#1359 |
Drives: ‘16 4Runner, ‘19 Corolla HB
Weight gain will be marginal. Driver weight differences will be on the same order as the weight added by the aero kit. The whole bumper cover on my old 2.5RS was probably 10lbs or so. Exhaust may be lighter than the standard one to cancel out the difference (I doubt it, but who knows.)
#1360 |
The Stig's German cousin
Given the limited numbers and extra cost, no way the RS 1.0 stays classed with the base model. The SAC hasn't forgotten the lessons from the MSR and Z0K so quickly. And if they have, well, TTD looks inviting...
| The Following User Says Thank You to renfield90 For This Useful Post: | Kido1986 (08-14-2014) |
#1361 |
i kill cones.
Drives: around cones in a parking lot
What about trd springs? I'm pretty sure they're an option now.
If they are, are they allowed?
2013 SSM BRZ Limited 6MT
#1362 |
Drives: BMW 135i, soon to BRZ
#1363 | |
Drives: Toyobaru FRZ
#1364 |
Yes, but how much weight can you realistically exert on your own? Using a jack allows you to leverage the weight of the car and hold it in place while you tighten.
#1365 |
Drives: 2014 BRZ
#1366 | |
I figure the camber gained will be based upon the amount of play in the holes where the top hat studs go. Even if you can apply 500 lbs of force vs 50lbs, as long as the studs on the top hat are as close inward as the mounting holes will allow, that'll be your max camber gained. If you think differently, I'd like to understand that. Just trying to see what difference it'll be from what I've done already using two people. Not hard to loosen the 3 nuts and use the jack if its better. |
#1367 |
I tested those methods on my WRX which has the same front suspension. There are no bushings or anything so having a friend push is just as good as using a jack, the jack just lets you do it by yourself.
Agree on the RS 1.0, I'm not sure they'll even class it and if they do it'll get stuck in BS. |
#1368 | |
#1369 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
I hope I can drive somewhere close to what I did at today's private pre-nat TnT. My car is on fire
#1370 |
Drives: 2013 BRZ, 1994 Miata
For those who have run the 235/45-17 Dunlop ZII. What kind of tire pressures were you running?
#1371 | |
Drives: 2013 Cayenne turbo
![]() I'm running that size, but different brand of tire (and also 225s up front), with only crash bolts. 35.5 psi front and 36 rear felt really nice last time out.
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
#1372 |
Drives: 2014 SWP BRZ Limited
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
