#1107 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
I wish I was going
I've never been able to make a Pro. I have a crap paying job with shit for PTO. I was going to make Blytheville this year until they announced they moved it to the weekend after Dixie
#1108 | |
I'm asking because I'm currently running 235/40 17 on 17x8 +45 and I cannot fit a finger between the wheels and the front struts - but would once like to try the A6 in 245/40 17 too. Also, has anybody run the A6 in 225/40 17 or does this size overheat too quickly? |
#1109 | |
Dodging cones
Nearly everyone is using the OEM camber bolts with ~.8-1.5 degrees of negative camber
| The Following User Says Thank You to Kido1986 For This Useful Post: | rx3 (05-26-2014) |
#1110 |
The Stig's German cousin
Here's my favorite wheel/tire size calculator: http://rimsntires.com/specspro.jsp
This shows the 17x8 +45 wheel is 7mm closer to the suspension parts than stock. I don't know how much clearance we have with stock wheels, but there you go. If you're running race tires that run a bit wide, add to that a little more. I ran 225 Goodyear DOT R comps last year and didn't have overheating issues. I don't think the A6 will be any different. At any rate, this year there's the A7 on tap. No word yet on which one is actually faster, although I think Hoosier is smart enough not to release a slower tire. |
#1111 | ||
I haven't seen any reviews on the A7 as of yet, but apparently some have already got them: http://www.autocross.us/forums/topic...ill-a7-follow/ And at least the harder version is apparently not faster but more consistent and does require less camber: http://detroit-scca.org/e107/e107_plugins/forum/forum_viewtopic.php?44836 (which would be an advantage for our cars). |
#1112 |
For most people, I'm going to say yes (with no solid data to back that up, mind you, other than my own meandering experience). I have a much stiffer front bar than most so the additional grip would probably push the balance of my car so far towards understeer that I might actually be slower. I'm sure I could make it work, but I'd need to rethink my setup and my driving style.
I think everyone has a softer bar than me and the additional rear grip will push them closer to neutral, not further away. The keywords in both paragraphs are "additional grip," because that's what the 245 gives you. |
#1113 | |
C-Street AutoX
#1114 | |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
#1115 |
Pawn in game of life
Drives: 19 STX BRZzz
Anxiously awaiting the brain dump from spring nationals Rexpelagi
Autocross nut
#1116 | |
C-Street AutoX
So I noticed like EVERYONE has jumped on board to the new Hankook RS3 V2 tires....what's the verdict on those tires at that surface? Better than ZII's? I wonder if a set of shaved R1R's will still be faster? Trevor Jones (TREV) noted that last year spring nationals the Rivals were actually better than the ZII's, but that was the polar opposite at Solo nationals when the course was more 'rubbered in'. I see he's bailed on the BRZ to run a Focus ST. Seems like a much less enjoyable car to autocross, but probably has a much better chance of winning the class at nationals than a twin in CS. Last edited by SeanRTR; 05-28-2014 at 01:49 PM. |
#1117 |
It is not as refined or connected as the BRZ but I would say I have enjoyed autox'ing it more than the BRZ thus far. If I had to give up one of them it would be the BRZ. However if the BRZ was in full STX trim, I would prefer that over the stock FoST for autox. I hope they they don't bury the FoST as it is a GREAT value for the money and best all around daily car I have owned.
#1118 | |
C-Street AutoX
#1119 | |
I'll miss running with you as well Sean and the other C Street drivers. I will do my best on continuing to stir the pot I have Z2's (245/45R17), RS3 ver2's (255/40R17) and Federals (255/35R18 Front/245/35R18 Rear) for the Focus. I left the RS3's at home based on the forecast for Lincoln as I had no wet weather experience with them yet even on the street. I was also a single driver and the temperatures looked like they were going to be on the cooler side. I ran the Federals for the Pro on the first day AM session (dry). I then switched to the Z2's in the afternoon (dry). I went a couple tenths quicker in the afternoon on the Z2's but course conditions could have attributed to that. I was a couple tenths quicker on the practice course on the Federals (dry) but there was less room to stretch the cars legs and the .7" taller Z2 could have created that gap. For the Tour, I ran the Federals as it was supposed to rain and I wanted to try them in the wet on concrete since I had already tried the Z2. They are also .7" shorter in diameter and the courses looked like they would not require the taller 245/45. My 2nd and 3rd run on Day 1 of the Tour was wet for 2nd runs and then drying a bit for 3rd runs. I did leave the traction control full on for my 3rd run on day 1 of the tour for grins so the time is slower than it would have likely been full off (how I ran all other wet runs). I like the Federal better in moderately to heavy wet conditions. The Federal and Z2 are a toss up in drying or dry conditions IMO at least at Lincoln on concrete. The Federal has better longitudinal grip/feel (helps the FoST more than it would the Twins) and the Z2 has better lateral grip/feel. I think the Z2's will last almost twice as long as the Federal which somewhat negates the price savings. Forgot to add that I have driven a FiST. It was at a practice session. I had run about a dozen runs with my FoST and then hopped in the FiST and got within .2 seconds after two runs. The course was more transitional and a bit tighter. On those types of courses, the FiST will definitely be competitive if not the car to have. The primary purpose for me buying the FoST was as a daily driver. I considered the FiST but it was just too small for what I wanted. |
#1120 | |
Drives: 2013 Subaru BRZ
Trevor even raw-timed everyone in CS except Fenter on the east course and probably would have done the same on the west if not for the rain. Definitely excellent driving Trevor!
-John L.
2011 BMW M3 - 57 FS 2007 Ford SGT - 57 FS 2013 Subaru BRZ - Sold |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
