#827 | |
AutoX Nut
Drives: 2022 BRZ
My new STX wheels have rubber valve stems as well. Glad I went this route.... |
#828 | |
Drives: 2013 Subaru BRZ
If you are in a corner and the rear starts to slide you actually should add partial throttle to transfer weight to the back and settle the rear of the car. If you are accelerating and the rear starts to slide, you want to back off the throttle slightly but generally not all the way, as a quick throttle lift will have the same effect as above and unload the rear too quickly. I'm thinking you meant under acceleration, but since you didn't specify I gave you a silly O.o face. :-). A good way to think of it is that the gas pedal and brake pedal are weight transfer devices, at least when it comes to balance. It is the same logic with why trail braking into a corner aids turn-in - a little extra grip where you need it and less where you don't.
-John L.
2011 BMW M3 - 57 FS 2007 Ford SGT - 57 FS 2013 Subaru BRZ - Sold |
#829 |
Drives: 2006 Honda s2000
Video and SoloStorm Data from the Dixie National Tour this weekend:
[ame="http://www.youtube.com/watch?v=EmgXBHwawgs"]2014 Dixie National Tour - C-Street BRZ #99 - YouTube[/ame] Huge thanks again to Henry for letting me run the car. These cars are way too much fun in C-Street. Ran out of gear a few times, but nothing that would want to make me put a taller tire on the car. Even with a few big acceleration zones, I never felt the car needing more power, I was able to be pretty agressive with the throttle at or before apex. With it being a Strano course, there was a lot of slow in, fast out. It was nice meeting a few of you FT86 guys. Deff a good group of people. Car setup is typical C-Street. I really like the Z2s after this weekend, and have a set sitting in the garage for my STR car. |
#830 |
I should add to this. Andrew Pallotta used the same delete (Nameless) in STX until he got his full exhaust, and he never had an issue with sound. I know he ran several national events with that setup, so you should be ok.
-John L.
| The Following User Says Thank You to Rexpelagi For This Useful Post: | Sccabrz192 (03-19-2014) |
#831 | |
Drives: Subaru BRZ Limited M/T
I see your point. After driving for over 40 years, I do so much by instinct that I almost can't explain what I do. Your explanation is so much more eloquent that I take my hat off to you sir. YA what he said. Sent from my iPhone using Tapatalk |
#832 |
Drives: JAWS
Some really great info in this thread, especially for an autocross noob like me.
I'm going to be doing my first autocross this Sunday..should be about 70 degreesF out. I'll be running the stock Michelins and stock alignment settings. With very little or no camber are the shoulders of the stock tires going to be done for after a day of autocross? Also, would bringing a water sprayer to cool the tires inbetween runs help me a lot? |
#833 |
i'm sorry, what?
Drives: Canada
you'd need to try really really really hard to kill the stock tires in a single day
i would just add extra air and save the water for yourself. |
| The Following User Says Thank You to 7thgear For This Useful Post: | JB86'd (03-19-2014) |
#834 |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
I've run 4 events on the stock tires:
8 runs (2 drivers @ 4 runs) 12 runs (3 drivers @ 4 runs) 8 runs (2 drivers @ 4 runs) 8 runs (2 d @ 4 r) for 36 runs on the stock michelins and also have about 20k road miles on them and still have 7/32's tread depth. they are pretty resilient.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
| The Following User Says Thank You to Sccabrz192 For This Useful Post: | JB86'd (03-19-2014) |
#835 | |
Drives: JAWS
#836 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
I'd pump them up for ~40psi. Keep check on them, lower down to 40 after each run.
High PSI means less roll over, less wear.
| The Following User Says Thank You to Kido1986 For This Useful Post: | JB86'd (03-19-2014) |
#837 | |
Detroit Region, MI
I should also note this lot is asphalt and a bit gravely so it's pretty friendly on tires compared to some of the cheese grater concrete surfaces. This year I'll be on ZII's, so I won't be running the OE's any more.
#838 |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
Ugh, i just got my Koseis w/ tires mounted from Tirerack with those stupid stems in them. I really don't like the metal valve stems because I have more troubles quickly checking pressures with them too.
#839 |
Wrong Wheel Drive :(
Drives: FiST
Thank you sir for making this as simple as possible.
Ford Fiesta STmountune wrong wheel drive club of america |
| The Following User Says Thank You to zohaib For This Useful Post: | Kido1986 (03-20-2014) |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
