#113 |
Site Moderator
Drives: Stuff
Not really. .6 seconds isn't that aggressive of a shift. It's not a lazy shift but it's far from a power shift too. Can someone datalog the following? Run the car up near redline is 2nd, get off the gas, then floor it again, within .2-.6 seconds and see if this occurs then? I bet it does. I use that type of driving to set the car (or unsettle it) by moving weight around, etc...
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | 2forme (06-07-2013) |
#114 | ||
Drives: GR86
#115 | |
#116 |
#117 |
Grip>Slip
I thought it was a valid question. If it's the transient spark tables, why would it happen during tuning? I haven't seen any dyno tuning methods where you'd be on-off-on the throttle in a similar manner that is described in the TSB or used to induce oversteer.
#118 | |
Keep it on topic please. He made a statement, there just happened to be a case that differ, hence the question. What is the explanation for the difference in that case?
#119 |
Drives: 2013 Firestorm FR-S
Was it possible that activity previous to the tunning weakened the seals and they let go while tuning due to the pressures? Just thinking of possible scenarios, not saying that I'm right in this particular case.
2013 Firestorm FR-S, MTX, build date 1/13.
#120 | |
Drives: 2013 Asphalt FR-S
Certainly, the omission of transient retard beyond 5,000 rpm will cause most cars to experience shift knock at some time or another... but that is not the only time knock can occur. IMO, the seals are simply a poor design and will continue to fail even after the update for some un lucky folks with knockzillas under the hood. That's not to say that fixing the transient retard issue is not valuable, it certainly is, and both subaru and toyota should do a recall / all regions tsb on the issue at a minimum.
~Namaste~ |
| The Following 3 Users Say Thank You to mad_sb For This Useful Post: |
#121 |
Drives: A lot of supercars.
They are going to have to sooner than later.. I know over a dozen people in my area that owns a 86 and 4 of them are having/had the issue, not including myself.
#122 |
Drives: Over the hill WRX
That plastic piece acts as a seal in a location near the combustion chamber? Even if there is no knocks it will deteriorates just from continuously sustaining temperature cycling.
#123 |
I haven't seen anyone with the DI seal issue before April, which is when mine and a few others started. Has anyone else? I was right over 20k miles.
#124 |
Drives: Honda Fit
#125 |
Drives: BRZ DGM Limited
So are we saying that in its current design we should keep the RPMs below 4K to prevent seal failure?? Drive in in break in mode for the life of the car???
#126 |
We can all have our backseat opinions. Detonation at high RPM combined with high engine temps and sustained heat would make complete sense why a $10 seal would fail.
Thing is we won't know until people start running new or modified flash seals and pulling injectors after hard mileage.
| The Following User Says Thank You to Dezoris For This Useful Post: | mad_sb (06-08-2013) |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 05:26 PM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 10:31 AM |
| Leaking Oil? | 636 | Issues | Warranty | Recalls / TSB | 11 | 01-05-2013 05:43 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 06:03 PM |
