#57 |
The correct response by Toyobaru would be to issue a recall and fix the cause of the problem while also updating the design to be more resistant to it in the future. I mean, the cost of these parts are miniscule compared to the amount a new motor would cost, even assuming it only ever affects 1% of owners.
#58 | |
Drives: A lot of supercars.
#59 |
Drives: '13 SWP BRZ-L
I question this as well... Even if my seals are OK, has the damage already been done to the pistons?
#60 |
Drives: Firestorm FR-S (MT)
Just out of curiosity, everyone who is having these injector troubles, did you follow proper break-in procedure? Everyone always argues whether you should or shouldn't follow the manufacturers break-in procedure. Well, I think this would be a good place to start collecting data.
#61 | |
I literally drove from Los Angeles to San Diego for dinner, using surface streets only. Took about 5 hours. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Shagaliscious (06-04-2013), strat61caster (06-04-2013) |
#62 |
Well, that was easy. Thanks.
#63 |
#64 |
Drives: 2013 BRZ Ltd. MT
Here are some further thoughts to ponder: So far, Subaru/Toyota have not shown that they have a general fix for all of us, and/or are uninterested in pursuing a universal fix. My suspicions currently are that this phenomenon of “Burst Knock” (to borrow from GM), and the potential or certain(?) catastrophe that follows when sufficient damage accumulates over time is applicable to anyone who drives these cars “aggressively.” It may destruct sooner if one tracks the car, but I have to wonder if my BRZ is safe even if I do not track the car. It just may take longer.
That Toyota bulletin indicated the cause of failure to be the result of “aggressive” shifting above 5200 rpm. If it blows up, Subaru/Toyota will replace your engine. Once. Meaning? To me, as I read things, they currently cannot assure owners that the engine will not destruct yet again. But next time = NO WARRANTY. No warranty to cover our engines on our new cars. The most expensive component on our cars is no longer covered following the first replacement which occurred through no fault of the owner, but was almost certainly the result of a serious design flaw. Faced with that situation, I would not dare take it over 5200 rpm and shift “aggressively.” Now, is it not true that the engine replacement would be recorded in the CarFax database? What will that do to the resale value of said car? Would YOU buy it as a used car at market competitive prices? With an ENGINE REPLACEMENT on record? Not me, mon. Maybe for a $10,000 discount, but I’d probably still avoid it. Who needs that kind of trouble? Will a non-Subaru dealer give me full market trade value on a trade-in? Will Subaru, even? They’ve still got to sell it to an increasingly savvy market who know enough to check the CarFax records. For the record: I am unaware of any problems with MY car of any significance, although I have just now heard my crickets awaken at 4200 miles. Crickets do not concern me, and no one is touching my fuel pump, thank you. I took delivery of my new BRZ one year ago. And for Shag’s edification, I broke it in very progressively and patiently. In fact, I followed the Porsche company’s break-in procedure. Many folks would sneer at how I broke in my BRZ. But, I’ll bet when they’re in the market for a used BRZ, mine’s the one they’d want to buy. ![]() I really like this car. But these recent developments concern me. I know they can do better than this. In the recent Nurburgring 24-Hour Race, the GT86 won one class and was second in another and many others scored very well. Did they not do well last year, too? I fail to see how those cars could do that with the same ECU fuel/ignition mapping that we have on our street cars. These engines can be made to work, and work reliably. There surely is no tougher endurance race on the calendar than this one. |
#65 | |
#66 |
Seems like the fix is an ECU reflash, shouldn't be long to fix... After EPA vetting of course -.-
| The Following User Says Thank You to strat61caster For This Useful Post: | Carwhisperer (06-04-2013) |
#67 |
Drives: FRS
Agreed. I expect the TSB to show up in the mail relatively soon. I, once again, suggest you all call your OEM and and talk about this issue. Get it documented and let them know we are aware there is a problem.
| The Following User Says Thank You to wootwoot For This Useful Post: | Carwhisperer (06-04-2013) |
#68 |
Drives: 2010 Mazda 3 hatch
What's the point of having a 7400 rpm redline if the engine can't take it...
| The Following 7 Users Say Thank You to mx5apex For This Useful Post: | 1stGenBRZ86 (08-04-2013), ATL BRZ (06-05-2013), BatStig (06-04-2013), Carwhisperer (06-04-2013), CSG Mike (06-04-2013), Spartan65 (06-12-2013), SubieNate (06-05-2013) |
#69 |
#70 |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 05:26 PM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 10:31 AM |
| Leaking Oil? | 636 | Issues | Warranty | Recalls / TSB | 11 | 01-05-2013 05:43 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 06:03 PM |
