Old 10-09-2014, 03:49 AM   #337
s2d4
s2d4's Avatar
Originally Posted by Astroboy View Post
I hate that 10% ethanol crap. One time, Since everybody on this forum was recommending shell gas station, I figured i'd give it a shot. I took my car ONE time to a shell gas station that apparently had 10% ethanol in it, and I soon started having many issues with my car. I go to my local gas station now because they have 93 octane gas with no ethanol content.
Fuck you shell and your 10% ethanol.
I love ethanol.
The Following User Says Thank You to s2d4 For This Useful Post:
ISDriven (10-09-2014)
Old 10-09-2014, 07:33 AM   #338
ZZT86
ZZT86's Avatar
Drives: BR86
only if it's 85%
ZZT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to ZZT86 For This Useful Post:
Astroboy (10-10-2014), ISDriven (10-09-2014)
Old 10-09-2014, 10:18 AM   #339
ISDriven
ISDriven's Avatar
Drives: chill
Originally Posted by s2d4 View Post
Not the same issue.
The popping on cold start can be normal if fuel has ethanol in it.
But here's the thing, It didn't occur on a cold start, nor did I ever tell the dealer that. It happened waiting for a traffic light. When the light changed, I stabbed the throttle, revs jumped to about 3-4k and POP. Both times it happened were almost identical scenarios. The engine was slightly warmed. I was able to drive out of the parking garage and down a few blocks in rush our light to light. I would say the engine was already running for at least a good 5 minutes minimum before it occurred. Ambient temperature was about 70 degrees maybe.
Is that still technical considered a cold start? The engine was not cold or starting.
I am not arguing, I'm just saying the whole thing is suspect.
ISDriven is offline   Reply With Quote
Old 10-09-2014, 12:04 PM   #340
s2d4
s2d4's Avatar
So far if you have this issue, it'll be there all the time unless it is starting to become that.
But yeah, warranty is your friend if that is the case.
Old 10-10-2014, 11:59 AM   #341
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by nikitopo View Post
You mean the stock ecu? Nope.. above 4000 RPMs it runs quite rich. Factory adds more fuel in high RPMs for protecting the motor generating high temperatures and dangerous knocking. Tuners always changing these AFM ratios and run leaner ..
Then what what was the issue with the factory tune? Was it timing?
Astroboy is offline   Reply With Quote
Old 10-10-2014, 12:34 PM   #342
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes, they removed a bit of timing in the specific conditions.
The Following User Says Thank You to nikitopo For This Useful Post:
Old 10-10-2014, 12:43 PM   #343
Astroboy
Astroboy's Avatar
Drives: None
so it really had nothing to do with the afr?
Old 10-27-2014, 06:23 PM   #344
Hanakuso
Has there been a fix to this yet? One of the reasons why I'm hesitant to go to the track often is this issue might haunt me after warranty is over.
Hanakuso is offline   Reply With Quote
Old 10-27-2014, 06:26 PM   #345
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I'm pretty sure there was a software update as long as you have the latest tsbs and firmware in your good, also allot of the aftermarket tunes had corrected the issue before the OEM
Old 10-27-2014, 07:21 PM   #346
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Mine has about 20 hours of track time (about 14 on the stock tune), and with all the other track junkie 86s in the NW we have more than 150 hrs of track time without a single failure I am aware of.
Decay107 is offline   Reply With Quote
Old 10-27-2014, 07:24 PM   #347
Fastbrz
Drives: Wrb brz
I thought It was federal law that all gas must have 10% ethanol.
Fastbrz is offline   Reply With Quote
Old 10-28-2014, 12:59 AM   #348
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Not in Canada.
Muaddib is offline   Reply With Quote
Old 10-29-2014, 03:05 PM   #349
diirk
diirk's Avatar
Drives: Audi S5
Will Wet Trace around the injectors show if a DI seal has failed?
diirk
15 Audi S5 DSG Daytona Grey | Pinnacle Tint
<SOLD>13 SWP BRZ Prem MT
diirk is offline   Reply With Quote
Old 12-31-2015, 07:09 AM   #350
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
I stumbled across a post where someone listed some aftermarket seals for the DI's. I can't for the life of me find the link again. It was from a Japanese company. Anyone had any experience with those seals? Are they any better than the OEM ones?
2006 Lotus Exige Aspen White (Supercharged Honda K24A2 swapped.)
1994 Autozam AZ-1 Mazdaspeed
1996 Mazda Miata (Track car.)
2007 Suzuki SV650 (Track bike.)
akiranakayama is offline   Reply With Quote
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 07:33 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 10:31 AM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
