Sam Strano
Old 01-22-2016, 04:10 PM   #3991
chucky12012
Drives: 2013 Asphalt Scion FR-S
Originally Posted by sludge1300 View Post
Thanks man! Good call on that. Looking forward to our next event at Grand Sport! Funny timing, but I've been meaning to bother you specifically and haven't had a chance yet. I at the very least need to catch a ride with someone like yourself who can drive an 86 closer to the limit. Anyway, it's going to be a great season watching you guys battle it out in the old X class especially with DM driving an ND now.
Always feel free to grab a ride. See you out there next weekend.
chucky12012 is offline   Reply With Quote
Old 01-22-2016, 05:47 PM   #3992
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by TrqlessWonder View Post
Max camber rear? No real such thing. It's not adjustable. You can play with the rear subframe to get it even side-to-side though
Originally Posted by Briankbot View Post
Just to clarify: do you mean there is enough play in the linkage attachment points to the rear subframe to change rear camber slightly? All of the the rear linkage attachment points are connected to the subframe, so the only adjustment that can be achieved through moving the rear sub frame in relation to the body is track. I'm curious if you have actually been able to change your rear camber by taking advantage of play in the linkage bolt holes. Please do tell if so.
Not exactly. All that you can do is shift one side to the other, which I suppose is technically changing the camber, but it's not like you can choose it to be higher on both sides or lower on both sides. It's left or right only, not wider or narrower. You can really only introduce or correct the imbalance between the sides. Some cars alignments sheets I've seen posted had as much as 0.5* degree or more difference L/R in the rear. Doing this can help with that.
Mechanically, the upper and lower arms are connected to the same subframe so shifting it has no effect on camber.
The Following 4 Users Say Thank You to redlined600 For This Useful Post:
Briankbot (01-23-2016), DocWalt (01-22-2016), DylanFRS (01-25-2016), e1_griego (01-22-2016)
Old 01-25-2016, 07:26 PM   #3993
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Never mind on the BBS. Apparently BBS wants $300 more per wheel than they would for other sizes. They must only make the 17x7 on a per order basis or something...
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 01-26-2016, 02:33 PM   #3994
Mark99es
Drives: 2013 Scion FRS
Anyone running the Dixie Tour? This will be my first National event with the FRS and probably 2nd or 3rd event total with the car. Will be running 245's which I do not think will be a good tire for that lot but oh well. Look forward to meeting the FRS crowd!
Mark99es is offline   Reply With Quote
Old 01-26-2016, 05:57 PM   #3995
hayden55
Drives: 2013 FRS
Trying to figure out the magic tire as there are lots of size but usually all missing the size you want, like everybody knows. But I came across some Toyo R1R and they are 200 tread wear tires. Since the re71r is considered the tire to have how do the R1R's compare? Never heard of any comparison's and they seem like 140 tread wear cheater tires to me.
Thoughts?
(Tires are both 200 tread wear tho... )
hayden55 is offline   Reply With Quote
Old 01-28-2016, 05:21 PM   #3996
Locust
Custom User Title
Locust's Avatar
Anyone know anything about these wheels? https://www.japanparts.com/parts/detail/41593 (Am I allowed to link to this?)
Description: Tom's Forged Alloy Wheels 17x7.0J Silver: 6.0kg
6kg (13.23lbs) is INSANELY light for a forged OEM sized wheel. I'm not sure I even believe this...
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 01-28-2016, 09:13 PM   #3997
Biggins
Drives: Scion, Honda
I did a lot of this same research a couple years ago and gave up... I really wanted the RS Watanabe magnesium wheels for our size, but they were just crazy money. If I remember right, they were maybe 10lbs or maybe less?
I've just stuck to the Koseis that everybody has and a set of Buddy Club P1 Racing wheels for now. I did notice that Motegi has a light-ish
CS option available on Tire Rack again. I don't think it's the forged Traklites that they sold years ago, but it's another option!
Keep us in the loop with any others that you find!
Biggins is offline   Reply With Quote
Old 01-29-2016, 10:50 AM   #3998
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Thoughts?
R1R's are inferior in every way, even in wear/tire life. Having burned multiple sets of both of these tires, R1R's are just old technology. Very soft compound, but suffer from bad tread squirm, and soft sidewall, and they'll heat cycle out much quicker. The RE71R is so much easier to drive on, and will be significantly faster for new-amateur drivers, giving you much more confidence in slaloms. These tires are not even close in my opinion, there's a reason even the people running the 195-50-15 in STS even swapped to Re71R's (or Rival-S) this year.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
The Following User Says Thank You to SeanRTR For This Useful Post:
DocWalt (01-29-2016)
Old 01-29-2016, 10:54 AM   #3999
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I've got a set of Wats coming! But in 17x8 +35.
I was originally going to go with the magnesium wheels, but after reading about their tendency to break because they're more brittle; I decided not to risk it on the awful IL roads, and ordered the aluminum alloys. Not heavy, but not really light either.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 01-29-2016, 12:35 PM   #4000
gtslow
Drives: 2015 Halo FR-S
The Motegis at Tirerack are flow formed (cast) and something like 1.8 pounds per wheel heavier than the RPF1.
gtslow is offline   Reply With Quote
Old 01-29-2016, 12:42 PM   #4001
gtslow
They aren't listed in the newest Hyper-Rev 86 book that I picked up when I was last in Japan but I did remember that you can order Work Meister S1R in custom size and it looks like 17x7 is available. How much they would weigh, I don't know.
Old 01-29-2016, 02:33 PM   #4002
Locust
Custom User Title
Locust's Avatar
I have a feeling I'm just going to end up with RPF1s in spite of all my efforts to find something better. It's just too much work to find a forged option for CS.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 02-01-2016, 11:33 PM   #4003
Locust
Custom User Title
Locust's Avatar
2016 Colorado Championship Tour
Who all is going to the Colorado Champ Tour this year? I'm debating road tripping out there for it. What's the venue like?
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 02-01-2016, 11:43 PM   #4004
YawMomentRacing
YawMomentRacing's Avatar
Drives: 2013 Red 6MT Scion FR-S
I can't this year. I enjoyed it last year but it's at a different site this year which I have not been to.
Sent from my XT1254 using Tapatalk
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street
http://yawmomentracing.blogspot.com/
YouTube Channel
YawMomentRacing is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
