#3879 |
Drives: '14 FRS TT5
I really have no problem with the BRZ's running the TRD parts and I'm for a rule change. But I do understand the SAC's perspective, in that they do not want to make a one-off or even a "blanket" exception. There are other cars in similar situations (soltice vs. sky; wrx vs 9-2x aero; etc) but I don't believe they are as mechanically similar as the FRS and BRZ. It would be tough to write the rule properly without creating other loop holes. If you think you can craft the proper rule, draft it and send it to the SAC - but the idea of a "one-off" rule has already been shot down.
In the end, there have been plenty of cars historically that were competitive in their original Street class, only to be buried in a tougher class a year or two down the road. This is essentially what happened to the BRZ owners, and I'm sorry. FRS owners got "lucky" I guess. So if you own a BRZ and want to be competitive, I think your options are: trade your BRZ for a FRS, make the jump to STX, or get adopted by the elusive "insanely fast driver's planet" and return to earth as an alien.
Follow my NASA TT5 build here: JHill Motorsports
| The Following 2 Users Say Thank You to TMF For This Useful Post: | Jack Black (12-15-2015), strat61caster (12-14-2015) |
#3880 |
Custom User Title
Are the RPF1s still the go-to wheel for C-Street or is there a better option out there? Pretend cost +/- about 30% isn't an issue... Anyone have suggestions on this?
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#3881 | |
Drives: 2014 FR-S
Splitting them along the TRD parts-or-not line isn't something I'd oppose. For some reason, though, the SEB doesn't seem concerned about the lack of population/selection in DS. But the twin problem exists with the miatae as well. ES? NA's and NB's of all stripe and flavor (save for the MSM) are there, and not all of them are pointy-end competitive. Booting the MS-R to BS (and ZOK cars) was more of a nod to their relative rarity. which the TRD bits really are not.
-Mike
#24 CS/CSR |
#3882 | ||
http://www.ft86club.com/forums/showthread.php?t=7535 I don't think there's anything 'better' than an RPF1, only different and slightly more expensive on the $/weight scale. Or cheaper if you're willing to sacrifice a pound or two. |
#3883 | |
Custom User Title
I've seen plenty of RPF1s locally. Just not sure what else is out there. I know the RPF1s are a cheap, reliable option but I wouldn't be averse to paying $100-$200 more a wheel if it's a few pounds lighter.
| The Following User Says Thank You to Locust For This Useful Post: | strat61caster (12-14-2015) |
#3884 | |
Drives: '14 FRS TT5
#3885 | |
![]() I wouldn't blindly take what's posted their without at least one second or third source for weights either. |
#3886 | |
Custom User Title
Speaking of which... Has anyone seen/tried these? http://www.rayswheels.co.jp/products...=en&wheel=G2PR The RAYS website says they'd work and my experience with Volks in the Evo world is that they're pretty much the tops you can get.
#3887 |
Senior Citizen
Drives: Scion FR-S
shameless plug for my set of RPF1s for sale....http://www.ft86club.com/forums/showp...78&postcount=1
#3888 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
I realize your examples were, perhaps, exaggerated, but I don't think the fact that they were going to consider the FR-S and BRZ the same car would be grounds to argue that the Corvette and the Cadillac are the same as well... |
| The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post: | SeanRTR (12-15-2015), strat61caster (12-15-2015) |
#3889 |
Drives: 2014 FR-S
The standard part rule evolved from problems with other manufacturers. Stuff like WS6 Brakes on a base Camaro. That's the problem you will be running into by trying to allow the BRZ/FR-S the same parts. It's not the BRZ/FRS it's all the other combinations guys will want to get the exception for.
| The Following User Says Thank You to markw For This Useful Post: | strat61caster (12-15-2015) |
#3890 |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
I am pretty split on the issue. On one side I think it would be great for the BRZ owners to feel like they can compete in CS again. (Even though I am not entirely convinced that they can't)
On the other side, and this has been presented before, a lot of people chose the BRZ due to the performance (perceived or actual) benefit compared to the FR-S. I don't really get how this is different from that. You are also making quite the exception and where do you draw the line. The line is pretty well defined right now. Once you allow the BRZ to install the TRD springs, can you then also install the OEM BRZ springs on an FR-S? It is really lame that the FR-S got a slight upgrade that may have allowed it to compete with the RX-8 and the MX-5 and the BRZ didn't, no doubt. In all fairness though, the BRZ is just as competitive with the MX-5 and RX8 as it was last year and people were fine running it then. |
| The Following User Says Thank You to DylanFRS For This Useful Post: | strat61caster (12-15-2015) |
#3891 |
Drives: '15 FR-S, '92 Sentra SE-R
The sting is making the financial commitment, then seeing the same exact car get a "something" you can't have.
Very few people here lack a Nationals jacket because they can't do TRD springs. "Wrong" stuff gets driven up the podium all the time. For me, the lowest hanging fruit is always the driver. I just left the ES pool where a '93 MR2 emerged from the crypt and finished second. It's pretty janky that two cars effectively separated by badges can't have parity. Still, you see the box that it could open. Applied elsewhere, you go further down the path to Street Prepared Lite. People already bitch about the current allowances for sway bars, wheel diameters, pimp shocks, etc. |
| The Following User Says Thank You to JimR For This Useful Post: | strat61caster (12-15-2015) |
#3892 | ||
C-Street AutoX
If the exception said 'joint-venture cars that share the same chassis/driveline (Engine/Trans)' can you think of an example of how this screws anything up? I can't think of any advantages that are unlocked with this wording, but maybe I'm missing something. Saabaru/WRX wagon - I see no advantage/these cars all blew up and went to SM/ST Solstice/Sky - ZOK suspension BS Saturn Sky? Who cares, do it. Firebird/Camaro - WS6 parts on an SS Camaro, Z28 parts on a Formula (not a V6 model) Who cares again, I see no real advantages here either. Corvette/Caddy and F150/Mustang - ....these are not the same cars. Quote:
Yep, who cares, do it. I can't think of a situation where this rule would allow a car any kind of significant performance advantage. Someone tell me what I'm missing. The FR-S and the BRZ need to be on an equal playing field, period. There's too many SCCA members that bought these cars to compete in Street class to let a Toyota document with unfortunate verbiage alienate half of the owners. I think it's a bit ridiculous to see how many BRZ owners have simply bailed because of this minor performance advantage, but the cars should be on the same level of prep.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
