#141 |
Drives: 2010 BMW M3, 2013 Subaru BRZ
So I just had the warranty work denied because of modifications.
All I have on my car is: Eibach R2 (I believe the external reservoir scared them) Robispec rear tophats for more suspension travel Robispec front control arms HKS drop in air filter Sound tube delete Stainless steel brake lines Carbotech xp10 brake pads JDM exhaust tips Hankook RS3 As you can see no modifications unless you want to argue the air filter and sound tube delete, everything towards the engine is stock. Subaru tech line said they had never heard of this issue. My dealer is asking me to give them 150 for the engine teardown to find out the problem and I am sure they will find a problem and after they do find a problem with the injector seals they will warranty it and it will cost me nothing/refund 150. That is if they don't play any funny games and try to screw me over. Question is should I buy the parts and fix it myself OR pay my dealer the 150 and have them find the issue (if they dont try to screw me) and refund me my 150 after they find the injector seal issue and perhaps document it to help hurry up the posting of the TSB. |
#142 | |
Also, I think you need a special tool to swap the seals. One that only dealers have right now. I say push back, threaten law suit. |
#143 | |
Drives: '13 BRZ TLM Spec
Magnuson Moss only covers replacement parts; oil filters, air filters, spark plugs, etc. Automotive factory warranties only cover manufacturing or design defects. They don't cover any other failure; abuse, accident, lack of maintenance, etc. Warranty coverage can be denied for many things. I'm still confused as to why everyone's panties are in such a bunch...everything posted here as to why this engine failed is just a wild guess until we have some facts. Everything else is just workbench guesses and accusations.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
| The Following User Says Thank You to Opie For This Useful Post: | tripjammer (05-30-2013) |
#144 | |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | ATL BRZ (05-30-2013) |
#145 | |
Considering how this car is marketed, I would say that a motor failing under marketed use is a design defect. |
| The Following User Says Thank You to 2forme For This Useful Post: | ATL BRZ (05-30-2013) |
#146 |
Except the engine that failed was in a Subaru...not a Toyota (Scion), there is no concrete evidence that the Subaru mapping has, or had that same issue.
#147 | |
Grip>Slip
#148 | |
Drives: SSM LT MT BRZ
Are you suggesting that there is a difference in mapping between the 2 cars? That seems like a pretty far fetched idea...I'm not going to claim there won't be differences in how the Chassis control module may function based on different trims/available options, Perhaps even different access protocols (which seems to be disproven since techstream works on BRz's...) But it seems highly illogical that subaru (the manufacturer of the vehicle like it or not discuss elsewhere) would put safer maps in the Toyota's and Knowingly ship their cars with incomplete ign. retard tables...yes i am aware that the DI system comes from Toyota, I also would tend to believe it would be in toyota's best interest not to destroy a bunch of Subaru motors that say Toyota on the engine cover... We all understand that they are separate companies with their own rolls of red tape, but let's not pretend like they aren't the same car at the end of the day....including the same motor and the same ECU. |
#149 | |
Your car is at Irvine? They did our first engine, and I will be MORE than happy to get you a copy of our repair order. |
#150 |
I'm simply saying that Subaru has their engineers, and Toyota/Scion has theirs. There are TSB's that apply to one of the twins but not the other so it would seem that there are differences including the mapping that could be different.
I wouldn't just assume that everything except the front bumpers and the trim levels are the same.
#151 |
#152 | |
I know Ferdie is aware of the problem, and he's told me that they've done several of these already, and this was last year... |
#153 | |
Drives: Moped
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 05:26 PM |
| Need Help - 2 codes thrown | jpit | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 01:41 AM |
| Bulb codes | JDMenrique | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-17-2013 04:25 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 06:03 PM |
