#1135 | |
Drives: 2014 BRZ Limited, 2013 Focus ST
#1136 |
C-Street AutoX
people have reported that it fits just fine I may try it myself but right now I'm content with a staggered set up.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
#1137 | |
Pawn in game of life
Drives: 19 STX BRZzz
Autocross nut
| The Following User Says Thank You to AustinTX For This Useful Post: | Wepeel (05-30-2014) |
#1138 |
C-Street AutoX
I can probably do this for you... If they make a good course this weekend, I'll try it sunday. Strange local club format allows us to run whenever we want essentially....
| The Following User Says Thank You to SeanRTR For This Useful Post: | AustinTX (05-30-2014) |
#1139 |
The Stig's German cousin
#1140 | |
Senior Citizen
Drives: Scion FR-S
We noticed good lateral grip vs 225. Feel after initial turn in is a bit more vague and there may be a slight increase in understeer but it can be dialed out with tire pressure, fsb setting/choice, alignment. |
#1141 | |
Drives: N/A
I have my second autox in the BRZ this weekend, fully stock. The last time out I felt like I was sliding all over almost the entire time. Air temp was about 80 and loose pavement. My questions are: 1. How should I set up my alignment (caster, f/r camber, and f/r toe) for autox and DD without too much excessive wear on the Primacys? 2. What PSI should I be aiming for in the autox? Last time PSI was around 38-40 (with my cheap gauge). It should be around 90 air temp this weekend and same location. |
#1142 | |
Drives: Traded BRZ for Supra
#1143 |
Drives: N/A
But right now I still have the stock tires. I hope to get new tires in a few months. So I am looking for recommendations with my current setup.
Sent from my SGH-M919 using Tapatalk
2014 BRZ, SWP, OFT, Kosei K4R 17x7 with ZII SS
#1144 |
Drives: 2022 Toyota GR86
get the crash bolts for the front and max out the camber.
castor really isn't adjustable. 0 degree toe in front. +0.1 toe-in for the rear tires. camber isn't adjustable. tire pressures: 35 psi all around. the OEM tires do not grip so no need to change psi from stock. have fun!
Eric
2022 Toyota GR86 Steel |
| The Following User Says Thank You to edj For This Useful Post: | travisb (06-04-2014) |
#1145 | |
i'm sorry, what?
Drives: Canada
after two years on the stock tires doing a bit of track and a bit of autocross I can tell you that just keeping them at stock pressures works perfectly well, there's nothing there for you to chase
| The Following User Says Thank You to 7thgear For This Useful Post: | travisb (06-04-2014) |
#1146 |
Hell be chasing the back end of the car as it passes him if his experience is anything like mine with the car in 100% stock trim
#1147 | ||
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
| The Following User Says Thank You to Kido1986 For This Useful Post: | travisb (06-04-2014) |
#1148 |
Drives: N/A
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
