86WORX
Old 05-31-2013, 01:59 PM   #617
Sonolin
$3500 including tune and cable?
That's really good! I'm liking the price point
Sonolin is offline   Reply With Quote
Old 05-31-2013, 02:08 PM   #618
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I've had two different roots blowers on two different four cylinders (Mazda and Honda) with no cooling and never had any problems even in summer here in the south. Last one made 280whp. If I went this route I doubt I'd buy the cooling when they offer it. Twin screws are more efficient and have less heat issues than roots blowers.
Jeff86 is offline   Reply With Quote
The Following User Says Thank You to Jeff86 For This Useful Post:
Opposed (05-31-2013)
Old 05-31-2013, 02:17 PM   #619
robispec
Drives: Black frs project
Yes will be offered as an upgrade.
robispec is offline   Reply With Quote
The Following User Says Thank You to robispec For This Useful Post:
Mr.Zoolittle (05-31-2013)
Old 05-31-2013, 02:27 PM   #620
Subzero
Old...
Subzero's Avatar
Drives: Subaru
[ame]http://youtu.be/Xlq3XspyBH0[/ame]
That's the sound of someone trying to enjoy their car, without getting a ticket. .
*Mash*shift*Mash*part throttle with clutch slip*wait for iiiiiiiiit*Mash*Wheeeeeeee!
Every single one of us has done this.
Subzero is offline   Reply With Quote
The Following User Says Thank You to Subzero For This Useful Post:
mines13 (05-31-2013)
Old 05-31-2013, 02:30 PM   #621
robispec
Yeah puts a big grin on my face EVERYTIME. I feel so juvenile...and dont care!
OrbitalEllipses (05-31-2013)
Old 05-31-2013, 02:34 PM   #622
Sonolin
I'm wondering about CARB approval? Has there been any news about CARB, and would that apply to both non-intercooled & intercooled kits or just one in particular?
Old 05-31-2013, 02:35 PM   #623
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
The status of how the intercooler setup will come to market has not been finalized. It may be an accessory, it may be part of a different version of the kit, or maybe both. As is, an oil cooler will be a more significant upgrade then the intercooler on the base kit. I would say that about a stock FA20 too. Not to beat an already well flogged, very dead horse.
mines13 is offline   Reply With Quote
The Following User Says Thank You to mines13 For This Useful Post:
Sportsguy83 (05-31-2013)
Old 05-31-2013, 02:43 PM   #624
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Sounds like i need to come up with a package deal of Innovate supercharger, Perrin oil cooler, and 3" Perrin exhaust.
JoeBoxer is offline   Reply With Quote
The Following 2 Users Say Thank You to JoeBoxer For This Useful Post:
PoWn3d_0704 (06-02-2013), Sportsguy83 (05-31-2013)
Old 05-31-2013, 02:51 PM   #625
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
I keep telling myself to wait until my car is out of warranty, but this kit is just looking too good!
The Racers Line is offline   Reply With Quote
Old 05-31-2013, 02:55 PM   #626
Foobar
SLO NO MO
Foobar's Avatar
This looks to be the easiest FI kit to install and remove, so if you're worried about bringing your car in for service work, just unbolt, reflash, and go.
Old 05-31-2013, 02:58 PM   #627
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I don't believe a 3" exhaust would be optimum with the supercharger. We all went 2.5" on the SC'd Hondas until going turbo and pushing past 300whp. Exhaust velocity is still an important factor and the SC is a more NA-like situation since it doesn't touch the exhaust system.
Old 05-31-2013, 03:06 PM   #628
JoeBoxer
JoeBoxer's Avatar
We can do either, will leave it up to the customer to decide
Old 05-31-2013, 03:17 PM   #629
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Just trying to help the community . After a lot of dyno research, the 2.5" produced the best overall results on the SCd cars under 300whp.
"The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM."
From the article here:
http://forums.tunedimports.net/showt...why-it-s-wrong
I believe we'd see some similar results here since this motor is actually happier in a somewhat lower rpm range.
Old 05-31-2013, 03:21 PM   #630
SkullWorks
Drives: SSM LT MT BRZ
While I would tend to agree that a significant gain won't be had by going 3" at such a low HP level, you are going to have a very hard time coming up with actual data to support that there is a loss. Positive manifold pressure will help to overcome any internal EGR and a well tuned ECU will ensure that the cam overlap is ideal per RPM and TP (or load rather)
Im not saying 3" is a good idea, it will be ungodly loud, harder to package properly, and not really very beneficial. But every forum seems to develop a group of users who swear on things like exhaust scavenging...ad back pressure helping to make power...most if not all of that is done at the merger in the collector, after the merger, you just want to decrease back pressure that is how you maintain exhaust gas velocity in the primaries, by not creating a backlog downstream.
SkullWorks is offline   Reply With Quote
The Following 2 Users Say Thank You to SkullWorks For This Useful Post:
Fast_Freddy (06-01-2013), Jeff86 (05-31-2013)
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 11:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 11:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 02:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 05:40 PM
