pulley on a gasoline car talk to him about how it feels . If he can stop smiling long enough to give a coherent answer Quote:
| The Following 3 Users Say Thank You to robispec For This Useful Post: |
#649 | |
Drives: Whiteout FR-S
| The Following User Says Thank You to JoeBoxer For This Useful Post: | tom@kartboy (05-31-2013) |
#650 |
Drives: American Made Shift!
Its nowhere near as fast as my E63 wagon. Then again its 1/3 the price.
![]() If anyone is in the SD area and wants a hotlap. i'm game. My car is for the most part stockish. Minor suspension mods, Tires-wheels, along with our KB goodies. Thats about it. |
| The Following 3 Users Say Thank You to tom@kartboy For This Useful Post: |
#651 |
Old...
Drives: Subaru
What diameter is the crank pulley? (Please mic across the tops of the grooves and not the bottom.)
#652 |
Stock I never liked the non harmonic lightweight parts.
#654 | |
Drives: Da-Big Banana
Great now I need to go change my pants thanks guys.....
#655 |
#656 |
Drives: 86 (FR-S)
Just for compare, the 280whp I made (Honda) was with a 4-2-1 race header and 2.5" header back exhaust with a Jackson Racing Roots SC no cooling on a K20A2 93 octane. This is the exhaust setup that most of us ran and the guys who tried 3" yielded slightly poorer performance (especially low/mid) and did not hit higher peak hp numbers.
This is why I believe a similar setup would be optimum here. It's a high compression 4 banger. It's happier somewhat lower rpms and it does not breath as well. I frankly wouldn't expect to make K series power, but as I've said, the twin screw is better than a roots in every way. I'm thinkin 250+ uncooled and I don't want the cooler. A nice header, exhaust (2.5" imo) and an oil cooler and done. |
| The Following User Says Thank You to Jeff86 For This Useful Post: | JoeBoxer (06-01-2013) |
#657 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Slightly OT but, are any of you that are running lightened flywheels and lightened pulleys seeing misfire codes?
#658 | |
I Love custom Turbo kits
Drives: Limited BRZ
WOW...
| Bullet/Sprintex/Innovate on the bullet website | JoeBoxer | Forced Induction | 333 | 04-18-2013 11:07 AM |
| Still searching for an FR-S? 2 available in Little Rock | Moshpit37 | Southwest | 9 | 01-02-2013 11:32 AM |
| Bullet SC 86 | Loki556 | AUSTRALIA | 9 | 08-08-2012 02:39 AM |
| Searching Inventory in the SE | Erroneous | Southeast | 40 | 07-23-2012 05:40 PM |
