#155 |
Drives: Honda Fit
I wonder why failing injector seals didn't show up in the countless miles of preproduction testing. Did they change specs prior to ramping up the manufacturing process?
Just wondering. |
#156 | |
Either this is an issue that's come up recently due to differences between manufacturing and pre-production, completely overlooked during testing, or this isn't "normal" and it only affects a minority who are aggressive with their cars. I expect an ECU reflash to be available by the end of August, they'll warranty any stock vehicle failures (hopefully regardless of track time) and it will die down like the CEL/SL did. At least, that's assuming the failure is related to the knock and not the heat, if it's the heat then they'll need to change parts or figure out how to keep the engine cooler, that would be a huge mess. |
#157 | |
Drives: Honda Fit
No. For three reasons: 1) Chirp is ethanol related. 2) The Japanese don't perceive the chirp to be anything other than normal. 3) Chirp does not lead to either abnormal functioning of the car nor engine failure. Windows and tail lights are small assembly glitches remedied by a manufacturing process adjustment. Neither the windows nor the tail lights have rendered the car inoperable. |
#158 | ||
2. Fair, no argument there. BUT, they did issue a TSB which indicates that something requires fixing. 3. Agreed, however IF they were aware of the noise and deemed it "normal" a TSB should never have been issued, no "new" pump designs should have been put out. But those things happened, the "solution" was put into place either due to consumer demand or they were unaware of it in testing for whatever reasons, in which case you'd be asking the same question we're asking here: "Why wasn't this caught earlier?" Quote:
I admit they are not comparable to the injector seal issue but they are widespread and would have been caught on 10 randomly selected and thoroughly tested cars, at least from the pool we all bought ours from. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Carwhisperer (06-12-2013), Marrk (06-12-2013) |
#159 | |
Track Junkie
Drives: Faster than the Stig!
Btw guys i get to drive the ring on the 17th and they have a fr-s where im renting the race car. Ill ask them if they have had any DI issues since its a track rental, im guessing the cool temps will prove otherwise. If my mistake was posting my issue with the car to try and find a permanent fix so people dont start having the same problem some of us have had then so be it.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#160 |
Drives: A lot of supercars.
Guys ease up.
#161 | |
Loves the Smell of Track
Drives: '13 86
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD http://www.ft86club.com/forums/showthread.php?t=7934 |
#162 | |
Drives: Moped
#163 | |
Drives: Honda Fit
Please do report back on The 'Ring, etc. :happy0180: |
#164 |
Drives: BRZ, STI, 535, Tiffin Allegro
I had my injectors pulled by a 3rd party mechanic because Subaru refused to.
Here is what we found: ![]() Cylinder #1 injector was so badly pitted that we had to completely replace it:
#165 |
Drives: '13 86
Were you running a tune when the problem started?
#166 | |
Drives: GR86
More details please.... 1. Why would Subaru not pull them (no CEL)? 2. How many miles on your engine? 3. Did you just do it to check or could you hear an audible knock? 4. Anything else you think is important that we should know |
#167 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#168 | |
Please tell me you rubbed it in the face of the service manager and filed a complaint with SoA to get a refund. I think someone should take this to Jalopnik or Autoblog or something. That would DEFINITELY get their attention. |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 05:26 PM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 10:31 AM |
| Leaking Oil? | 636 | Issues | Warranty | Recalls / TSB | 11 | 01-05-2013 05:43 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 06:03 PM |
