#645 |
Senior Citizen
Drives: Scion FR-S
Tried stock, Hotchkis, Strano, and Tanabe. I like the Strano and Tanabe the best. The Tanabe seems a hair stiffer and installation without issues. I may go back to trying the Strano bar again, but am happy with the Tanabe set up for now. Not a fan of their bushings. If anyone was to use the Tanabe bar, I would recommend picking up a set of Whiteline 22mm bushings.
It is a matter of preference. My set up is very tossable and neutral. Minor oversteer or understeer can easily be created with shock tuning. Seems to work for our lots/courses. YMMV. |
#646 |
Drives: Subaru BRZ Limited M/T
I find the same results with a 20mm adj. Super Pro. Very neutral.
The only time I found heavy pushing was on our wet test n tune on asphalt. But that is me, and I ain't no expert. Sent from my iPhone using Tapatalk |
#647 |
DBC Racing
[ame]http://youtu.be/ToApoPpefsc[/ame]
Here is my run from this past weekend CSCC event. My quickest lap was a 55.642, but still with a lot of things to clean up. It was good enough for 1st in S2 and 9th overall in PAX
#194 SM
#648 | |
My two cents on sway bars is that the 20MM Whiteline is awesome and can be that way even with a street friendly alignment. I haven't had too many people drive my car but the ones who have had made comments similar to:
I had an issue with the end link boots ripping on one of my Whiteline adjustable links. Whiteline sent me a new set, no questions asked and just asked that I return the old ones at my convenience so they could see why the boot ripped. Excellent customer service. I have been considering going to STX and it is nice that I could at least try the bar on its stiffer setting. If I can make it work well, I don't have to buy another bar ![]() Depending on driving style and car setup, you may not even need a bar. Lance ran without one on his FR-S and was very competitive. He favors a loose car though and can drive the piss out of it that way |
#649 |
Drives: 2013 Subaru BRZ
I've thought the same thing, even though I know that the Strano bar clearly works well. I was running RS-3's on stock shocks though, so that is much different than the Nationals setup that actually worked. I'll probably run the bar though and just get ZII's to replace the barely-used RS-3's. I will be running an unorthodox setup on my RX-8, so I should play it conservative with the BRZ.
-John L.
2011 BMW M3 - 57 FS 2007 Ford SGT - 57 FS 2013 Subaru BRZ - Sold |
#650 | |
Drives: Scion, Honda
#651 |
i'm sorry, what?
Drives: Canada
is this a fair hiearchy of stock mods from most to least important?
tires camber (alignment) brakes bar shocks wheels exhaust
#652 |
AutoX Nut
Drives: 2022 BRZ
I think your priority list is pretty darn good there. The only thing I might knock down a bit is the brakes. I think the stock brakes are pretty darn good and brake-fade is not an issue with AutoX unless it's ridiculously hot outside and you're hot-lapping with a co-driver on a long course.
#653 |
Drives: '13 BRZ Ltd
I think bar and shocks are about even - for a BRZ, I would try shocks before the bar. FRS I'm not sure since it oversteers more, but I haven't driven a stock FRS. And brakes also I'd move both of those above brakes. Wheels and exhaust should be minimal.
#654 |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
I would rank as
Tires Bar Dampers Wheels Brakes Exhaust Intake filter I left off alignment because that is an adjustment more than a modification. I rank brakes very low because on a momentum car a pad with lots of initial bite can be counter productive... In this scenario a lesser pad could be better as long as it is consistent. Sent from my iPhone using Tapatalk
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
| The Following User Says Thank You to Sccabrz192 For This Useful Post: | FastWhite (02-11-2014) |
#655 |
i'm sorry, what?
Drives: Canada
is the OEM pad lesser enough thought?
![]() i ran the last two summers on the OEM pads and tires. This year i've finally got the scratch for tires and a bar (along with a full season's worth of entry fees) but debating whether i should go for that extra pad bite. ive been doing autocross but never at a level where i'm shooting for top 5... which i want to do this year, but on the smallest budget possible.
#656 |
If anything less "bite" is better (IMHO) as long as the car still stops well, because it allows you to weight the car's nose without upsetting the balance.
#657 | |
Detroit Region, MI
BFG Rival 225/45/17 Strano FSB Koni Dampers OE Crash Bolts Kosei K1TS/K4R wheels Stoptech Street or EBC Yellow brake pads Nameless or Berk muffler delete K&N Drop-in filter IMO you could easily stop after the crash bolts and the car could still be plenty competitive. The full monte is in the neighborhood of $3,300 to go from showroom to C-Street ready. could easily vary from $3,000 to 4,300 depending on what you choose for wheels, exhaust, brakes, and if you get a Swaybat with or without aftermarket end links.
#658 |
i'm sorry, what?
Drives: Canada
now that the Bilstein HDs are out (B6), would you consider those over Koni?
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
