Sam Strano
Old 03-25-2014, 02:05 PM   #897
vroom4
Has anyone had any problems with lifting the rears? I havent seen it.
vroom4 is offline   Reply With Quote
Old 03-25-2014, 02:31 PM   #898
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by 7thgear View Post
making one end stiffer vs completly unhooking something are entirely different things
no swaybar = 100% independence, the inside tire can droop all it wants without any interference from the loaded tire
I know the theory. How is this relevant for C Street in this car? I'm yet to hear any report of rear tire lift in this class+car. And if there are a few from really gripppy lots, I'm sure those are minor enough so that the bigger FSB is enough to fix those.
dsgerbc is offline   Reply With Quote
Old 03-25-2014, 02:36 PM   #899
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
gives people something to experiment with
also, you're assuming everyone has the funds for a swaybar
for instance, this year my budget went towards tires, pads and a datalogger. Next year i hope to have enough for a swaybar and maybe dampers.
so for this year, unhooking things is my only tunning option
although feel free to send me a strano bar or similar, i'll gladly put that on.
Old 03-25-2014, 03:24 PM   #900
dsgerbc
I'm assuming anyone can play with tire pressures. I'd spend the money on a good tire temperature gauge before I spend it on FSB (or data acquisition for that matter). You'd learn a whole lot more in real-time.
One can do a lot with tire pressures, especially someone who's willing to compromise overall grip by disconnecting RSB.
I'd argue for trying really high tire pressures up front (but you'd need a tire temp gauge to tell if you're getting high enough), instead of disconnecting RSB.
Old 03-27-2014, 11:36 AM   #901
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Okay
So some local pricing finally came down and I can get a set of Yokohama AD08R for around 1100 dollars (CAD) all expenses in, to my door.
I want to do a competitive run at C-Stock this year, my only mods will be camber bolts, otherwise the car is stock and there is zero budget for anything else.
Reading the limited reviews, it seems that I should go with the 245/45/17, with the 45 vs 40 to help with the pinching.
However, given that i’m on a stock swaybar, I’m wondering if this might be too much and if I should go down to 235/45 instead.
Although given the price, im also wondering if I should look for ZIIs instead, but finding a fresh set will be hard around here :/
Yokos are damn expensive.
Old 03-27-2014, 11:43 AM   #902
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
245/45/17 will be quite a bit taller than stock. I would not attempt.
Autocross nut
AustinTX is offline   Reply With Quote
Old 03-27-2014, 11:50 AM   #903
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
26mm if the calculators are right..
arn't people after a bit taller gearing though? Or i guess that's area dependent..
Old 03-27-2014, 11:52 AM   #904
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Tirerack.com doesn't deliver to Canada? With the price difference between what you are going to spend on the Yokohama's and the ZIIs, you could easily get a front sway bar.
DylanFRS is offline   Reply With Quote
Old 03-27-2014, 11:59 AM   #905
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Okay
For the longest time, I was in favor of the taller gearing. However, I have since changed my mind, the numbers in a best case scenario didn't make a case for the slowed acceleration.
I'd highly recommend the ZII and I'd definitely go 235 instead of 245 on a street tire. I'm hoping to get a chance to do a test of 245 ZIIs on 7" wheels soon though.
Just an FYI, my 235/40s came out to actually be minutely taller than my 215/45s even though specs said they would be slightly shorter. You an see it when they are stacked next to each other. Also, my 4th gear rev limiter (obviously not autocrossing at that time) picked up 1mph (108 vs 107). Extremely minute.
Go with the lighter, shorter, quicker accelerating tire if you ask me.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
7thgear (03-27-2014)
Old 03-27-2014, 12:09 PM   #906
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i did the math on the ZII's from tirerack, i'm not winning after conversion, shipping, customs and taxes . Well, maybe a little bit, but not enough for a swaybar. Also in this particular case i really do want to support local.
also from what i understand the ZIIs being sold right now are last remaining stock.. new ones wont hit shelves till November?!
The Following User Says Thank You to 7thgear For This Useful Post:
DylanFRS (03-27-2014)
Old 03-27-2014, 12:16 PM   #907
Wepeel
Drives: '13 BRZ Ltd
Interdasting...
Wepeel is offline   Reply With Quote
Old 03-27-2014, 12:24 PM   #908
Kido1986
Dodging cones
Kido1986's Avatar
Unfortunately true. Now is the last chance to order ZIIs for a while
Old 03-27-2014, 12:32 PM   #909
vroom4
And then we get star specs (banana dance).
Old 03-27-2014, 01:09 PM   #910
itzmik3
DBC Racing
itzmik3's Avatar
we have tried various sizing.
215, 225, 235, 245
to be honest the 245 has felt the best out of all the tires.
the way we have our car set up it is very neutral with no worries of under or step out oversteer.
i mean however in the end it all depends on driving style.
to be less than half a second behind a high caliber driver in a 370z is good enough for me. on the previous 225 set up we could not come even close to him.
#194 SM
itzmik3 is offline   Reply With Quote
The Following User Says Thank You to itzmik3 For This Useful Post:
Churg (04-04-2014)
Search this Thread:
Advanced Search
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
