Sam Strano
Old 11-01-2016, 12:01 PM   #4523
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I mean... you can use a TRD bar, but just one and no other sway bar upgrade.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 11-02-2016, 03:11 PM   #4524
ryan t
Drives: frs
Has anyone tried 225 front 245 rear? My car is completely terrible on launch. We run on sealed slick asphalt and gets no forward bite.
ryan t is offline   Reply With Quote
Old 11-02-2016, 09:00 PM   #4525
renfield90
The Stig's German cousin
The launch is not that important at an autocross. Why handicap your car's handling for 99% of the course so it does 1% of it slightly better?
245s square would be a much better idea, but ultimately you're going to have to live with the reality that there's not much you can do to generate grip on some lots.
The Following User Says Thank You to renfield90 For This Useful Post:
Shark_Bait88 (11-02-2016)
Old 11-04-2016, 02:17 AM   #4526
duqx
Drives: 15' FR-S, 02' 911
I just got my car a couple months ago, mostly for road course, but I have been thinking it would also be fun to do some autocross. At this point I am trying to stay as close to stock as possible to learn the car, so I would prefer to go into the c street (or d street now?).
The only problem I am seeing with my car is the oil cooler. From what I have read, it is not allowed in the "street" class. I do take my car out to road courses, and was seeing close to 280* oil temps, so the oil cooler is very necessary for the car.
Any suggestions on the best route to do both autox and road course? It would be quite a pain to remove/re-install the oil cooler all the time. With no other options, could I leave everything installed and just disconnect/plug the lines at the oil sandwich plate?
duqx is offline   Reply With Quote
Old 11-04-2016, 02:50 AM   #4527
renfield90
You would be classed in CS this year, and starting January 2017 you will be DS as long as you have OEM (non-TRD) springs and at least one OEM (non-TRD) sway bar (let me know if that didn't make sense).
For local events, pretty much nobody will give you grief over an oil cooler unless you're beating a lot of people.
duqx (11-04-2016)
Old 11-04-2016, 04:00 AM   #4528
duqx
Thanks for the info. Have not done autox before, so I don't plan on beating too many people, but would be nice being in a class more competitive for my setup without pulling out the oil cooler.
My plan for other mods is to do camber bolts and a sway bar (need to look into the options) to take advantage of what is awllowed in the class
Old 11-04-2016, 10:52 AM   #4529
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
RE: sway bar
I went too big (25mm hollow Hotchkiss on the front), and I kinda regret how very big it is. Go with one at least a little smaller then mine.
JohnJuan is offline   Reply With Quote
Old 11-05-2016, 11:04 AM   #4530
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
Originally Posted by JohnJuan View Post
RE: sway bar
From my experience, the car definitely goes faster with a Hotchkis bar on the softer setting, than it does with the end links through the stiff hole.
Cueman is offline   Reply With Quote
Old 11-22-2016, 02:58 PM   #4531
TMF
TMF's Avatar
Drives: '14 FRS TT5
Sooo is everyone jumping to DS?
I'm contemplating the move, which means I have to figure out a new setup. I never drove my FRS in autox before putting on the TRD stuff, and I'm not sure what to expect. Is it best to up-size the front or rear sway bar? Or is it course dependent?
My FRS in TRD form is fairly easy to rotate, while some other locals were running a stock BRZ all season that was fairly pushy. I know the spring rates in the FRS are slightly different, so it is supposed to be a bit easier to rotate the FRS in stock form vs the BRZ. So...bigger front bar for the FRS, or will that make it too pushy?
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 11-22-2016, 04:25 PM   #4532
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Shouldn't be much to figure out, the setup will be largely the same, just no TRD stuff (in DS). Larger front bar, wheels/tires/catback is the common recipe.
With the stock front bar you will have too much body-roll in slaloms and fast transitions. You might get a little bit of exit understeer but it should be manageable. From my experience anyways...
justinco is offline   Reply With Quote
Old 11-22-2016, 06:35 PM   #4533
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
I think you'd be crazy not to switch if you plan to run NTs or have an ND in your region. The ND Miata is 1 second faster on average on a 60 second course, rain or shine.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 11-22-2016, 11:48 PM   #4534
dutchman1
Drives: 2017 86 6-Speed
Just picked up a 2017 86. It'll be set up for DS (or CS, wherever they put it) and I'll be daily driving it. I'm coming from an STR (ish) Miata, just wanted something with a bit more footspace lol
Just wanted to say thanks for the thread everybody, definitely saves some time getting pointed in the right direction
Supposedly the 2017 has slightly stiffer front springs and slightly softer rear springs than the previous FR-S. I'm going to take the car to two small local events bone stock this month. After that I'm planning to pick up some dedicated wheels/tires, and to stick on a Strano front sway along with some crash bolts and set my alignment. I'm thinking max camber (duh), 1/16" total toe out in the front, 1/16" total toe in in the rear. I'm gonna leave the shocks stock for the first season I think, probably buy konis and a catback for next season.
Am I on the right track here alignment wise?
dutchman1 is offline   Reply With Quote
Old 11-22-2016, 11:55 PM   #4535
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Sounds like you are on the right track to me. I run neutral toe in the front, but my cars are STX.
If your car does not have TRD parts it should be DS. Curious how the new gearing will work in the stock class, it tops out at 57mph in 2nd.
What gen was your STR Miata? The ND's look like a ton of fun in STR.
Old 11-23-2016, 01:10 PM   #4536
solort
Drives: Series 10 FRS
2017 is not listed as moving from CS to DS. Only 2013-2016 w/o TRD stuff.
http://cdn.growassets.net/user_files...pdf?1477062058
solort is offline   Reply With Quote
Search this Thread:
Advanced Search
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
