| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Delights in pure handling
Drives: Zoom Zoom
Foam? What about it getting wet and eventually deteriorating over time?
#16 | |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
#17 |
Kuruma Otaku
Actually for its 12.5:1 compression and combined port/direct injection setup, 200 hp and 151 lb-ft of torque are pretty 'meh'. It should have some good economy.
Because titanium. |
#18 | |
Registered you sir
Drives: 99 impreza coupe
If there is one thing I am not worried about its MPG's, I sure wont be driving it with fuel economy in mind.
#19 |
Drives: n/a
theres no way i thought a sports car like this would get 35 mpg. I hdo hope however that the 30 number is at least in the city or combined
#20 | |
Drives: '06 AM V8V Coupe
The beauty of small displacement high rev is if done right, you can have both power and economy. When your engine grows too big you can't gear it down anymore. |
#21 | |
Registered you sir
#22 |
It's not true on modern engines. Back when they had fixed cams and port injection? Yea.
Gears have far far more to do with economy than anything else. |
#23 |
Registered you sir
Fuel consumption is performance, this is not even debatable.
#24 |
Mr. Sarcasm
I like this thread. Reading it makes me smarter. I don't know much mechanically about cars, but this is helping lol.
#25 |
Drives: 05 Nissan Sentra Se-r Spec V
Balls out tuning will require more fuel, true, but has anyone ever lost mpg from intake, headers, and/or exhaust? Even a higher compression ratio makes for more efficient combustion...It is when the power band gets moved up to 5-9k rpm that mpgs suffer immensely. Look at Mazda's Skyactiv...they basically built a race engine that makes power in the low rpms in order to achieve better fuel economy...And it worked!!! The only reason modified street cars lose mpg over stock is because, well, you don't modify a car to drive at the same speeds as a stock car... |
#26 | |
On that note, though, Mazda is incredible!! Developing an engine running 13:1 compression, reliably, on 87 octane fuel! It's just too bad Americans suck... |
#27 |
'it's the yeti of Texas'
Drives: 2013 Whiteout 6MT FR-S
#28 |
Efficiency at low rpm is only compromised with poor design, and low load efficiency is ALWAYS poor. Proper gearing ensures proper load, and direct injection or variable valve timing ensure good combustion at low speed. Tuning an engine for greater max power is not why a 2ZZ-GE gets only 30mpg on the highway while a civic with its 1.8 can cruise along at 45mpg. The variable lift actually makes low rpm combustion quite efficient.
When you throw a turbo on you're changing the equation quite a lot, but many performance oriented designs are not inherently far worse for fuel economy. An engine typically doesn't run well below 1500 rpm (that is, the efficiency starts to go down as you demand more load from it), so there are limits to how high you can go on displacement before you cannot get efficient street driving no matter what, but you don't hit that until you go past 3L. Also, not all things are a performance/efficiency tradeoff. If you want a mindblowing example, high rpm cams + direct injection like we have on the FA20 give poor low rpm VE, but the direct injection maintains combustion stability and efficiency and increases thermal efficiency. That's right, the high rpm torque bias will give you better mpg around town. |
| So what is the official weight? | brillo | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 05-03-2020 06:11 PM |
| Official Weight Reduction Thread - Sort of... | merlin2111 | Off-Topic Lounge [WARNING: NO POLITICS] | 77 | 10-07-2012 06:09 PM |
| How can i shave weight? | fernan2 | BRZ First-Gen (2012+) -- General Topics | 15 | 11-01-2011 11:31 AM |
| Another Rumor About Weight | Enzie | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 10-23-2011 03:00 AM |
| Weight of FT-86? | Levi | Engine, Exhaust, Transmission | 38 | 06-14-2011 11:43 PM |
