#29 | |
Drives: Some rust bucket
If it helps, the bottom bolt doesn't have any play, and I think that bolt takes more punishment than the top bolt. I'm using the top plates that were included in the Eibach R2 coilovers. |
#30 |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
Any of you guys see the Street Tire comparison in the June issue of Grassroots? I just got mine in the mail yesterday and am looking through it a bit today at work.
I am kind of bothered that they didn't test the RS3 and that the test they did was on a STS prepped CRX. It sucks because last year when they did this tire comparo I had a ST Civic and they used a BMW. Now I have a car closer to the BMW and they did it on a car that is almost the same as the Civic... also, why no RS3s?! I can scan in the article and post it up if anyone is interested and it isn't available online. |
#31 | |
#32 | |
Drives: Whiteout FR-S
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#33 |
Drives: 2022 Toyota GR86
re: the FR-S/BRZ crash bolts
the Twins come with two different sized bolts to hold the steering knuckle to the strut. (14mm and 16mm?). the factory authorized crash bolt is the 14mm bolt. all you are doing is replacing the larger OEM bolt with the smaller one. so you end up with two 14mm bolts. There should be no worries about the crash bolt being strong enough.
Eric
2022 Toyota GR86 Steel |
#34 | |
Sheering the top bolt should be not a major concern. As long as they are installed properly and torqued I don't see how it is much more different than the OEM bolt. I would be more worried about small allen head lock nuts on camber plates slipping over that strut bolts.
#35 | |
Lost in Kansas
Everyone who is racing will soon be running both the crash bolts and top hats anyways. The real question is, how did you get 1.5* of camber out of them Dezoris? |
#36 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
I need to recheck for clarification but I believe the lastest Fastrack clarified that you may use Tophats OR Bolts. Not both
#37 | |
Dodging cones
#38 |
Lost in Kansas
I was reading that as "camber bolts" being defined as aftermarket. Technically the crash bolts are just there in case of a suspension problem after an accident. So the car is 100% OEM with them in right? Thus the only mod from stock would be the upper camber plates.
I think it is worth talking about because it is not completely clear to me. :happy0180: |
#39 | |
#40 |
Drives: Scion, Honda
Perhaps it is not too relevant, but could we also add what popular aftermarket rims/wheels are available and legal for the class?
I had a bear of a time finding 17x7 42-54 rims last year, so I'm still running the OEM rims. I still have not pulled the trigger, but I assume the Enkei and Kosei options are best? |
#41 |
The Enkei RPF1 wheels are your first (and really only) option.
The Kosei wheels are OK but if you are putting any tire on them wider than a 225 then you will need a 1/4" spacer on the front wheels and now you need longer lug bolts to get the lug nuts to fit properly.
Eric
#42 |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
Motegi Tracklites are also an option.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
