Sam Strano
Old 01-04-2016, 08:04 PM   #3949
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by vroom4 View Post
Fourth place at nationals this year...all brand new parts. Header coated with $waintech. It really is the last 3% that adds up, its crazy.
Oh yea! Duh, I just put 2 and 2 together from your comments on my youtube vids Now I'm really curious what you put together for new parts at that price point, hah.
It's great that various levels of prep can still be highly competitive in STX...I talked to David (3rd) about his car a few times 'cause his was also a pretty mild build.
justinco is offline   Reply With Quote
Old 01-04-2016, 08:24 PM   #3950
vroom4
im not Adam, I'd be another 0.5s back per day on a good day :p
vroom4 is offline   Reply With Quote
Old 01-04-2016, 08:47 PM   #3951
86_Freak
86_Freak's Avatar
Drives: 2015 FR-S
Originally Posted by Jawnathin View Post
Full Disclaimer, I'm not an expert, but I recall reading or hearing that the expansion of rubber brake lines were a thing of the past and not much of an issue with newer cars.
I would check in with people who road course a modestly prepared car regularly (similar to your street build) and see if they've had any problems with the factory brake lines. If they've reported no problems with OEM lines then go back to them and try for yourself.
Judging by your other post you will be attending National level events, I would not risk losing out on a big win or contingency money over something as silly as a brake line. Probably won't be protested but for someone who wants to move up a spot to win money or a trophy and a hard ass on rules they might throw down the paper. For locals it won't matter and no one would ever know.
Originally Posted by DocWalt View Post
FWIW I installed SS brake lines separate from other mods. They made absolutely no noticeable difference. Waste of money, IMO. The SS line are essentially just rubber lines with a stainless sheath that will protect from abrasion and resist some tiny amount of expansion. A big negative, they'll also hide rubber failure by not letting a rubber line balloon noticeably when there's a pinhole in the liner, so you can't feel or see the failure until the brake line bursts.
Interesting points. I did a little bit of research and it looks like the main advantage of SS brake lines is that they use a Teflon inner hose instead of a plain rubber inner hose (like the majority of OEM rubber brake lines), which actually has more to do with the SS brake lines being less prone to expansion to rubber brake lines than the steel braiding itself.
http://www.stoptech.com/technical-su...rake-lines-q-a
http://www.cquence.net/blog/how-stai...g-performance/
https://en.wikipedia.org/wiki/Braide...el_brake_lines
Anyway, I agree with Jawnathin, I will be removing the SS lines from my FR-S because I will be competing at local and National events. It will be nice to have the chance to get contingency. In KM, the only contingency I got when I got 2nd out of 35 karts at Nationals was $100 from Honda.
86_Freak is offline   Reply With Quote
Old 01-04-2016, 11:54 PM   #3952
TMF
TMF's Avatar
Drives: '14 FRS TT5
I did the same on my 05 Saabaru - did the stainless lines and kept the old fluid and crappy advance auto pads (I weren't too smart back then) and those lines didn't make a bit of difference, besides being a huge PITA to install, and stripping one of the nuts.
On my 08 STI, I did the opposite - upgraded brake pads (HP+), regularly refreshed the fluid (RBF600) and left the stock lines. It was a world of difference. I didn't even add stainless lines, but I doubt it would have done much.
On the FRS, keeping it in CS keeps it simple...can't touch the lines!
Originally Posted by justinco View Post
Yea, I agree with you. My build is missing lightweight seats, aftermarket diff, and lightweight brakes, everything else is covered.
$10k seems to be about the norm' for a highly competitive build, this is my second STX build and my last one was about $10k too (little more actually because the e36 had lots of old wear items to replace).
Sorry for hijack, back to regularly scheduled CS discussion
Yup, sounds about right. I had the idea that I might make the jump to STX next year, until the I started adding up the costs to be competitive. Then I realized that full prep for CS isn't that expensive, the car is very competitive for it's class (both within CS and on PAX for local events...err it was last year anyway), and I still truly enjoy driving it in CS trim, and still have plenty to learn to max out the full potential. So, staying in CS for now!
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 01-05-2016, 03:15 AM   #3953
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Hah, damn I am confused lol
Both classes are a lot of fun, and yea STX costs ain't cheap even if you go budget. I had run Miata's and RX 8's in CS the past few years until my STX BMW most recently. Couldn't let go of the STX fun/speed factor
Old 01-05-2016, 12:54 PM   #3954
DaWorstPlaya
Drives: 2016 FR-S
Just got a 16 FR-S. Drove one during the 2012 Scion FR-S First drive when they 1st showed up in the country. I've been wanting one ever since they 1st came out. Looking forward to join the CS fray.
Lots of great info on this thread.
