#883 |
Drives: '13 BRZ Ltd
So if you do the math for total wheel rates in roll for the BRZ, and reduce it to natural frequencies, in completely stock form the BRZ has a front:rear natural frequency bias of 1.24 (Front Roll NF / Rear Roll NF). Adding a Strano front bar shifts that to 1.55 (more understeer). Keeping everything stock and removing the rear bar shifts it to 1.60, so a little more under-steery than the stock with the Strano bar but not too much so. Balance wise I would think it would be pretty similar but obviously the chassis will be moving around more.
Removing the rear bar will remove about 79 lb/in of rate from the rear wheels in roll and reduces overall roll stiffness by about 13%. |
#884 |
Drives: BRZ(sold), STI
Not sure what's minimal, but anyway.
On a really bumpy road it could help - sure. But I'd rather not drive on those lots where disconnecting RSB helps. In the rain? You mean for putting down power? Maybe (I'm not sure it's gonna help much short of standing water or 1st gear in this car), but you're still better off with a larger FSB and disconnected RSB if you want minimal load transfer in the rear. I just don't see the point of lowering overall grip to take care of mild oversteer. Just mess with tire pressures to give rear a bit more grip relative to the front. |
#885 | |
Drives: BMW 135i, soon to BRZ
| The Following User Says Thank You to mrazny For This Useful Post: | Kido1986 (03-24-2014) |
#886 |
i'm sorry, what?
Drives: Canada
because physics?
weight transfer is dictated by center of gravity, track width, and weight. nothing else during roll, the center of gravity shifts slightly but not enough to really impact the general state of things. control of roll in production cars is primarily there to reduce dynamic alignment changes and keep the tire in perfect angle to the road. http://www.motoiq.com/MagazineArticl...-transfer.aspx
#887 |
DBC Racing
[ame="https://www.youtube.com/watch?v=pivMquF2Sqw&list=UUfrcGo4iul6xqAvyWGlLR4w"]CSCC - Championship 3/23/14 - YouTube[/ame]
video from this weekend's racing. this was the closest I have been able to get to Jeff Stuart in the 370z (.478) i had a couple sections that i definitely could be cleaned up, but overall very happy with the result
#194 SM
#888 | |
Drives: Subaru BRZ
You were actually faster than Jeff after run#2...
#889 | |
Drives: JAWS
75.093. I need to work on my hand position, and a lot of other things! [ame]http://youtu.be/_ygZFemsEyU[/ame] |
#890 | |
DBC Racing
yeah i spoke with jeff after all the runs were over and he said he was actually a little worried after my 2nd run. sadly from there i was left in the dust.
#194 SM
#891 | |
DBC Racing
it was super hectic dialing in the C-Street car and doing shakedown runs in Max's STX BRZ maybe at the next practice
#194 SM
#892 |
Drives: JAWS
No worries at all man! That'd be great. I think I'll try and run in the next Saturday practice also.
#893 | |
But that's off-topic basically. Like I said, I see not point in reducing total roll stiffness of the car for regular autox. |
#894 |
Drives: frs
the main reason autoxers unhook the rsb is to help keep the inside rear wheel planted when applying power out of turns - helps the torsen work
#895 | |
I might be wrong, but I don't believe the rear inside lift is a problem in this car in C Street. It probably is in STX. |
#896 | |
i'm sorry, what?
Drives: Canada
no swaybar = 100% independence, the inside tire can droop all it wants without any interference from the loaded tire
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