DaWorstPlaya is offline   Reply With Quote
Old 01-19-2016, 05:51 PM   #3955
Jawnathin
Drives: Toyobaru FRZ
Subforum and thread is dead, so maybe a boring question to get some activity going...
Any feedback on alignment specs? Searching the thread but didn't see much discussion on it. I am thinking to max camber front and rear, then add a little bit of toe in on the rear? Hopefully it won't make the car pushy.
Jawnathin is offline   Reply With Quote
Old 01-19-2016, 06:18 PM   #3956
TrqlessWonder
Drives: 2014 FR-S
Was probably answered...but it was like a bazillion pages ago. So I'll slightly entertain:
Max camber front? Yep. Be sure to put the inserts in the holes if you bought full Konis
Max camber rear? No real such thing. It's not adjustable. You can play with the rear subframe to get it even side-to-side though
Toe? I run 1/16 out at the front and 1/16 in at the rear. Mostly helpful on-throttle rotation, and doesn't plow too bad on corner entry. Next year will be closer to 1/8 out up front.
**disclaimer: Not on the strano FSB, nor the TRD springs (yet). So YMMV.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 01-19-2016, 06:36 PM   #3957
Jawnathin
Thanks. Most of the discussion around alignment was about the full replacement Konis giving more camber. A few would post their settings, but no great discussions on recommendations and why. I admit I may have missed it though, it is a large and old thread.
Anyway, thanks for entertaining. I have the original Koni inserts that go into the OEM strut, so no problems there. Good to know about the rear subframe, I'll let my alignment guy know.
Last year I drove a BRZ w/ Strano Bar. It drove pretty well but a little pushy on corner exit if I got on the throttle too soon, I would love to make it a little more neutral. I never got it aligned though.
This year I'll be driving an FRS with full springs and TRD rear bar. I haven't autocrossed it yet so I don't have a baseline on what to adjust.
Reading through your comment, I am thinking a bit of toe out up front will help make the car not so pushy on corner exit and corner entry.
Old 01-19-2016, 06:48 PM   #3958
86_Freak
86_Freak's Avatar
Drives: 2015 FR-S
I'm curious on the difference between Strano front with the stock rear versus TRD front and rear sway bars. I have always heard that the FR-S really only needs the front sway bar and to just leave the rear sway bar as stock.
I recently picked up a used Strano front sway bar, so that's the route I'm going this year. If anyone wants to loan me the TRD front and rear, I'd be willing to test them back to back.
Old 01-19-2016, 11:04 PM   #3959
TMF
TMF's Avatar
Drives: '14 FRS TT5
Last year I was on the TRD springs, bars (F and R), and Koni full replacements. -2.2 degrees camber up front and I think -1.6 degrees camber in the rear. 0 toe all the way around. I ran the Koni's 1/2 turn from full stiff up front and 1/2 from full soft in the rear.
...And I got oversteer on corner exit on throttle. It was controllable if I eased into the throttle, but it definitely didn't push imho.
This year, I'll have to run the inserts in the front Konis and I'll probably lose about a degree of negative camber. I obviously haven't had a chance to try it that way yet, but my guess is I will still get some oversteer on corner exit.
From the factory, BRZ's understeer (typical Subaru) whereas the FRS has a bit more rotation. The TRD springs are "apparently" the same spring ratio when compared front to back, so the handling characteristics should be similar with the TRD's vs stock on the FRS.
I've always run 0 toe on my cars, but if I still have excessive oversteer on corner exit, I may try a hair of toe-in in the rear.
The Following User Says Thank You to TMF For This Useful Post:
Jawnathin (01-20-2016)
Old 01-20-2016, 03:42 AM   #3960
Lord09
Drives: 2015 BRZ
Apologies if this thread isn't the appropriate location, but I'm looking for a set of C Street wheels/tires.
If you have a set for sale in good shape, please send me a message.
Lord09 is offline   Reply With Quote
Old 01-20-2016, 02:31 PM   #3961
Jawnathin
New Fastrack is out with mention of the Koni issue...
#18376 Koni struts for twins
It has come to the SAC’s attention that there is a difference between the Koni strut housing and the OE strut housing
for the Subaru BRZ and Scion FRS.
Specifically, the OE strut housing ear’s upper mounting holes are of differing diameters forward and aft, while the Koni
strut housing ear’s upper mounting holes are both the same (larger) diameter.
There is no allowance for this. To be compliant with Street allowances, the Koni strut housing must be modified to
match the OE strut housing hole diameter and location. One method by which this can be achieved is by using a
stepped washer of the appropriate size to match the OE diameter and center the hole.
Koni N/A is aware of the issue and members are encouraged to contact them if necessary.
And three more denials of the BRZ getting TRD Parts
http://cdn.growassets.net/user_files...pdf?1453302263
Old 01-20-2016, 02:53 PM   #3962
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Pretty much what everyone was already expecting.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
